0 Replies Latest reply on Aug 11, 2014 1:56 PM by thomas-shaw
    How do i change the path of data ajax false from returning to homepage, when using a PHP mail form in jquery mobile?
    thomas-shaw
      I have a put a php mail form in the quote page of my mobile site. However when i send the form it returns to the route page rather than the quote page, i have used the data ajax false action as i dont want to send via ajax. i have left the thanks page blank as i want it to remain on the same page showing sent or declined message.  Can someone help please?
      <?php
      // OPTIONS - PLEASE CONFIGURE THESE BEFORE USE!
      $yourEmail = "Thomas-shaw1988@hotmail.co.uk"; // the email address you wish to receive these mails through
      $yourWebsite = "www.firstcalltransport.co.uk"; // the name of your website
      $thanksPage = ''; // URL to 'thanks for sending mail' page; leave empty to keep message on the same page
      $maxPoints = 4; // max points a person can hit before it refuses to submit - recommend 4
      $requiredFields = "name,email,collection,delivery,comments"; // names of the fields you'd like to be required as a minimum, separate each field with a comma
      // DO NOT EDIT BELOW HERE
      $error_msg = array();
      $result = null;
      $requiredFields = explode(",", $requiredFields);
      function clean($data) {
        $data = trim(stripslashes(strip_tags($data)));
        return $data;
      function isBot() {
        $bots = array("Indy", "Blaiz", "Java", "libwww-perl", "Python", "OutfoxBot", "User-Agent", "PycURL", "AlphaServer", "T8Abot", "Syntryx", "WinHttp", "WebBandit", "nicebot", "Teoma", "alexa", "froogle", "inktomi", "looksmart", "URL_Spider_SQL", "Firefly", "NationalDirectory", "Ask Jeeves", "TECNOSEEK", "InfoSeek", "WebFindBot", "girafabot", "crawler", "www.galaxy.com", "Googlebot", "Scooter", "Slurp", "appie", "FAST", "WebBug", "Spade", "ZyBorg", "rabaz");
        foreach ($bots as $bot)
        if (stripos($_SERVER['HTTP_USER_AGENT'], $bot) !== false)
        return true;
        if (empty($_SERVER['HTTP_USER_AGENT']) || $_SERVER['HTTP_USER_AGENT'] == " ")
        return true;
        return false;
      if ($_SERVER['REQUEST_METHOD'] == "POST") {
        if (isBot() !== false)
        $error_msg[] = "No bots please! UA reported as: ".$_SERVER['HTTP_USER_AGENT'];
        // lets check a few things - not enough to trigger an error on their own, but worth assigning a spam score..
        // score quickly adds up therefore allowing genuine users with 'accidental' score through but cutting out real spam
        $points = (int)0;
        foreach ($badwords as $word)
        if (
        strpos(strtolower($_POST['comments']), $word) !== false ||
        strpos(strtolower($_POST['name']), $word) !== false
        $points += 2;
        if (strpos($_POST['comments'], "http://") !== false || strpos($_POST['comments'], "www.") !== false)
        $points += 2;
        if (isset($_POST['nojs']))
        $points += 1;
        if (preg_match("/(<.*>)/i", $_POST['comments']))
        $points += 2;
        if (strlen($_POST['name']) < 3)
        $points += 1;
        if (strlen($_POST['comments']) < 15 || strlen($_POST['comments'] > 1500))
        $points += 2;
        if (preg_match("/[bcdfghjklmnpqrstvwxyz]{7,}/i", $_POST['comments']))
        $points += 1;
        // end score assignments
        foreach($requiredFields as $field) {
        trim($_POST[$field]);
        if (!isset($_POST[$field]) || empty($_POST[$field]) && array_pop($error_msg) != "Please fill in all the required fields and submit again.\r\n")
        $error_msg[] = "Please fill in all the required fields and submit again.";
        if (!empty($_POST['name']) && !preg_match("/^[a-zA-Z-'\s]*$/", stripslashes($_POST['name'])))
        $error_msg[] = "The name field must not contain special characters.\r\n";
        if (!empty($_POST['email']) && !preg_match('/^([a-z0-9])(([-a-z0-9._])*([a-z0-9]))*\@([a-z0-9])(([a-z0-9-])*([a-z0-9]))+ ' . '(\.([a-z0-9])([-a-z0-9_-])?([a-z0-9])+)+$/i', strtolower($_POST['email'])))
        $error_msg[] = "That is not a valid e-mail address.\r\n";
        if (!empty($_POST['url']) && !preg_match('/^(http|https):\/\/(([A-Z0-9][A-Z0-9_-]*)(\.[A-Z0-9][A-Z0-9_-]*)+)(:(\d+))?\ /?/i', $_POST['url']))
        $error_msg[] = "Invalid website url.\r\n";
        if ($error_msg == NULL && $points <= $maxPoints) {
        $subject = "Automatic Form Email";
        $message = "You received this e-mail message through your website: \n\n";
        foreach ($_POST as $key => $val) {
        if (is_array($val)) {
        foreach ($val as $subval) {
        $message .= ucwords($key) . ": " . clean($subval) . "\r\n";
        } else {
        $message .= ucwords($key) . ": " . clean($val) . "\r\n";
        $message .= "\r\n";
        $message .= 'IP: '.$_SERVER['REMOTE_ADDR']."\r\n";
        $message .= 'Browser: '.$_SERVER['HTTP_USER_AGENT']."\r\n";
        $message .= 'Points: '.$points;
        if (strstr($_SERVER['SERVER_SOFTWARE'], "Win")) {
        $headers   = "From: $yourEmail\r\n";
        } else {
        $headers   = "From: $yourWebsite <$yourEmail>\r\n";
        $headers  .= "Reply-To: {$_POST['email']}\r\n";
        if (mail($yourEmail,$subject,$message,$headers)) {
        if (!empty($thanksPage)) {
        header("Location: $thanksPage");
        exit;
        } else {
        $result = 'Your mail was successfully sent.';
        $disable = true;
        } else {
        $error_msg[] = 'Your mail could not be sent this time. ['.$points.']';
        } else {
        if (empty($error_msg))
        $error_msg[] = 'Your mail looks too much like spam, and could not be sent this time. ['.$points.']';
      function get_data($var) {
        if (isset($_POST[$var]))
        echo htmlspecialchars($_POST[$var]);
      <!DOCTYPE HTML>
      <html>
      <head>
      <meta charset="utf-8">
      <title>Untitled Document</title>
      <link href="CSS/stylesheetnew.css" rel="stylesheet" type="text/css">
      <link href="../jquery-mobile/jquery.mobile-1.0a3.min.css" rel="stylesheet" type="text/css">
      <script src="../jquery-mobile/jquery-1.5.min.js" type="text/javascript"></script>
      <script src="../jquery-mobile/jquery.mobile-1.0a3.min.js" type="text/javascript"></script>
      <style type="text/css">
        p.error, p.success {
        font-weight: bold;
        padding: 10px;
        border: 1px solid;
        p.error {
        background: #ffc0c0;
        color: #F00;
        p.success {
        background: #b3ff69;
        color: #4fa000;
      </style>
      </head>
      <body>
      <div data-role="page" id="home">
        <div data-role="header" data-position="fixed">
         <h1>FIRSTCALL TRANSPORT</h1>
      </div>
          <div data-role="navbar" data-position="fixed">
                                      <ul>
                                        <li><a href="#about">About</a></li>
                                        <li><a href="#services">Services</a></li>
                                        <li><a href="#contact">Contact</a></li>
                                        <li><a href="#quote">Quote</a></li>
                                      </ul>
        </div>
        <div data-role="content"> </div>
           <div data-role="footer" data-position="fixed" > </div>
      </div>
      </div>
      <div data-role="page" id="quote">
          <h1>GET A QUOTE</h1>
        </div>
         <?php
      if (!empty($error_msg)) {
        echo '<p class="error">ERROR: '. implode("<br />", $error_msg) . "</p>";
      if ($result != NULL) {
        echo '<p class="success">'. $result . "</p>";
      <form action="<?php echo basename(__FILE__); ?>" method="post" data-ajax="false"  >
      <noscript>
        <p><input type="hidden" name="nojs" id="nojs" /></p>
      </noscript>
      <p>
        <label for="name">Name: *</label>
        <input type="text" name="name" id="name" value="<?php get_data("name"); ?>" /><br />
        <label for="email">E-mail: *</label>
        <input type="text" name="email" id="email" value="<?php get_data("email"); ?>" /><br />
              <label for="company">Company:</label>
        <input type="text" name="company" id="company" value="<?php get_data("company"); ?>" /><br />
        <label for="collection">Collection: *</label>
        <input type="text" name="collection" id="collection" value="<?php get_data("collection"); ?>" /><br />
          <label for="delivery">Delivery: *</label>
        <input type="text" name="delivery" id="delivery" value="<?php get_data("delivery"); ?>" /><br />
        <label for="comments">Message: *</label>
        <textarea name="comments" id="comments" rows="5" cols="20"><?php get_data("comments"); ?></textarea><br />
        <input type="submit" name="submit" id="submit" value="Send" <?php if (isset($disable) && $disable === true) echo ' disabled="disabled"'; ?> />
      </p>
      </form>  </div>
           <div data-role="footer" >  </div>
        </div>
        </div>
      </body>
      </html>
