1. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
JJMack Aug 11, 2014 8:55 AM (in response to Zocolco)What OS are you using. First as an administrator use your system disk check program make sure you disk is in good shape. Free up as much space as you can on you boot disk use your system disk clean up program to delete temp file. Make sure there is lots of free disk space. Then login as the non administrator user start Photoshop and press and hold Ctrl|CMD+Atl|Option+Shift as soon as you start Photoshop. If done in time Photoshop should prompt you asking if you want your preferences deleted. Reply Yes, Photoshop should then start up and work..
2. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Zocolco Aug 15, 2014 3:11 PM (in response to JJMack)Hello, firstly I apologise for the delay in replying to your helpful post's. I’am traveling at the moment SE Asia, and internet connection not always possible, when I do get the time to reply.
For your information, I have tried many times the Shift/Ctrl/Alt option, however this fails to work for me.I receive the Prompt to delete PS settings, however, PS quits within a second or two just after I've agreed to delete settings file on launch of app. I’m currently running OS X Version 10.9.4.
I have chatted with Adobe first, after they reviewed the crash report. They have said that The settings of my user account in Mac are corrupted, cause is Exception Type: EXC_BAD_ACCESS (SIGSEGV)Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000080VM and that I should speak with Apple. Adobe also sent this link http://helpx.adobe.com/x-productkb/global/troubleshoot-unexpected-behavior-user-account.ht ml
I then spoke with Apple, they reviewed the same crash log however, found no clear evidence to support Adobe’s claim.
Apple, suggested I set up another user account and test that one for the problem. I will let you know how I get on. It might just be the easiest option for me….the hidden Libraries, etc..
Just to note, I did follow your useful link “ glad" Resetting Photoshop preferences-Alien Skin Software for a more targeted approach.However, the problem still exists. I’ have since set up a other user account and it appears to be working fine…..its just such a hassle, switching between accounts…I was hoping to solve the issue and not work around it. Anyway, thank you for your help and time on this issue….it was much appreciated.
Kind regards, Pinchermartin@Zenfolio.
3. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Chris CoxAug 15, 2014 3:14 PM (in response to Zocolco)
We need to see the full, detailed crash report to know why you crashed.
But MacOS gets really, really unstable when the boot volume fills up.
BTW - Apple's first tier support and "geniuses" have no idea how to read a crash report.
Adobe's first tier support doesn't know how either, but they're supposed to forward the requests to more senior support folks who can read them (and then call me when they can't figure it out :-).
4. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Zocolco Aug 16, 2014 11:42 AM (in response to Chris Cox)P.s trying to send this report is a nightmare, I kept getting, Error Message," Your content could not be saved due to an error. You may have been logged out. If this problem persists please contact your system administrator. Click here to refresh this page. "
Even though I freshly sign in, paste content, & then add reply......... is the "Crash Log" Report to Long.....or My Internet connection...failing me again..testing on the possibilities of sending this message.
5. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Zocolco Aug 16, 2014 11:46 AM (in response to Zocolco)Can not send Crash Log! Report too long. Please advise.
6. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Chris CoxAug 16, 2014 12:35 PM (in response to Zocolco)
Post the log somewhere else and post a link to it here.
(and I'm not sure why some people can post crash logs and others can't - is it a browser issue?)
7. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Zocolco Aug 17, 2014 6:14 AM (in response to Chris Cox)Process: Adobe Photoshop CC [23973]
Path: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/MacOS/Adobe Photoshop CCIdentifier:
Version:
Code Type:
Parent Process: launchd [148]com.adobe.Photoshop 14.2.1 (14.2.1.570)
X86-64 (Native)
Responsible: User ID:
Date/Time:
OS Version:
Report Version: 11
Anonymous UUID: D75EAA2C-F5C9-73DE-57A9-860A792F7AC5Sleep/Wake UUID: 5E90CBF3-F73E-49F7-BF2D-E013005EEFD8 Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000080VM Regions Near 0x80: -->
__TEXT 0000000100000000-0000000103fa4000 [ 63.6M] r-x/rwx SM=COW /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/MacOS/Adobe Photoshop CC
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
Adobe Photoshop CC [23973] 502
2014-08-17 01:43:57.404 +0700 Mac OS X 10.9.4 (13E28)
0 com.google.selectivetool const&) + 191
1 com.google.selectivetool 2 com.google.selectivetool + 10153 com.google.selectivetool
SPBasicSuite*, td_PSCommands*, std::vector<FilterDescriptionList*, std::allocator<FilterDescriptionList*> >, wxArrayInt) + 1950- 4 com.google.selectivetool
- 5 com.google.selectivetool
void*) + 54 6 7 8 9 10 11 12 13 14 15 16 17 18 com.adobe.Photoshop com.adobe.Photoshop com.adobe.Photoshop com.adobe.Photoshop com.adobe.Photoshop com.adobe.Photoshop com.apple.AppKit com.adobe.Photoshop com.adobe.Photoshop com.adobe.Photoshop com.adobe.Photoshop com.adobe.Photoshop com.adobe.Photoshop 0x000000010030f377 0x100000000 + 3208055 0x000000010009456d 0x100000000 + 607597 0x0000000100093611 0x100000000 + 603665 0x000000010008de4f 0x100000000 + 581199 0x000000010008dc10 0x100000000 + 580624 0x00000001017bcf54 0x100000000 + 24891220 0x00007fff8b3a39f9 -[NSApplication run] + 646 0x00000001017bd732 0x100000000 + 24893234 0x00000001017bea08 0x100000000 + 24898056 0x000000010008e53f 0x100000000 + 582975 0x00000001002f1ff7 0x100000000 + 3088375 0x00000001002f2199 0x100000000 + 3088793 0x0000000100002e34 0x100000000 + 11828 0x00007fff8a4f1e6a __workq_kernreturn + 10 0x00007fff93aa3f08 _pthread_wqthread + 330 0x00007fff93aa6fb9 start_wqthread + 13 Thread 1:
- 0 libsystem_kernel.dylib
- 1 libsystem_pthread.dylib
- 2 libsystem_pthread.dylib
0x000000011926f63f ParseFavoritesFile(wxString const&, wxString 0x0000000119271523 SelectiveTool::GetConfigFavorites(int) + 2001 0x0000000119277f7d SelectiveTool::CreateSection(wxWindow*, int, int) 0x000000011927ba82 SelectiveTool::SelectiveTool(wxWindow*, 0x0000000119264957 StartDialog() + 247
0x000000011926aac6 HandlePhotoshopEvent(unsigned int, _ADsc*, int, Thread 2:: Dispatch queue: com.apple.libdispatch-manager
- 0 libsystem_kernel.dylib 0x00007fff8a4f2662 kevent64 + 10
- 1 libdispatch.dylib 0x00007fff8af4e421 _dispatch_mgr_invoke + 239
2 libdispatch.dylib 0x00007fff8af4e136 _dispatch_mgr_thread + 52 Thread 3:- 0 libsystem_kernel.dylib
Thread 4:
Thread 5:: MPSupport Worker
- 2 MultiProcessor Support
- 3 MultiProcessor Support
- 4 MultiProcessor Support
- 5 libsystem_pthread.dylib
- 6 libsystem_pthread.dylib
- 7 libsystem_pthread.dylib
Thread 6:: MPSupport Worker
Thread 7:: MPSupport Worker
0x00007fff8a4f1716 __psynch_cvwait + 10 0x00007fff93aa4c3b _pthread_cond_wait + 727
0x0000000111caf65b 0x111c6a000 + 284251 0x0000000111caf51b 0x111c6a000 + 283931 0x0000000111cce754 0x111c6a000 + 411476
0x00007fff93aa2899 _pthread_body + 138 0x00007fff93aa272a _pthread_start + 137 0x00007fff93aa6fc9 thread_start + 13
Thread 8:: Lens Profile Manager
8. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Zocolco Aug 17, 2014 6:16 AM (in response to Zocolco)- 0 libsystem_kernel.dylib
- 2 com.adobe.Photoshop
- 3 com.adobe.Photoshop
- 4 com.adobe.Photoshop
- 5 com.adobe.Photoshop
- 8 libsystem_pthread.dylib
Thread 9:
1 libtbb.dylib 0x0000000104bc8079 tbb::internal::rml::private_worker::thread_routine(void*) + 441
- 3 libsystem_pthread.dylib
- 4 libsystem_pthread.dylib
0x00007fff8a4f1716 __psynch_cvwait + 10 0x00007fff93aa4c3b _pthread_cond_wait + 727 0x00000001017eaf8f 0x100000000 + 25079695 0x00000001017ea07e 0x100000000 + 25075838 0x0000000101763d02 0x100000000 + 24526082 0x00000001017e9604 0x100000000 + 25073156 0x00007fff93aa2899 _pthread_body + 138 0x00007fff93aa272a _pthread_start + 137 0x00007fff93aa6fc9 thread_start + 13 0x00007fff8a4eda56 semaphore_wait_trap + 10 0x00007fff93aa2899 _pthread_body + 138 0x00007fff93aa272a _pthread_start + 137 0x00007fff93aa6fc9 thread_start + 13
Thread 10:- 0 libsystem_kernel.dylib 0x00007fff8a4eda56 semaphore_wait_trap + 10
- 1 libtbb.dylib 0x0000000104bc8079 tbb::internal::rml::private_worker::thread_routine(void*) +
441
Thread 12:
- 1 libsystem_c.dylib
- 2 com.adobe.PSAutomate
- 3 com.adobe.PSAutomate
- 4 com.adobe.PSAutomate
0x00007fff8a4f1a3a __semwait_signal + 10 0x00007fff8cba9dc0 nanosleep + 200 0x0000000119b75508 0x119a1f000 + 1402120 0x0000000119b5af6e 0x119a1f000 + 1294190 0x0000000119b750a5 0x119a1f000 + 1400997 0x00007fff93aa2899 _pthread_body + 138 0x00007fff93aa272a _pthread_start + 137 0x00007fff93aa6fc9 thread_start + 13 0x00007fff93aa2899 _pthread_body + 138 0x00007fff93aa272a _pthread_start + 137 0x00007fff93aa6fc9 thread_start + 13 Thread 11:
441
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000600000e44770 rbx: 0x00007fff5fbfe390 rcx: 0x000000000003565d rdx:0x000000000003565c
rdi: 0x0000000108d27100 rsi: 0x0000000000000008 rbp: 0x00007fff5fbfe300 rsp: 0x00007fff5fbfdc90r8: 0x000000011a08e500 r9: 0x0000000000000000 r10: 0x000000000003565c r11: 0x0000000000000212
r12: 0x00007fff5fbfe360 r13: 0x0000000000000001 r14: 0x0000000000000000 r15: 0x00000001194bdae0
rip: 0x000000011926f63f rfl: 0x0000000000010242 cr2: 0x0000000000000080 Logical CPU: 0
9. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Zocolco Aug 17, 2014 6:19 AM (in response to Zocolco)Error Code:
Trap Number: 140x00000004
Binary Images:
0x100000000 - 0x103fa3f5f +com.adobe.Photoshop (14.2.1 - 14.2.1.570) <DDBD24F2-1527-3A3D-9299-55F59B013742> /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/MacOS/Adobe Photoshop CC
0x104bb9000 - 0x104be5ff7 +libtbb.dylib (0) <64B7013E-D548-3F7B-A2FB-28B7B932275C> /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Frameworks/libtbb.dylib
0x104bff000 - 0x104c1efe7 +libtbbmalloc.dylib (0) <6887ED68-67ED-3748-82DA- B39A3EB210BB> /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Frameworks/libtbbmalloc.dylib
0x104c42000 - 0x104c48fff org.twain.dsm (1.9.5 - 1.9.5) <B002FF14-291D-35C7-ABD3- 8271EFA07675> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
0x104c50000 - 0x104c63ff7 +com.adobe.ahclientframework (1.8.0.31 - 1.8.0.31) <58BB943C- 98EC-3812-AAAB-74F66630D1D4> /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x104c6d000 - 0x104c71fff com.apple.agl (3.2.3 - AGL-3.2.3) <9851E4CC-DA6B-3AF4-9B06- 61BAC289572D> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x104c78000 - 0x104e44fff +com.adobe.owl (AdobeOwl version 5.0.24 - 5.0.24) <1C99AA07- E73F-370B-82FA-01C1C4AAF97D> /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x104e87000 - 0x105420fff +com.adobe.MPS (AdobeMPS 5.8.1.31977 - 5.8.1.31977)
10. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Zocolco Aug 17, 2014 7:01 AM (in response to Zocolco)Chris, I'm very sorry....I thought I might be able to send this crash log in small clips, however, almost half way through the process of sending.....I received the "Warning Red Line" same as I've posted above. I then switched to Firefox, to see if it was a browser issue, but I received the same warning. You need the patients of a Saint, to pursue this enigma. It's wrecking my head. Where would you suggest I post the crash log? Kind regards
11. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Chris CoxAug 17, 2014 12:55 PM (in response to Zocolco)
As you can already read in your crash report - the crash has little to do with Photoshop, and everything to do with your Nik/Google SelectiveTool plugin.
Disable that plugin and contact Nik/Google for an update that fixes the bugs in that plugin.
12. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Zocolco Aug 24, 2014 5:52 AM (in response to Chris Cox)Hi Chris,
Thank You for your help. I did as you advised, I uninstalled Nik/Google collection. I tried to open CC 2014 and it opened first time on the user account that I was having difficulties with. I have since reinstalled latest version of the Nik software and everything appears to be running as normal. Cheer's to your good health!
13. Re: "Scratch disk" was almost full Warning. I deleted open files to create space. However, photoshop CC, crashed before I could free space. I tried many times to re-open Photoshop CC but within the 2-seconds it crashes on load. I then decided to update to
Zocolco Aug 24, 2014 6:06 AM (in response to JJMack)Hi JJMack,
I would like to thank you for your reply. It was new information to me and has helped me to develop my knowledge of CC Photoshop. Kind Regards,
