5 Replies Latest reply on Aug 16, 2014 2:42 AM by c.pfaffenbichler
    Can scripting do path editing?
    the05
      I used ScriptListener to log what happens when I clicked path editing tool (screenshot above) on the top bar. I clicked every path editing tool on the top bar, however, only Combine generated scripts. This is what I got:
      var idcombine = stringIDToTypeID( "combine" );
          var desc143 = new ActionDescriptor();
          var idnull = charIDToTypeID( "null" );
              var ref76 = new ActionReference();
              var idPath = charIDToTypeID( "Path" );
              var idOrdn = charIDToTypeID( "Ordn" );
              var idTrgt = charIDToTypeID( "Trgt" );
              ref76.putEnumerated( idPath, idOrdn, idTrgt );
          desc143.putReference( idnull, ref76 );
      executeAction( idcombine, desc143, DialogModes.NO );
      I saved these code into a .jsx file and ran from Photoshop. It successfully combined pathes.
      I'm wondering why I couldn't get any code for other path editing tools. Is there other way to realize path editing with scripting?
      Information:
      Windows 7 64-bit SP1
      Photoshop cc 2014
      Javascript
        • 1. Re: Can scripting do path editing?
          c.pfaffenbichler Level 9
          As far as I can tell the only option is to assess the whole information of the Path, edit that Array and create a new Path.
          One can naturally remove the old Path and name the new one with the old one’s name.
          • 2. Re: Can scripting do path editing?
            the05 Level 1
            Thanks very much for your reply. Could you please provide an example?
            • 3. Re: Can scripting do path editing?
              This would create paths based on the first path’s subPathItems.
              // make paths from first path’s subpathitems;
              // 2014, use it at your own risk;
              #target "photoshop-70.032"
              if (app.documents.length > 0) {
              var myDocument = app.activeDocument;
              if (myDocument.pathItems.length > 0) {
              var theArray = collectPathInfoFromDesc2012 (myDocument, myDocument.pathItems[0]);
              var theName = myDocument.pathItems[0];
              for (var m = 0; m < theArray.length; m++) {
              createPath2012([theArray[m]], theName+"_"+m)
              ////// collect path info from actiondescriptor, smooth added //////
              function collectPathInfoFromDesc2012 (myDocument, thePath) {
              var originalRulerUnits = app.preferences.rulerUnits;
              app.preferences.rulerUnits = Units.POINTS;
              // based of functions from xbytor’s stdlib;
              var ref = new ActionReference();
              for (var l = 0; l < myDocument.pathItems.length; l++) {
                var thisPath = myDocument.pathItems[l];
                if (thisPath == thePath && thisPath.name == "Work Path") {
                ref.putProperty(cTID("Path"), cTID("WrPt"));
                if (thisPath == thePath && thisPath.name != "Work Path" && thisPath.kind != PathKind.VECTORMASK) {
                ref.putIndex(cTID("Path"), l + 1);
                if (thisPath == thePath && thisPath.kind == PathKind.VECTORMASK) {
                      var idvectorMask = stringIDToTypeID( "vectorMask" );
                      ref.putEnumerated( idPath, idPath, idvectorMask );
              var desc = app.executeActionGet(ref);
              var pname = desc.getString(cTID('PthN'));
              // create new array;
              var theArray = new Array;
              var pathComponents = desc.getObjectValue(cTID("PthC")).getList(sTID('pathComponents'));
              // for subpathitems;
              for (var m = 0; m < pathComponents.count; m++) {
                var listKey = pathComponents.getObjectValue(m).getList(sTID("subpathListKey"));
                var operation1 = pathComponents.getObjectValue(m).getEnumerationValue(sTID("shapeOperation"));
                switch (operation1) {
                case 1097098272:
                var operation = 1097098272 //cTID('Add ');
                break;
                case 1398961266:
                var operation = 1398961266 //cTID('Sbtr');
                break;
                case 1231975538:
                var operation = 1231975538 //cTID('Intr');
                break;
                default:
              // case 1102:
                var operation = sTID('xor') //ShapeOperation.SHAPEXOR;
                break;
              // for subpathitem’s count;
                for (var n = 0; n < listKey.count; n++) {
                theArray.push(new Array);
                var points = listKey.getObjectValue(n).getList(sTID('points'));
                try {var closed = listKey.getObjectValue(n).getBoolean(sTID("closedSubpath"))}
                catch (e) {var closed = false};
              // for subpathitem’s segment’s number of points;
                for (var o = 0; o < points.count; o++) {
                var anchorObj = points.getObjectValue(o).getObjectValue(sTID("anchor"));
                var anchor = [anchorObj.getUnitDoubleValue(sTID('horizontal')), anchorObj.getUnitDoubleValue(sTID('vertical'))];
                var thisPoint = [anchor];
                try {
                var left = points.getObjectValue(o).getObjectValue(cTID("Fwd "));
                var leftDirection = [left.getUnitDoubleValue(sTID('horizontal')), left.getUnitDoubleValue(sTID('vertical'))];
                thisPoint.push(leftDirection)
                catch (e) {
                thisPoint.push(anchor)
                try {
                var right = points.getObjectValue(o).getObjectValue(cTID("Bwd "));
                var rightDirection = [right.getUnitDoubleValue(sTID('horizontal')), right.getUnitDoubleValue(sTID('vertical'))];
                thisPoint.push(rightDirection)
                catch (e) {
                try {
                var smoothOr = points.getObjectValue(o).getBoolean(cTID("Smoo"));
                thisPoint.push(smoothOr)
                catch (e) {thisPoint.push(false)};
                theArray[theArray.length - 1].push(thisPoint);
                theArray[theArray.length - 1].push(closed);
                theArray[theArray.length - 1].push(operation);
              // by xbytor, thanks to him;
              function cTID (s) { return cTID[s] || cTID[s] = app.charIDToTypeID(s); };
              function sTID (s) { return sTID[s] || sTID[s] = app.stringIDToTypeID(s); };
              // reset;
              app.preferences.rulerUnits = originalRulerUnits;
              return theArray;
              ////// create a path from collectPathInfoFromDesc2012-array //////
              function createPath2012(theArray, thePathsName) {
              // thanks to xbytor;
              cTID = function(s) { return app.charIDToTypeID(s); };
              sTID = function(s) { return app.stringIDToTypeID(s); };
                  var desc1 = new ActionDescriptor();
                  var ref1 = new ActionReference();
                  ref1.putProperty(cTID('Path'), cTID('WrPt'));
                  desc1.putReference(sTID('null'), ref1);
                  var list1 = new ActionList();
                var thisSubPath = theArray[m];
                  var desc2 = new ActionDescriptor();
                  desc2.putEnumerated(sTID('shapeOperation'), sTID('shapeOperation'), thisSubPath[thisSubPath.length - 1]);
                  var list2 = new ActionList();
                  var desc3 = new ActionDescriptor();
                  desc3.putBoolean(cTID('Clsp'), thisSubPath[thisSubPath.length - 2]);
                  var list3 = new ActionList();
              for (var n = 0; n < thisSubPath.length - 2; n++) {
                var thisPoint = thisSubPath[n];
                  var desc4 = new ActionDescriptor();
                  var desc5 = new ActionDescriptor();
                  desc5.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), thisPoint[0][0]);
                  desc5.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), thisPoint[0][1]);
                  desc4.putObject(cTID('Anch'), cTID('Pnt '), desc5);
                  var desc6 = new ActionDescriptor();
                  desc6.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), thisPoint[1][0]);
                  desc6.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), thisPoint[1][1]);
                  desc4.putObject(cTID('Fwd '), cTID('Pnt '), desc6);
                  var desc7 = new ActionDescriptor();
                  desc7.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), thisPoint[2][0]);
                  desc7.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), thisPoint[2][1]);
                  desc4.putObject(cTID('Bwd '), cTID('Pnt '), desc7);
                  desc4.putBoolean(cTID('Smoo'), thisPoint[3]);
                  list3.putObject(cTID('Pthp'), desc4);
                  desc3.putList(cTID('Pts '), list3);
                  list2.putObject(cTID('Sbpl'), desc3);
                  desc2.putList(cTID('SbpL'), list2);
                  list1.putObject(cTID('PaCm'), desc2);
                  desc1.putList(cTID('T   '), list1);
                  executeAction(cTID('setd'), desc1, DialogModes.NO);
              if (hasVectorMask() == false) {
              if (thePathsName != undefined) {app.activeDocument.pathItems[app.activeDocument.pathItems.length - 1].name = thePathsName};
              var myPathItem = app.activeDocument.pathItems[app.activeDocument.pathItems.length - 1];
              else {
              if (thePathsName != undefined) {app.activeDocument.pathItems[app.activeDocument.pathItems.length - 2].name = thePathsName};
              var myPathItem = app.activeDocument.pathItems[app.activeDocument.pathItems.length - 2];
              return myPathItem
              // from »Flatten All Masks.jsx« by jeffrey tranberry;
              // Function: hasVectorMask
              // Usage: see if there is a vector layer mask
              // Input: <none> Must have an open document
              // Return: true if there is a vector mask
              function hasVectorMask() {
                var hasVectorMask = false;
                try {
                var keyVectorMaskEnabled = app.stringIDToTypeID( 'vectorMask' );
                var keyKind = app.charIDToTypeID( 'Knd ' );
                ref.putEnumerated( app.charIDToTypeID( 'Path' ), app.charIDToTypeID( 'Ordn' ), keyVectorMaskEnabled );
                var desc = executeActionGet( ref );
                if ( desc.hasKey( keyKind ) ) {
                var kindValue = desc.getEnumerationValue( keyKind );
                if (kindValue == keyVectorMaskEnabled) {
                hasVectorMask = true;
                }catch(e) {
                return hasVectorMask;
              • 4. Re: Can scripting do path editing?
                the05 Level 1
                Hey C.pfaffenbichler. Thanks very much for you sharing!
                Your code works on PS CC 2014 (32-bit) but fails on PS CC 2014 (64-bit).
                Anyway, I believe it's helpful to solve my problem. My programing skill is poor and can't understand your code very well now. I'll get back to this after I improve my Javascript knowledge.
                • 5. Re: Can scripting do path editing?
                  What exact error does it produce in CC 2014?
                  For me it works (20140508.r.58 x64 on Mac OS 10.8.5) but there may well be some shortcoming I have overlooked …
