6 Replies Latest reply on Aug 11, 2014 7:28 AM by thedigitaldog
    Colour inappropriately rendered in Lightroom
    Dorset Photographer
           I take a JPEG image in Canon EOS 5D set to sRGB colour space. It is a JPEG, not a RAW image. I download to a Dell PC running Windows XP SP3. When I display the image using Canon's ZoomBrowser EX utility the colour is rendered accurately. When I open the image with MS Picture Manager the colour is again rendered accurately; by this I mean that no colour adjustment would be necessary before "publication" - print, web or whatever. So far, so good.
           However, when I import the image to Lightroom 3, the image is displayed with a muddy brown hue. Not so good! Without editing the image in any way within Lightroom, I export the image again as a JPEG file. When I open this file with MS Picture Manager the colour is again rendered perfectly.
           This all sounds OK except that within Lightroom the colour rendering is so bad that one is tempted to try and adjust the colour balance or whatever, when in fact no adjustment is necessary for this "perfect" image.
           Why is the colour rendition of JPEG sRGB images so bad within Lightroom?
           In the case of my so-called "perfect" image, it doesn't matter as no adjustment wasnecessary, but with a less than perfect image it would be impossible to adjust the colour because the Lightroom rendition is so unrealistic.
           By the way, the image acquires the same muddy brown hue when opened in Photoshop Elements 10, so it seems like a consistent Adobe flaw.
           So is Lightroom (and Photoshop Elements) only suitable for processin RAW images? Or must I set the colour space within the camera to Adobe RGB if I intend to use Adobe products?
           If I select Adobe RGB colour space within the camera, will the images be displayed accurately in non-Adobe applications or printers?
           Strangely, I don't remember this being an issue when I first started using Lightroom. In case you're wondering, all images were displyed on the same monitor.
           Thanks!
        • 1. Re: Colour inappropriately rendered in Lightroom
          D Fosse Adobe Community Professional & MVP
          You have a broken display profile. A bad profile may affect different applications differently; and some applications aren't color managed at all and don't use the profile.
          Recalibrate to make a new profile, or if you don't have a calibrator use sRGB until you get one. Go to Control Panel > Color Management > Devices:
          Relaunch Lightroom so that it can pick up the new profile at startup.
          • 2. Re: Colour inappropriately rendered in Lightroom
            elie-d Level 4
            This sounds like a corrupted monitor profile or at least one that LR is finding unpalatable. If your monitor is calibrated, recalibrate. And if given the choice, select to make a V.2 profile. LR 3 does not support V.4 profiles and PSE may also have problems with them. If you have not calibrated your monitor, check your OS display settings to see if it is using a generic profile made by the monitor manufacturer and installed by the driver. LR sometimes finds these canned profiles indigestible. To test whether it is in fact a display profile problem, make sRGB your OS display default. If LR's display improves, you will have your answer.
            N. B., setting sRGB as the display default in effect cancels LR and PSE color management. It is only a temporary test, not a solution.
            • 3. Re: Colour inappropriately rendered in Lightroom
              thedigitaldog MVP & Adobe Community Professional
              Yes but only if the other applications are color managed (understand ICC profiles for display and printer).
              • 4. Re: Colour inappropriately rendered in Lightroom
                Dorset Photographer Level 1
                Thank you 21 for solving the problem. The colour profile was set to 1905FP.icm which is logical as the monitor is a Dell 1905P. I assume this file is corrupted. When I Added sRGB and set it as the Default profile, the colour was immediately rendered accurately in LR3 and PSE10. I suppose I could look for the uncorrupted 1905.icm profile but as I am taking delivery of a new Dell XPS 8700 today I may not spend too much time looking. With Windows 8.1 to get my head around I'm not likely to have much time in the foreseeable future. I hope the new PC will solve my Samsung-Kies synchronisation problems under XP. Many thanks.
                • 5. Re: Colour inappropriately rendered in Lightroom
                  Thanks for also supplying the correct answer.
                  • 6. Re: Colour inappropriately rendered in Lightroom
                    It fixed the ugly preview but please don't think it's accurate. It will only move towards that goal by calibrating and creating a custom ICC display profile that defines your display system.
                    If you view an image in Photoshop or Lightroom using that generic sRGB profile, then view the same image in a non ICC aware application as I discussed, they will not match. That is because LR is ICC aware and uses the actual display profile (which in your case is better but not correct in terms of describing your Dell and that is why they provided another almost equally canned profile). Non ICC app's just send the numbers to the display which is quite different from what LR and Photoshop does.
