1 Reply Latest reply on Aug 12, 2014 5:32 PM by A.T. Romano
    how can i add extra sound effects to my library in adobe premiere 12
    astonshaw
      how can i add extra sound effects to my library in adobe premiere 12????
        • 1. Re: how can i add extra sound effects to my library in adobe premiere 12
          A.T. Romano Level 7
          astonshaw
          What computer operating system is your Premiere Elements 12 running on?
          By "my library" I am assuming you mean to have your own sound effects available to you under the Expert and Quick workspaces, either
          a. Action Bar Menu at top of workspace/Audio/Sound Effects
          or
          b. Audio Tab at bottom of workspace/Sound Effects
          This does work for Windows, but I am not sure if it is applicable to Mac.
          1. Create your Sound Effect as a .wav file. Name the file....name_prv.wav. In this example bang_prv.wav
          2. Go to
          Local Disk C
          Program Data
          Adobe
          Premiere Elements
          12.0
          Online
          Sound Effects
          All_Lang
          and in the All_Lang Folder create a folder named "Mine". In the "Mine" Folder create a folder named Bang.
          In the Bang Folder, place in the Bang Folder the bang_prv.wav plus a copy of the metadata.xml copied from one of the other Adobe
          Sound Effects.
          After you close out of there, you should find your sound effect available for use in a project under the Action Bar Menu or Audio Tab route.
          I have not experimented with sound effects duration. This quick look used a 4.139 seconds sound effect.
          It might be just as easy to create your sound effects as wav files, store them in a folder on hard drive, and, when needed, import one into a project with Add Media/Files and Folders.
          Please let us know if this worked for you.
          Thank you.
          ATR
