1. Re: Adobe Photoshop CC 2014 Help TAB > Photoshop Online Help - LINK IS BROKEN
Chris Cox Aug 9, 2014 6:22 PM (in response to RickyLACA)That XML error shows that your local scripts/java code is broken, not the Adobe link.
The second part looks like a real problem: http://community.adobe.com/chcservices/services/redirect?u=http://help.adobe.com&p=Photosh op_15.0&l=en_US&id=AH_HOME is not currently responding.
I have a suspicion that I know the cause: a power outage at Adobe headquarters has many of the internal servers shutdown right now. That link shouldn't depend on internal servers, but it looks like it somehow does.
2. Re: Adobe Photoshop CC 2014 Help TAB > Photoshop Online Help - LINK IS BROKEN
Henk Tobbe Aug 9, 2014 10:24 PM (in response to Chris Cox)It is not only Photoshop Help that is down, but also the Help and Community pages for other software like Illustrator and Dreamweaver. Any idea when they'll be on line again?
3. Re: Adobe Photoshop CC 2014 Help TAB > Photoshop Online Help - LINK IS BROKEN
Chris Cox Aug 10, 2014 2:35 PM (in response to Henk Tobbe)I'm betting they'll be back online Monday morning. UPDATE: they appear to be back online now.
And someone at Adobe will have some explaining to do about why they were offline...
4. Re: Adobe Photoshop CC 2014 Help TAB > Photoshop Online Help - LINK IS BROKEN
Pfondaneche Aug 15, 2014 5:35 AM (in response to Chris Cox)Hello
I am having exactly the same problem with the French version of Photoshop CC 2014. The only menu item working is "What's new?".
Trying to access online help (F1) takes me to
Very similar to your page except for the language.
This page does not load (error 404).
I was on chat with Adobe support but they did not solve the problem.
I tried to reinstall and also used 3 different browsers (IE - FF - CH).
I have Photoshop installed on 2 different platforms (W7 and W8), same issue.
Were you able to solve your problem?
6. Re: Adobe Photoshop CC 2014 Help TAB > Photoshop Online Help - LINK IS BROKEN
Noel Carboni Aug 15, 2014 6:55 AM (in response to Pfondaneche)Pfondaneche wrote:
Hello
Pfondaneche, when you press F1, are you just in the main Photoshop window?
When I press F1 I see it go through a quick redirection and within a small fraction of a second it ends up here:
Photoshop Help | Photoshop Help
The specific link you posted does not work for me either, so I'm assuming there's an Adobe server problem somewhere, or maybe a problem with that particular link.
I've noticed Adobe has failed to update a number of its pages for the new Photoshop CC 2014.1 release. For example, where is a new page that describes where Photoshop CC 2014.1 keeps its preference files?
-Noel
7. Re: Adobe Photoshop CC 2014 Help TAB > Photoshop Online Help - LINK IS BROKEN
Pfondaneche Aug 15, 2014 7:07 AM (in response to Noel Carboni)Yes I press F1 from the main window. It is the same if I select menu items #2 and #3 from the help menu. Curiously item#1 (what's new?) works properly.
From there you can go up one level in the help file and end-up where F1 should take you directly. Which means the content is available, it's just that the url does not work.
8. Re: Adobe Photoshop CC 2014 Help TAB > Photoshop Online Help - LINK IS BROKEN
Noel Carboni Aug 15, 2014 7:34 AM (in response to Pfondaneche)From what I can see it's the French resource that's missing on the server...
A slight variation to the URL you posted where en_US is substituted for fr_FR makes it work (and deliver of course English content).
So my theory that Adobe isn't employing enough web people to keep up with their advertised services must be close to the mark.
You guys at Adobe need someone who can go find all the proper web pages and update them? I'm available.
-Noel
9. Re: Adobe Photoshop CC 2014 Help TAB > Photoshop Online Help - LINK IS BROKEN
Pfondaneche Aug 15, 2014 7:36 AM (in response to Pfondaneche)I was in contact with Abobe Support team by chat in //. It seems to be a general issue, they have escalated the case.
