11 Replies Latest reply on May 3, 2007 10:53 AM by MultiMedia13
    Setting the duration of an action
    MultiMedia13 Level 1
      Is there a way to control the timing and/or blending of the color changes in this code?
      import flash.geom.ColorTransform;
      import flash.geom.Transform;
      var colorTrans:ColorTransform = new ColorTransform();
      var trans:Transform = new Transform(pages_main_mc);
      trans.colorTransform = colorTrans;
      page1_btn.onRelease = function() {
      colorTrans.rgb = 0x000000;
      page2_btn.onRelease = function() {
      colorTrans.rgb = 0xFFFFFF;
      Say like a 5 sec period from the time I click the pages2_btn before the color changes to white? In other words the color is black, 3 seconds after clicking the pages2_btn the color is 50% grey and at 5 sec the color is white? Some sort of a timer code for the color change?
        • 1. Re: Setting the duration of an action
          the code below the dotted line adds a new method to movieclips, colorFadeF().
          to use:
          • 2. Re: Setting the duration of an action
            I'm getting this
            **Error** Scene=Scene 1, layer=Action, frame=1:Line 10: Left side of assignment operator must be variable or property.
            MovieClip.prototype.colorFadeF = function(rgb1, a1, rgb2, a2, speed, steps) {
            Total ActionScript Errors: 1 Reported Errors: 1
            I what var or prop am I missing?
            • 3. Re: Setting the duration of an action
              copy and paste the code you used.
              • 4. Re: Setting the duration of an action
                pages_main_mc.colorFadeF(colorTrans.rgb,100,0x000000,100,5,50);
                pages_main_mc.colorFadeF(colorTrans.rgb,100,0xffffff,100,5,50);
                if (!var314159) {
                var314159 = 1;
                trA = ["ra", "rb", "ga", "gb", "ba", "bb", "aa", "ab"];
                function fadeF(mc) {
                if (!mc.repeatPass) {
                mc.repeatPass = 1;
                co = mc.mcCO;
                tf2 = mc.tf2;
                tf1 = mc.tf1;
                steps = mc.steps;
                intermediateTF = mc.intermediateTF;
                for (var ivar = 0; ivar<trA.length; ivar++) {
                num = Math.floor(mc.repeatPass*(tf2[trA[ivar]]-tf1[trA[ivar]])/steps)+tf1[trA[ivar]];
                intermediateTF[trA[ivar]] = num.toString();
                co.setTransform(intermediateTF);
                mc.repeatPass++;
                if (mc.repeatPass>steps) {
                clearInterval(mc.int);
                updateAfterEvent();
                this.mcCO = new Color(this);
                this.mcCO.setRGB(rgb2);
                this._alpha = a2;
                this.tf2 = this.mcCO.getTransform();
                this.mcCO.setRGB(rgb1);
                this._alpha = a1;
                this.tf1 = this.mcCO.getTransform();
                this.steps = steps;
                this.speed = speed;
                this.intermediateTF = new Array();
                clearInterval(this.int);
                this.repeatPass=0;
                this.int = setInterval(fadeF, 1000*this.speed/this.steps, this);
                • 5. Re: Setting the duration of an action
                  remove or comment the dotted line.
                  • 6. Re: Setting the duration of an action
                    Oops
                    I forgot to delete the ---------------------------------
                    • 7. Re: Setting the duration of an action
                      SUPER!!! You rock Kglad! I'm going to look through your code and see what makes things tick. I found the timing for the buttons. One other question and I may find it while looking at the code closer: Anyway for the buttons to have a memory of what the last buttons color was? Say I make page1 button 0000ff and page two ff0000 color is black to start I click page2 and the color goes from black to ff0000 I then hit page 1 and insted of the color going back to black the page one button knows that the current color is ff0000 and fades from that to 0000ff.
                      Once again thank you
                      • 8. Re: Setting the duration of an action
                        you can use:
                        • 9. Re: Setting the duration of an action
                          Ok, so I need to attatch that code and I am guessing add the "col" somewhere in the button code? Sorry, still grasping Flash and I have tried a few ways with no success. I seems I need for the button to know that col (or the current color of pages_main_mc) before it can make a fade to the new color. Humm, or would that mean the "col" needs to be in the fade function. I.E. function starts finds out what the current color is and then proceeds to fade to new color. That would make more sence. Well to me it would LOL but I wouldn't be here asking if I knew would I!
                          • 10. Re: Setting the duration of an action
                            in your button handlers:
                            • 11. Setting the duration of an action
                              Wow, once again I wanted to thank you for helping me with this. My main pages look and dance around with color! Now after thinking a bit more I've got another idea. Leave it to me! Anyway, I am using an XML gallery on my site and figured why not try and incorporate this with the gallery. So, is it possible to use the import flash.geom.ColorTransform; code with XML to have the XML call the background change function? I have tried a few ways I.E. having the XML call a SWF with code in it telling the parent to change the background and that seems to work somewhat(but not exactly). So then I started thinking what if i make a new node in the XML called <bgcolor> and used this code I used to tweak my gallery:
                              See Below
                              And tweaked that to add:
                              bgcolor = [];
                              bgcolor = xmlNode.childNodes.childNodes[3].firstChild.nodeValue;
                              I believe that has Flash recognize the new node bgcolor.
                              Then add the code you helped me with setting up the background change function minus the page buttons but adding code that tells Flash if it goes to the XML and loads say image 13 it would see this:
                              <pic>
                              <image>img/bri/bri_13.jpg</image>
                              <caption>Image #13</caption>
                              <thumbnail>img/bri/bri_sm_13.jpg</thumbnail>
                              <bgcolor>0x0000ff</bgcolor>
                              </pic>
                              That would tell Flash to load the decription, thumbnail of image 13, and if this thumbnail is released load the actual image 13 and change the color of the background to 0000ff using the cool fade function.
                              Am I in way over my head this time?
