1 Reply Latest reply on Aug 13, 2014 5:11 AM by cmc mihai
    Acrobat XI - hyperlink properties is changing when the file is moves
    cmc mihai
      02 final file
      01 initial file
      Good day Support,
      Kindly advice the procedure to create documents from MS Word 2010 using the PDF maker add-on and keeping the links absolute.
      When created the file, the link in pointing to the initial file as specified in the MS Word - the link is pointing to an file located on a specified path.
      Whenever this document is moved is start pointing to another location according to the place this file is moved. the link stays on the same location and it should be called from there only.
      Please refer to the pictures attached (01 initial and 02 final).
      Your prompt advice will be highly appreciated.
      Thanks / Mihai
      Email: mihai.carcu@gmail.com
