3 Replies Latest reply on Mar 29, 2016 3:04 AM by dina1029
    retain layer size not working in after effects composition?
    Prema_b
      I have imported illustrator documents into after effects CC selecting "retain layer size" when importing the composition.
      When the ai files import the illustrator layers are all at the document size instead of at the layer size. i.e. the bounding box is the size of the document - rather than the size of the small object on that layer.
      The issue does not happen with photoshop layer import which works fine - only ai documents.
      I've been using after effects for years and never had this issue. I've tried importing several different ai files with the same result. The issue has cropped up this week.
