• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Data format conversion issue
Explorer ,
Apr 20, 2007 Apr 20, 2007
I have a problem with data being corrupted in transit from a form to a query to output. Here is the statement:
QuerySetCell(PartsOrdered, "Part",evaluate('form.partno#Counter#'));
However, what is happening is, when a part number gets passed in that looks like 110-25-5 (which is, BTW, rather typical), it is being converted to a datetime object.
I googled the issue of the Evaluate() method, and I'm aware it's a problem. However, I've tried a few different configurations to maintain the data format, and none work.
Suggestions?
TOPICS
Advanced techniques
Views
592
Translate
Translate
Report
Report
Community guidelines
community guidelines
Participant , Apr 20, 2007 Apr 20, 2007
Check out the documentation for queryNew. You can specify a list of datatypes for your columns. Make sure you specify VarChar for your Part column.
Votes
Translate
Translate
LEGEND ,
pblecha wrote:
> Suggestions?
The highly preferred array notation method. querySetCell(ParsOrdered,
form["partno" & counter]); Look ma no evaluate.
But it looks like you where correctly getting the form value, but that
it is being interpreted as a date. Do you define the data types for the
query you are building? How else is this data being used?
Votes
Translate
Translate
Report
Report
Participant ,
Evaluate is definitely not an efficient way to do anything... it should really be avoided in CF.
For this, try the following:
QuerySetCell(PartsOrdered, "Part",form["partno#Counter#"]);
Your syntax for evaluate is correct, btw, so you might run into the same issue here.
Votes
Translate
Translate
Report
Report
Explorer ,
Yes, it's still returning the same datetime object.
Votes
Translate
Translate
Report
Report
LEGEND ,
What does your queryNew() function look like?
How are you outputing the value?
What else might you be doing to the value in between?
What does <cfoutput>#form["partno" & counter]#<cfoutput> at the
beginning of the page show?
Votes
Translate
Translate
Report
Report
Participant ,
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
quote:
This worked. Thanks.
Votes
Translate
Translate
Report
Report
New Here ,
what about using Evaluate(DE(form["partno#Counter#"]))
Votes
Translate
Translate
Report
Report
Resources
Documentation
