2 Replies Latest reply on Aug 10, 2014 12:19 PM by alexandertana
    PS Elements Album import from earlier version
      I just upgraded to elements 12 from 8.
      Besides not being as intuitive as version 8 was, my Album titles have been imported but nothing displays when you click on it and if you try to drag a photo to it get an error with no explanation as to cause.
      tags don't seem to acts consistently either
      All the above is on a windows Vista Ultimate 64
        • 1. Re: PS Elements Album import from earlier version
          Little_Pale_Face Most Valuable Participant
          First off, have you tried updating to 12.1 ? - select Updates from the Help menu
          When looking at the thumbnail grid, do you have Media tab selected at the top? If you click on one of your album names do you get the message "No media to be displayed"?
          It could be that you have a filter applied. Click on the All Media button at the top and then click on the album name again.
          The problem with trying to add a new image into an existing album is usually resolved by first creating a new dummy album. You don't need to add anything to it and you can delete it later but it should then allow you to move new images into the album.
          The way you filter by tags has changed since version 8. In version 12, if you hover over a keyword tag, you will see a small > appear to the right, click on that to select that tag as a filter.
          Hope that helps
          • 2. Re: PS Elements Album import from earlier version
            alexandertana Level 1
            Thank you for the quick answer.
            I updated to 12.1 and .......it worked!
            Thanks again
