4 Replies Latest reply on Aug 9, 2014 11:59 PM by therealdobro
    How to automate an effect?
    john_2 Newcomer
      In Multitrack Editor I added an effect to an audio file. What I need is to automate it using Write (or Latch).
      The problem is, unlike Pan/Volume which have visible controls making live automation easy, for effects there are no controls visible the whole time. I have to open that effect's window, modify, close the window, then repeat all over again.
      What should I do in this situation?
        • 1. Re: How to automate an effect?
          therealdobro Helper
          Check the track pane which contains all your insert effects.  Below the effects pane, you see 'Read' with a triangle beside it.  Click the triangle, which gives you a dropdown effect lane (I doubt that's the correct terminology for it).  I've never used it and don't know how, but does it help with what you're trying to do?
          • 2. Re: How to automate an effect?
            _durin_ Rockstar
            You can enable the automation envelopes for any effect in a track effects rack by clicking the triangle next to the Read/Write/Touch/Latch dropdown.  Here, you can show or hide many automation envelopes for effect parameters for manual editing of keyframes and changes.  Additionally, you can keep the effect UI open and during playback in Write/Touch/Latch mode, adjust the parameters which will update the envelopes for the modified parameters.
            • 3. Re: How to automate an effect?
              john_2 Newcomer
              I had already tried that but I wanted access to *all* the parameters of an effect (or more), which were sometimes more than a dozen, and to enable their envelopes one at a time was too tedious.
              However your second suggestion was great.
              Thanks.
              • 4. Re: How to automate an effect?
                therealdobro Helper
                It depends on the plugin, though.  Right?  Some plugins have tons of paramaters, and some have a blessed few.
