2 Replies Latest reply on Aug 10, 2014 4:10 AM by minekus2
    file is already imported but missing in LR
    minekus2
      In my catalog I have a folder with 378 pictures. On my harddrive there are 544 pictures in the folder.
      When I try to synchronise the folder in LR5, I get the message that there are no photo's to import.
      Earlier I got some greyed out pictures in the window and when I right click on them I get the message that the picture was already imported.
      It may be that I deleted the picture in LR, but not on the harddisk. But for 160+ pictures I doubt that.
      How can I resolve this?
      Can I import the pictures that have already been imported but are missing in LR and may be delete them from the harddisk?
      How can I select the messages that are missing in LR on the Harddisk and review them to delete or may be rename and import?
      Thank you for your suggestions.
      Jan Minekus
        • 1. Re: file is already imported but missing in LR
          ssprengel Adobe Community Professional & MVP
          Either LR has already imported those photos but it thinks they are in a different folder—you can search the All Photos collection by filename to try to find them, or some of the photos are JPGs with the same base filename as a raw file in the folder so the JPGs are considered sidecars of the raws and wouldn’t both show up as separate photos in LR.  There is a setting in LR preferences to treat JPGs and RAWs separately and if you enable this then you can synchronize the folder and see the JPGs as well as their corresponding raw files.
          • 2. Re: file is already imported but missing in LR
            minekus2 Level 1
            Hello,
            Thanks for your suggestion. It did not work. There are no sidecars in
            the folder.
            I can't search the all photo's because I do not know the filenames of
            the photos that are missing. I would have to manually compare each file.
            I found a solution myself after this.
            I moved all the files in the folder in LR to a different folder. LR did
            not have any files left.
            In windows I opened the empty folder and there were still all the files
            I couldn't import.
            I reviewed them all and decided to delete them all, as they were of no
            great importance, as I discovered that some of them were allready in
            another folder.
            In the future I will not do anything to the folders outside LR. I
            believe that was the cause of my problem.
            Thank you again for your reaction. It got me to the solution.
            ssprengel schreef op 9-8-2014 22:22:
            created by ssprengel <https://forums.adobe.com/people/ssprengel> in
            /Photoshop Lightroom/ - View the full discussion
            <https://forums.adobe.com/message/6625882#6625882>
