• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Cannot install latest version (.176)
Community Beginner ,
Aug 13, 2014 Aug 13, 2014
Platform is OS X 10.9.4. Download is fine. Installer hangs asking to close applications (Dashboard Client and Safari). Both closed using the activity monitor. Window appears requiring Safari be closed. IT IS CLOSED! This becomes a closed loop.
Views
633
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Aug 16, 2014 Aug 16, 2014
Since no bright ideas appeared as a result of the log file, I decided to use the Flash Player uninstaller and remove the installed version from my system. I did that and then downloaded the latest flash player version from the Adobe web site.
The new version installed "normally."
Barry
Votes
Translate
Translate
Adobe Employee ,
Hello,
Once all apps that use Flash Player are closed, installation should complete.  Can you please provide the FlashPlayerInstallManager.log file located at ~/Library/Logs (this is the user's Library not the system Library).  The file will most likely be fairly large, as such, please follow the instructions at How to share a document to share the log file.
Thank you.
Maria
Votes
Translate
Translate
Report
Report
That link is completely confusing.
I have attached the log file to this return E-mail.
Barry Hemphill
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
I would appreciate if you'd explain what exactly is confusing (or unclear) in the instructions I provided in https://forums.adobe.com/thread/1408375
I can make it more clear if you tell me what's wrong with it.
Votes
Translate
Translate
Report
Report
Barry Hemphill
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi Barry,
Attachments to forums emails will be deleted.  The other alternative is to post the contents of the log file here in your post.
Maria
Votes
Translate
Translate
Report
Report
https://files.acrobat.com/preview/...
2011-03-08 07:04:00 -0600 ---------- log start ----------
2011-03-08 07:04:00 -0600 All install checks pass
2011-03-08 07:04:10 -0600 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-03-08 07:04:24 -0600 [install started]
2011-03-08 07:04:26.330 installer[5540:3007] PackageKit: *** Missing bundle identifier: /Library/Receipts/Flip4Mac QuickTime Components.pkg
2011-03-08 07:04:26.334 installer[5540:3007] PackageKit: *** Missing bundle identifier: /Library/Receipts/Flip4Mac Web Plugins.pkg
installer: Package name is PlugIn
installer: Upgrading at base path /
installer: The upgrade was successful.
2011-03-08 07:04:31 -0600 [install completed]
2011-03-08 07:04:31 -0600 [install succeeded]
2011-03-08 07:04:36 -0600 ----------  log end  ----------
2011-06-01 06:03:55 -0500 ---------- log start ----------
2011-06-01 06:04:01 -0500 ----------  log end  ----------
2011-06-13 05:58:51 -0500 ---------- log start ----------
2011-06-13 05:58:56 -0500 ----------  log end  ----------
2011-06-14 14:43:40 -0500 ---------- log start ----------
2011-06-14 14:43:40 -0500 All install checks pass
2011-06-14 14:44:39 -0500 User has 2 processes that need to be closed before the Flash Player can be installed.
2011-06-14 14:44:56 -0500 [install started]
2011-06-14 14:44:56.997 installer[2628:3007] PackageKit: *** Missing bundle identifier: /Library/Receipts/Flip4Mac QuickTime Components.pkg
2011-06-14 14:44:57.000 installer[2628:3007] PackageKit: *** Missing bundle identifier: /Library/Receipts/Flip4Mac Web Plugins.pkg
2011-06-14 14:45:02 -0500 [install completed]
2011-06-14 14:45:02 -0500 [install succeeded]
2011-06-14 14:45:07 -0500 ----------  log end  ----------
2011-07-22 04:17:10 +0000 ---------- log start ----------
2011-07-22 04:17:15 +0000 ----------  log end  ----------
2011-07-22 04:17:57 +0000 ---------- log start ----------
2011-07-22 04:18:00 +0000 ----------  log end  ----------
2011-07-22 04:19:56 +0000 ---------- log start ----------
2011-07-22 04:20:01 +0000 All install checks pass
2011-07-22 04:21:23 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-07-22 04:21:33 +0000 [install started]
2011-07-22 04:21:39 +0000 [install completed]
2011-07-22 04:21:39 +0000 [install succeeded]
2011-07-22 04:21:43 +0000 ----------  log end  ----------
2011-08-09 20:11:03 +0000 ---------- log start ----------
2011-08-09 20:11:06 +0000 ----------  log end  ----------
2011-08-09 20:31:39 +0000 ---------- log start ----------
2011-08-09 20:31:39 +0000 All install checks pass
2011-08-09 20:31:50 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-08-09 20:32:00 +0000 [install started]
2011-08-09 20:32:06 +0000 [install completed]
2011-08-09 20:32:06 +0000 [install succeeded]
2011-08-09 20:32:11 +0000 ----------  log end  ----------
2011-09-22 15:11:50 +0000 ---------- log start ----------
2011-09-22 15:11:50 +0000 All install checks pass
2011-09-22 15:12:02 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2011-09-22 15:12:02 +0000 [install started]
2011-09-22 15:12:08 +0000 [install completed]
2011-09-22 15:12:08 +0000 [install succeeded]
2011-09-22 15:12:12 +0000 ----------  log end  ----------
2011-10-01 12:07:35 +0000 ---------- log start ----------
2011-10-01 12:07:38 +0000 ----------  log end  ----------
2011-10-11 10:42:09 +0000 ---------- log start ----------
2011-10-11 10:42:09 +0000 All install checks pass
2011-10-11 10:42:20 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-10-11 10:42:31 +0000 [install started]
2011-10-11 10:42:37 +0000 [install completed]
2011-10-11 10:42:37 +0000 [install succeeded]
2011-10-11 10:42:42 +0000 ----------  log end  ----------
2011-11-12 14:17:46 +0000 ---------- log start ----------
2011-11-12 14:17:47 +0000 1568
2011-11-12 14:18:17 +0000 14777601
2011-11-12 14:18:18 +0000 verifySignatureWithData : Message Verified!
2011-11-12 14:18:23 +0000 ----------  log end  ----------
2011-11-12 14:18:29 +0000 ---------- log start ----------
2011-11-12 14:18:29 +0000 All install checks pass
2011-11-12 14:18:40 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-11-12 14:18:50 +0000 [install started]
2011-11-12 14:18:56 +0000 [install completed]
2011-11-12 14:18:56 +0000 [install succeeded]
2011-11-12 14:19:02 +0000 ----------  log end  ----------
2012-02-22 11:46:01 +0000 ---------- log start ----------
2012-02-22 11:46:02 +0000 1568
2012-02-22 11:46:29 +0000 14782799
2012-02-22 11:46:30 +0000 verifySignatureWithData : Message Verified!
2012-02-22 11:46:35 +0000 ----------  log end  ----------
2012-02-22 11:48:39 +0000 ---------- log start ----------
2012-02-22 11:48:39 +0000 All install checks pass
2012-02-22 11:50:16 +0000 ----------  log end  ----------
2012-02-29 14:34:44 +0000 ---------- log start ----------
2012-02-29 14:34:44 +0000 1568
2012-02-29 14:35:09 +0000 14782799
2012-02-29 14:35:09 +0000 verifySignatureWithData : Message Verified!
2012-02-29 14:35:15 +0000 ----------  log end  ----------
2012-02-29 14:35:17 +0000 ---------- log start ----------
2012-02-29 14:35:17 +0000 All install checks pass
2012-02-29 14:36:10 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-02-29 14:36:21 +0000 [install started]
2012-02-29 14:36:27 +0000 [install completed]
2012-02-29 14:36:27 +0000 [install succeeded]
2012-02-29 14:36:31 +0000 ----------  log end  ----------
2012-03-08 15:26:57 +0000 ---------- log start ----------
2012-03-08 15:27:00 +0000 ----------  log end  ----------
2012-03-08 15:28:24 +0000 ---------- log start ----------
2012-03-08 15:28:24 +0000 All install checks pass
2012-03-08 15:28:47 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-03-08 15:28:57 +0000 [install started]
2012-03-08 15:29:03 +0000 [install completed]
2012-03-08 15:29:03 +0000 [install succeeded]
2012-03-08 15:29:08 +0000 ----------  log end  ----------
2012-03-08 15:30:41 +0000 ---------- log start ----------
2012-03-08 15:30:41 +0000 All install checks pass
2012-03-08 15:30:50 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-03-08 15:30:50 +0000 [install started]
2012-03-08 15:30:55 +0000 [install completed]
2012-03-08 15:30:55 +0000 [install succeeded]
2012-03-08 15:30:59 +0000 ----------  log end  ----------
2012-03-29 15:14:30 +0000 ---------- log start ----------
2012-03-29 15:14:31 +0000 1583
2012-03-29 21:02:03 +0000 11211713
2012-03-29 21:02:03 +0000 verifySignatureWithData : Message Verified!
2012-03-29 21:02:08 +0000 ----------  log end  ----------
2012-03-29 21:02:13 +0000 ---------- log start ----------
2012-03-29 21:02:13 +0000 All install checks pass
2012-03-29 21:04:02 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-03-29 21:04:02 +0000 [install started]
2012-03-29 21:04:10 +0000 [install completed]
2012-03-29 21:04:10 +0000 [install succeeded]
2012-03-29 21:04:15 +0000 ----------  log end  ----------
2012-04-15 23:00:31 +0000 ---------- log start ----------
2012-04-15 23:00:32 +0000 1583
2012-04-15 23:01:21 +0000 11211575
2012-04-15 23:01:21 +0000 verifySignatureWithData : Message Verified!
2012-04-15 23:01:26 +0000 ----------  log end  ----------
2012-04-15 23:01:30 +0000 ---------- log start ----------
2012-04-15 23:01:30 +0000 All install checks pass
2012-04-15 23:01:41 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-04-15 23:01:41 +0000 [install started]
2012-04-15 23:01:48 +0000 [install completed]
2012-04-15 23:01:48 +0000 [install succeeded]
2012-04-15 23:01:52 +0000 ----------  log end  ----------
2012-05-08 10:15:13 +0000 ---------- log start ----------
2012-05-08 10:15:15 +0000 1583
2012-05-08 10:15:37 +0000 11210280
2012-05-08 10:15:37 +0000 verifySignatureWithData : Message Verified!
2012-05-08 10:15:43 +0000 ----------  log end  ----------
2012-05-08 10:16:42 +0000 ---------- log start ----------
2012-05-08 10:16:42 +0000 All install checks pass
2012-05-08 10:16:52 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-05-08 10:17:05 +0000 [install started]
2012-05-08 10:17:11 +0000 [install completed]
2012-05-08 10:17:11 +0000 [install succeeded]
2012-05-08 10:17:16 +0000 ----------  log end  ----------
2012-06-09 10:36:16 +0000 ---------- log start ----------
2012-06-09 10:36:16 +0000 1106
2012-06-09 10:36:38 +0000 11580012
2012-06-09 10:36:38 +0000 verifySignatureWithData : Message Verified!
2012-06-09 10:36:43 +0000 ----------  log end  ----------
2012-06-09 10:36:46 +0000 ---------- log start ----------
2012-06-09 10:36:46 +0000 All install checks pass
2012-06-09 10:37:10 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-06-09 10:37:20 +0000 [install started]
sudo: no tty present and no askpass program specified
2012-06-09 10:37:27 +0000 [install completed]
2012-06-09 10:37:27 +0000 [install succeeded]
2012-06-09 10:37:41 +0000 ----------  log end  ----------
2012-06-09 10:37:41 +0000 Changing update mode to 1
2012-07-02 09:28:09 +0000 ---------- log start ----------
2012-07-02 09:28:09 +0000 All install checks pass
2012-07-02 09:28:23 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-07-02 09:28:23 +0000 [install started]
2012-07-02 09:28:35 +0000 [install completed]
2012-07-02 09:28:35 +0000 [install succeeded]
2012-07-02 09:29:34 +0000 ----------  log end  ----------
2012-07-02 09:29:34 +0000 Changing update mode to 1
2012-07-12 03:48:36 +0000 ---------- log start ----------
2012-07-12 03:48:36 +0000 664
2012-07-12 03:49:06 +0000 11582449
2012-07-12 03:49:06 +0000 verifySignatureWithData : Message Verified!
2012-07-12 03:49:11 +0000 ----------  log end  ----------
2012-07-12 03:49:14 +0000 ---------- log start ----------
2012-07-12 03:49:14 +0000 All install checks pass
2012-07-12 03:49:24 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-07-12 03:49:37 +0000 [install started]
2012-07-12 03:49:43 +0000 [install completed]
2012-07-12 03:49:43 +0000 [install succeeded]
2012-07-12 03:49:53 +0000 ----------  log end  ----------
2012-07-12 03:49:52 +0000 Changing update mode to 1
2012-07-19 20:21:04 +0000 ---------- log start ----------
2012-07-19 20:21:09 +0000 ----------  log end  ----------
2012-07-26 20:38:45 +0000 ---------- log start ----------
2012-07-26 20:38:45 +0000 All install checks pass
2012-07-26 20:38:56 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-07-26 20:39:07 +0000 [install started]
dyld: DYLD_ environment variables being ignored because main executable (/System/Library/PrivateFrameworks/Install.framework/Resources/runner) is setuid or setgid
2012-07-26 20:39:15 +0000 [install completed]
2012-07-26 20:39:15 +0000 [install succeeded]
2012-07-26 20:39:23 +0000 ----------  log end  ----------
2012-07-26 20:39:23 +0000 Changing update mode to 1
2012-08-14 20:59:16 +0000 ---------- log start ----------
2012-08-14 20:59:16 +0000 664
2012-08-14 21:01:27 +0000 11583286
2012-08-14 21:01:27 +0000 verifySignatureWithData : Message Verified!
2012-08-14 21:01:32 +0000 ----------  log end  ----------
2012-08-14 21:01:36 +0000 ---------- log start ----------
2012-08-14 21:01:36 +0000 All install checks pass
2012-08-14 21:01:45 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-08-14 21:01:45 +0000 [install started]
dyld: DYLD_ environment variables being ignored because main executable (/var/folders/f2/btr7v9yw8xj79f0059blnwmh0000gn/T/FPInstallHelper) is setuid or setgid
2012-08-14 21:01:51 +0000 [install completed]
2012-08-14 21:01:51 +0000 [install succeeded]
2012-08-14 21:02:03 +0000 ----------  log end  ----------
2012-08-14 21:02:03 +0000 Changing update mode to 1
2012-08-22 10:38:11 +0000 ---------- log start ----------
2012-08-22 10:38:11 +0000 602
2012-08-22 11:20:04 +0000 11861772
2012-08-22 11:20:04 +0000 verifySignatureWithData : Message Verified!
2012-08-22 11:20:09 +0000 ----------  log end  ----------
2012-08-22 11:20:13 +0000 ---------- log start ----------
2012-08-22 11:20:13 +0000 All install checks pass
2012-08-22 11:20:27 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-08-22 11:20:27 +0000 [install started]
2012-08-22 11:20:34 +0000 [install completed]
2012-08-22 11:20:34 +0000 [install succeeded]
2012-08-22 11:20:41 +0000 ----------  log end  ----------
2012-08-22 11:20:41 +0000 Changing update mode to 1
2012-09-12 19:29:39 +0000 ---------- log start ----------
2012-09-12 19:29:43 +0000 ----------  log end  ----------
2012-10-10 09:46:41 +0000 ---------- log start ----------
2012-10-10 09:46:41 +0000 602
2012-10-10 09:47:06 +0000 11866905
2012-10-10 09:47:06 +0000 verifySignatureWithData : Message Verified!
2012-10-10 09:47:11 +0000 ----------  log end  ----------
2012-10-10 09:47:18 +0000 ---------- log start ----------
2012-10-10 09:47:18 +0000 All install checks pass
2012-10-10 09:47:29 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-10-10 09:47:41 +0000 [install started]
2012-10-10 09:47:48 +0000 [install completed]
2012-10-10 09:47:48 +0000 [install succeeded]
2012-10-10 09:47:59 +0000 ----------  log end  ----------
2012-10-10 09:47:58 +0000 Changing update mode to 1
2012-11-13 21:54:40 +0000 ---------- log start ----------
2012-11-13 21:54:40 +0000 580
2012-11-13 21:55:11 +0000 16875066
2012-11-13 21:55:11 +0000 verifySignatureWithData : Message Verified!
2012-11-13 21:55:16 +0000 ----------  log end  ----------
2012-11-13 21:55:23 +0000 ---------- log start ----------
2012-11-13 21:55:23 +0000 All install checks pass
2012-11-13 21:55:33 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-11-13 21:55:43 +0000 [install started]
2012-11-13 21:55:54 +0000 [install completed]
2012-11-13 21:55:54 +0000 [install succeeded]
2012-11-13 21:55:57 +0000 ----------  log end  ----------
2012-11-13 21:55:57 +0000 Changing update mode to 0
2013-01-03 10:23:53 +0000 ---------- log start ----------
2013-01-03 10:23:53 +0000 580
2013-01-03 10:24:07 +0000 ---------- log start ----------
2013-01-03 10:24:07 +0000 Changing update mode to 1
2013-01-10 22:40:24 +0000 ---------- log start ----------
2013-01-10 22:40:25 +0000 580
2013-01-10 22:41:17 +0000 16879485
2013-01-10 22:41:17 +0000 verifySignatureWithData : Message Verified!
2013-01-10 22:41:23 +0000 ----------  log end  ----------
2013-01-10 22:41:27 +0000 ---------- log start ----------
2013-01-10 22:41:27 +0000 All install checks pass
2013-01-10 22:41:38 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-01-10 22:41:38 +0000 [install started]
2013-01-10 22:41:49 +0000 [install completed]
2013-01-10 22:41:49 +0000 [install succeeded]
2013-01-10 22:41:53 +0000 ----------  log end  ----------
2013-01-10 22:41:53 +0000 Changing update mode to 0
2013-01-26 03:17:16 +0000 ---------- log start ----------
2013-01-26 03:17:16 +0000 Changing update mode to 1
2013-01-26 03:17:20 +0000 ---------- log start ----------
2013-01-26 03:17:22 +0000 580
2013-02-08 16:37:13 +0000 ---------- log start ----------
2013-02-08 16:37:14 +0000 [install started]
2013-02-08 16:37:25 +0000 [install completed]
2013-02-08 16:37:27 +0000 ----------  log end  ----------
2013-02-08 16:37:27 +0000 Changing update mode to 1
2013-02-11 20:36:30 +0000 ---------- log start ----------
2013-02-11 20:36:32 +0000 [install started]
2013-02-11 20:36:45 +0000 [install completed]
2013-02-11 20:36:47 +0000 ----------  log end  ----------
2013-02-11 20:36:47 +0000 Changing update mode to 1
2013-02-20 02:33:29 +0000 ---------- log start ----------
2013-02-20 02:33:30 +0000 1214
2013-02-20 02:33:31 +0000 1214
2013-02-20 02:34:47 +0000 16931999
2013-02-20 02:34:48 +0000 verifySignatureWithData : Message Verified!
2013-02-20 02:34:53 +0000 ----------  log end  ----------
2013-02-20 02:35:02 +0000 ---------- log start ----------
2013-02-20 02:35:02 +0000 All install checks pass
2013-02-20 02:35:14 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-02-20 02:35:25 +0000 [install started]
2013-02-20 02:35:36 +0000 [install completed]
2013-02-20 02:35:36 +0000 [install succeeded]
2013-02-20 02:35:40 +0000 ----------  log end  ----------
2013-02-20 02:35:40 +0000 Changing update mode to 0
2013-02-27 02:36:40 +0000 ---------- log start ----------
2013-02-27 02:36:41 +0000 1214
2013-02-27 02:37:37 +0000 16931542
2013-02-27 02:37:37 +0000 verifySignatureWithData : Message Verified!
2013-02-27 02:37:42 +0000 ----------  log end  ----------
2013-02-27 02:37:46 +0000 ---------- log start ----------
2013-02-27 02:37:46 +0000 All install checks pass
2013-02-27 02:37:57 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-02-27 02:38:08 +0000 [install started]
2013-02-27 02:38:21 +0000 [install completed]
2013-02-27 02:38:21 +0000 [install succeeded]
2013-02-27 02:38:25 +0000 ----------  log end  ----------
2013-02-27 02:38:25 +0000 Changing update mode to 0
2013-04-10 19:35:56 +0000 ---------- log start ----------
2013-04-10 19:35:56 +0000 1214
2013-04-10 19:36:01 +0000 ----------  log end  ----------
2013-04-10 19:37:07 +0000 ---------- log start ----------
2013-04-10 19:37:07 +0000 All install checks pass
2013-04-10 19:37:09 +0000 ----------  log end  ----------
2013-04-10 19:37:31 +0000 ---------- log start ----------
2013-04-10 19:37:31 +0000 All install checks pass
2013-04-10 19:37:33 +0000 [install started]
2013-04-10 19:37:46 +0000 [install completed]
2013-04-10 19:37:48 +0000 ----------  log end  ----------
2013-05-16 09:37:10 +0000 ---------- log start ----------
2013-05-16 09:37:10 +0000 1214
2013-05-16 09:37:41 +0000 18007571
2013-05-16 09:37:42 +0000 verifySignatureWithData : Message Verified!
2013-05-16 09:37:47 +0000 ----------  log end  ----------
2013-05-16 09:37:51 +0000 ---------- log start ----------
2013-05-16 09:37:51 +0000 All install checks pass
2013-05-16 09:38:16 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-05-16 09:38:29 +0000 ----------  log end  ----------
2013-05-16 09:40:48 +0000 ---------- log start ----------
2013-05-16 09:40:48 +0000 All install checks pass
2013-05-16 09:40:49 +0000 ----------  log end  ----------
2013-05-16 09:41:09 +0000 ---------- log start ----------
2013-05-16 09:41:09 +0000 All install checks pass
2013-05-16 09:41:10 +0000 [install started]
2013-05-16 09:41:21 +0000 [install succeeded]
2013-05-16 09:41:23 +0000 ----------  log end  ----------
2013-06-08 04:06:37 +0000 ---------- log start ----------
2013-06-08 04:06:41 +0000 ----------  log end  ----------
2013-06-14 12:16:18 +0000 ---------- log start ----------
2013-06-14 12:16:18 +0000 Changing update mode to 1
2013-06-14 12:16:23 +0000 ---------- log start ----------
2013-06-14 12:16:23 +0000 1214
2013-06-26 14:24:10 +0000 ---------- log start ----------
2013-06-26 14:24:10 +0000 1214
2013-07-21 21:58:52 +0000 ---------- log start ----------
2013-07-21 21:58:52 +0000 1213
2013-07-21 21:58:58 +0000 ----------  log end  ----------
2013-07-21 22:00:24 +0000 ---------- log start ----------
2013-07-21 22:00:24 +0000 All install checks pass
2013-07-21 22:00:26 +0000 ----------  log end  ----------
2013-07-21 22:01:12 +0000 ---------- log start ----------
2013-07-21 22:01:12 +0000 All install checks pass
2013-07-21 22:01:13 +0000 ----------  log end  ----------
2013-07-21 22:03:48 +0000 ---------- log start ----------
2013-07-21 22:03:48 +0000 All install checks pass
2013-07-21 22:03:50 +0000 ----------  log end  ----------
2013-07-21 22:04:46 +0000 ---------- log start ----------
2013-07-21 22:04:46 +0000 All install checks pass
2013-07-21 22:04:47 +0000 ----------  log end  ----------
2013-07-21 22:05:17 +0000 ---------- log start ----------
2013-07-21 22:05:17 +0000 All install checks pass
2013-07-21 22:05:18 +0000 ----------  log end  ----------
2013-07-21 22:07:47 +0000 ---------- log start ----------
2013-07-21 22:07:47 +0000 All install checks pass
2013-07-21 22:07:49 +0000 ----------  log end  ----------
2013-07-21 22:12:25 +0000 ---------- log start ----------
2013-07-21 22:12:25 +0000 All install checks pass
2013-07-21 22:12:26 +0000 ----------  log end  ----------
2013-07-29 15:39:28 +0000 ---------- log start ----------
2013-07-29 15:39:28 +0000 1213
2013-07-29 15:39:29 +0000 1213
2013-07-29 15:39:34 +0000 ----------  log end  ----------
2013-07-29 15:40:47 +0000 ---------- log start ----------
2013-07-29 15:40:47 +0000 All install checks pass
2013-07-29 15:40:48 +0000 ----------  log end  ----------
2013-07-29 15:41:11 +0000 ---------- log start ----------
2013-07-29 15:41:11 +0000 All install checks pass
2013-07-29 15:41:11 +0000 [install started]
2013-07-29 15:41:22 +0000 [install succeeded]
2013-07-29 15:41:24 +0000 ----------  log end  ----------
2013-07-29 15:41:24 +0000 Changing update mode to 1
2013-08-13 13:21:40 +0000 ---------- log start ----------
2013-08-13 13:21:40 +0000 1213
2013-09-11 11:02:39 +0000 ---------- log start ----------
2013-09-11 11:02:39 +0000 1214
2013-09-11 11:02:40 +0000 1214
2013-09-11 11:03:04 +0000 18133029
2013-09-11 11:03:04 +0000 verifySignatureWithData : Message Verified!
2013-09-11 11:03:09 +0000 ----------  log end  ----------
2013-09-11 11:03:15 +0000 ---------- log start ----------
2013-09-11 11:03:15 +0000 All install checks pass
2013-09-11 11:03:28 +0000 User has 2 processes that need to be closed before the Flash Player can be installed.
2013-09-11 11:03:42 +0000 [install started]
2013-09-11 11:03:48 +0000 [install completed]
2013-09-11 11:03:48 +0000 [install succeeded]
2013-09-11 11:03:55 +0000 ----------  log end  ----------
2013-09-11 11:03:55 +0000 Changing update mode to 1
2013-09-19 13:02:45 +0000 ---------- log start ----------
2013-09-19 13:02:52 +0000 ----------  log end  ----------
2013-10-09 13:15:14 +0000 ---------- log start ----------
2013-10-09 13:15:15 +0000 1389
2013-10-09 13:15:39 +0000 18408578
2013-10-09 13:15:39 +0000 verifySignatureWithData : Message Verified!
2013-10-09 13:15:44 +0000 ----------  log end  ----------
2013-10-09 13:15:49 +0000 ---------- log start ----------
2013-10-09 13:15:49 +0000 All install checks pass
2013-10-09 13:16:00 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-10-09 13:16:10 +0000 [install started]
installer: Package name is Adobe Flash Player
2013-10-09 13:16:21 +0000 [install completed]
2013-10-09 13:16:21 +0000 [install succeeded]
2013-10-09 13:16:28 +0000 ----------  log end  ----------
2013-10-09 13:16:28 +0000 Changing update mode to 1
2013-11-13 14:32:22 +0000 ---------- log start ----------
2013-11-13 14:32:22 +0000 1389
2013-11-13 14:32:23 +0000 1389
2013-11-13 14:32:29 +0000 ----------  log end  ----------
2013-11-13 14:34:19 +0000 ---------- log start ----------
2013-11-13 14:34:19 +0000 All install checks pass
2013-11-13 14:34:20 +0000 [install started]
2013-11-13 14:34:32 +0000 [install succeeded]
2013-11-13 14:34:32 +0000 ----------  log end  ----------
2013-11-13 14:34:32 +0000 Changing update mode to 1
2013-12-17 12:29:04 +0000 ---------- log start ----------
2013-12-17 12:29:04 +0000 1389
2013-12-17 12:29:29 +0000 18417494
2013-12-17 12:29:29 +0000 verifySignatureWithData : Message Verified!
2013-12-17 12:29:34 +0000 ----------  log end  ----------
2013-12-17 12:29:38 +0000 ---------- log start ----------
2013-12-17 12:29:38 +0000 All install checks pass
2013-12-17 12:29:52 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-12-17 12:30:04 +0000 [install started]
2013-12-17 12:30:15 +0000 [install completed]
2013-12-17 12:30:15 +0000 [install succeeded]
2013-12-17 12:30:27 +0000 ----------  log end  ----------
2013-12-17 12:30:27 +0000 Changing update mode to 1
2014-01-12 15:14:05 +0000 ---------- log start ----------
2014-01-12 15:14:05 +0000 1389
2014-01-13 15:00:51 +0000 ---------- log start ----------
2014-01-13 15:00:51 +0000 1389
2014-01-19 13:01:29 +0000 ---------- log start ----------
2014-01-19 13:01:29 +0000 1386
2014-01-19 13:01:33 +0000 ---------- log start ----------
2014-01-19 13:01:34 +0000 1386
2014-01-19 13:01:41 +0000 ----------  log end  ----------
2014-01-19 05:03:44 -0800   IM: ---------- log start ----------
2014-01-19 05:03:44 -0800   IM: All install checks pass
2014-01-19 05:03:44 -0800   IM: Unexpected umask value for process: 0
2014-01-19 05:03:46 -0800   IM: User does not have any processes that need to be closed.
2014-01-19 05:03:46 -0800   IM: [install started]
2014-01-19 05:03:49 -0800 FIN: [finalizer started]
2014-01-19 05:03:49 -0800 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-01-19 05:03:49 -0800 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-01-19 05:03:52 -0800 FIN: [finalizer succeeded]
2014-01-19 05:03:57 -0800   IM: [install succeeded]
2014-01-19 05:03:57 -0800   IM: ----------  log end  ----------
2014-02-05 07:02:49 -0800   IM: ---------- log start ----------
2014-02-05 07:02:49 -0800   IM: 1386
2014-02-05 07:02:51 -0800   IM: ---------- log start ----------
2014-02-05 07:02:51 -0800   IM: 1386
2014-02-05 07:03:17 -0800   IM: 18450331
2014-02-05 07:03:17 -0800   IM: verifySignatureWithData : Message Verified!
2014-02-05 07:03:21 -0800   IM: ----------  log end  ----------
2014-02-05 07:03:21 -0800   IM: ---------- log start ----------
2014-02-05 07:03:21 -0800   IM: All install checks pass
2014-02-05 07:03:33 -0800   IM: User has 2 processes that need to be closed before the Flash Player can be installed.
2014-02-05 07:03:44 -0800   IM: [install started]
2014-02-05 07:03:46 -0800 FIN: [finalizer started]
2014-02-05 07:03:46 -0800 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-05 07:03:46 -0800 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-05 07:03:48 -0800 FIN: [finalizer succeeded]
2014-02-05 07:03:55 -0800   IM: [install completed]
2014-02-05 07:03:55 -0800   IM: [install succeeded]
2014-02-05 07:03:58 -0800   IM: ----------  log end  ----------
2014-02-21 12:23:10 -0800   IM: ---------- log start ----------
2014-02-21 12:23:10 -0800   IM: All install checks pass
2014-02-21 12:23:10 -0800   IM: [install started]
2014-02-21 12:23:13 -0800 FIN: [finalizer started]
2014-02-21 12:23:13 -0800 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-21 12:23:13 -0800 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-21 12:23:15 -0800 FIN: Unable to create directory '(null)'.
2014-02-21 12:23:15 -0800 FIN: [finalizer failed]
2014-02-21 12:23:21 -0800   IM: [install succeeded]
2014-02-21 12:23:21 -0800   IM: ----------  log end  ----------
2014-03-02 06:36:55 -0800   IM: ---------- log start ----------
2014-03-02 06:36:55 -0800   IM: 1386
2014-03-17 04:52:01 -0700   IM: ---------- log start ----------
2014-03-17 04:52:01 -0700   IM: 1386
2014-03-17 04:52:26 -0700   IM: 18419293
2014-03-17 04:52:26 -0700   IM: verifySignatureWithData : Message Verified!
2014-03-17 04:52:31 -0700   IM: ----------  log end  ----------
2014-03-17 04:52:36 -0700   IM: ---------- log start ----------
2014-03-17 04:52:36 -0700   IM: All install checks pass
2014-03-17 04:52:52 -0700   IM: User has 1 process that needs to be closed before the Flash Player can be installed.
2014-03-17 04:52:59 -0700   IM: [install started]
2014-03-17 04:53:01 -0700 FIN: [finalizer started]
2014-03-17 04:53:01 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-03-17 04:53:01 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-03-17 04:53:03 -0700 FIN: [finalizer succeeded]
2014-03-17 04:53:10 -0700   IM: [install completed]
2014-03-17 04:53:10 -0700   IM: [install succeeded]
2014-03-17 04:53:13 -0700   IM: ----------  log end  ----------
2014-03-20 07:17:45 -0700   IM: ---------- log start ----------
2014-03-20 07:17:46 -0700   IM: 1386
2014-04-08 14:46:03 -0700   IM: ---------- log start ----------
2014-04-08 14:46:03 -0700   IM: 1387
2014-04-08 14:46:04 -0700   IM: 1387
2014-04-08 14:49:34 -0700   IM: ----------  log end  ----------
2014-04-08 14:51:16 -0700   IM: ---------- log start ----------
2014-04-08 14:51:16 -0700   IM: All install checks pass
2014-04-08 14:51:16 -0700   IM: Unexpected umask value for process: 0
2014-04-08 14:51:17 -0700   IM: User does not have any processes that need to be closed.
2014-04-08 14:51:17 -0700   IM: [install started]
2014-04-08 14:51:21 -0700 FIN: [finalizer started]
2014-04-08 14:51:21 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-08 14:51:21 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-08 14:51:23 -0700 FIN: [finalizer succeeded]
2014-04-08 14:51:29 -0700   IM: [install succeeded]
2014-04-08 14:51:29 -0700   IM: ----------  log end  ----------
2014-04-22 15:31:42 -0700   IM: ---------- log start ----------
2014-04-22 15:31:43 -0700   IM: 1387
2014-04-22 15:32:04 -0700   IM: 15721099
2014-04-22 15:32:04 -0700   IM: verifySignatureWithData : Message Verified!
2014-04-22 15:32:09 -0700   IM: ----------  log end  ----------
2014-04-22 15:32:13 -0700   IM: ---------- log start ----------
2014-04-22 15:32:13 -0700   IM: All install checks pass
2014-04-22 15:32:36 -0700   IM: User has 2 processes that need to be closed before the Flash Player can be installed.
2014-04-22 15:32:46 -0700   IM: ----------  log end  ----------
2014-04-22 15:35:51 -0700   IM: ---------- log start ----------
2014-04-22 15:35:52 -0700   IM: 1387
2014-04-22 15:35:55 -0700   IM: ---------- log start ----------
2014-04-22 15:35:55 -0700   IM: 1387
2014-04-22 15:36:15 -0700   IM: 15721099
2014-04-22 15:36:15 -0700   IM: verifySignatureWithData : Message Verified!
2014-04-22 15:36:19 -0700   IM: ----------  log end  ----------
2014-04-22 15:36:19 -0700   IM: ---------- log start ----------
2014-04-22 15:36:19 -0700   IM: All install checks pass
2014-04-22 15:36:28 -0700   IM: User has 2 processes that need to be closed before the Flash Player can be installed.
2014-04-22 15:36:39 -0700   IM: [install started]
2014-04-22 15:36:41 -0700 FIN: [finalizer started]
2014-04-22 15:36:41 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-22 15:36:41 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-22 15:36:43 -0700 FIN: [finalizer succeeded]
2014-04-22 15:36:50 -0700   IM: [install completed]
2014-04-22 15:36:50 -0700   IM: [install succeeded]
2014-04-22 15:37:13 -0700   IM: ----------  log end  ----------
2014-04-29 15:39:28 -0700   IM: ---------- log start ----------
2014-04-29 15:39:29 -0700   IM: 1387
2014-04-29 15:39:51 -0700   IM: 15715106
2014-04-29 15:39:51 -0700   IM: verifySignatureWithData : Message Verified!
2014-04-29 15:39:56 -0700   IM: ----------  log end  ----------
2014-04-29 15:39:59 -0700   IM: ---------- log start ----------
2014-04-29 15:39:59 -0700   IM: All install checks pass
2014-04-29 15:40:10 -0700   IM: User has 2 processes that need to be closed before the Flash Player can be installed.
2014-04-29 15:40:14 -0700   IM: ----------  log end  ----------
2014-04-29 15:41:15 -0700   IM: ---------- log start ----------
2014-04-29 15:41:15 -0700   IM: 1387
2014-04-29 15:41:18 -0700   IM: ---------- log start ----------
2014-04-29 15:41:18 -0700   IM: 1387
2014-04-29 15:41:42 -0700   IM: 15715106
2014-04-29 15:41:42 -0700   IM: verifySignatureWithData : Message Verified!
2014-04-29 15:41:46 -0700   IM: ----------  log end  ----------
2014-04-29 15:41:46 -0700   IM: ---------- log start ----------
2014-04-29 15:41:46 -0700   IM: All install checks pass
2014-04-29 15:41:56 -0700   IM: User has 2 processes that need to be closed before the Flash Player can be installed.
2014-04-29 15:42:09 -0700   IM: [install started]
2014-04-29 15:42:12 -0700 FIN: [finalizer started]
2014-04-29 15:42:12 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-29 15:42:12 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-29 15:42:13 -0700 FIN: [finalizer succeeded]
2014-04-29 15:42:20 -0700   IM: [install completed]
2014-04-29 15:42:20 -0700   IM: [install succeeded]
2014-04-29 15:42:27 -0700   IM: ----------  log end  ----------
2014-05-16 05:35:32 -0700   IM: ---------- log start ----------
2014-05-16 05:35:32 -0700   IM: 1387
2014-05-16 05:35:38 -0700   IM: ---------- log start ----------
2014-05-16 05:35:38 -0700   IM: 1387
2014-05-16 05:36:03 -0700   IM: 15723551
2014-05-16 05:36:03 -0700   IM: verifySignatureWithData : Message Verified!
2014-05-16 05:36:07 -0700   IM: ----------  log end  ----------
2014-05-16 05:36:07 -0700   IM: ---------- log start ----------
2014-05-16 05:36:07 -0700   IM: All install checks pass
2014-05-16 05:36:18 -0700   IM: User has 1 process that needs to be closed before the Flash Player can be installed.
2014-05-16 05:36:30 -0700   IM: [install started]
2014-05-16 05:36:32 -0700 FIN: [finalizer started]
2014-05-16 05:36:32 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-05-16 05:36:32 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-05-16 05:36:34 -0700 FIN: [finalizer succeeded]
2014-05-16 05:36:41 -0700   IM: [install completed]
2014-05-16 05:36:41 -0700   IM: [install succeeded]
2014-05-16 05:36:48 -0700   IM: ----------  log end  ----------
2014-05-21 13:46:06 -0700   IM: ---------- log start ----------
2014-05-21 13:46:07 -0700   IM: 1387
2014-05-23 07:07:14 -0700   IM: ---------- log start ----------
2014-05-23 07:07:21 -0700   IM: ----------  log end  ----------
2014-06-10 18:20:31 -0700   IM: ---------- log start ----------
2014-06-10 18:20:31 -0700   IM: 1387
2014-06-10 18:20:36 -0700   IM: ----------  log end  ----------
2014-06-10 18:21:55 -0700   IM: ---------- log start ----------
2014-06-10 18:21:55 -0700   IM: All install checks pass
2014-06-10 18:21:55 -0700   IM: Unexpected umask value for process: 0
2014-06-10 18:21:57 -0700   IM: User does not have any processes that need to be closed.
2014-06-10 18:21:57 -0700   IM: [install started]
2014-06-10 18:22:01 -0700 FIN: [finalizer started]
2014-06-10 18:22:01 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-06-10 18:22:01 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-06-10 18:22:02 -0700 FIN: [finalizer succeeded]
2014-06-10 18:22:08 -0700   IM: [install succeeded]
2014-06-10 18:22:08 -0700   IM: ----------  log end  ----------
2014-06-15 06:57:20 -0700   IM: ---------- log start ----------
2014-06-15 06:57:20 -0700   IM: 1387
2014-06-15 06:57:28 -0700   IM: ---------- log start ----------
2014-06-15 06:57:28 -0700   IM: 1387
2014-07-09 06:41:41 -0700   IM: ---------- log start ----------
2014-07-09 06:41:41 -0700   IM: 1387
2014-07-09 06:41:42 -0700   IM: 1387
2014-07-09 06:42:02 -0700   IM: 16326619
2014-07-09 06:42:02 -0700   IM: verifySignatureWithData : Message Verified!
2014-07-09 06:42:07 -0700   IM: ----------  log end  ----------
2014-07-09 06:42:11 -0700   IM: ---------- log start ----------
2014-07-09 06:42:11 -0700   IM: All install checks pass
2014-07-09 06:42:24 -0700   IM: User has 2 processes that need to be closed before the Flash Player can be installed.
2014-07-09 06:42:37 -0700   IM: [install started]
2014-07-09 06:42:39 -0700 FIN: [finalizer started]
2014-07-09 06:42:39 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-07-09 06:42:39 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-07-09 06:42:41 -0700 FIN: [finalizer succeeded]
2014-07-09 06:42:48 -0700   IM: [install completed]
2014-07-09 06:42:48 -0700   IM: [install succeeded]
2014-07-09 06:42:54 -0700   IM: ----------  log end  ----------
2014-08-12 16:28:34 -0700   IM: ---------- log start ----------
2014-08-12 16:28:34 -0700   IM: 1407
2014-08-12 16:28:38 -0700   IM: ---------- log start ----------
2014-08-12 16:28:38 -0700   IM: 1407
2014-08-12 16:28:45 -0700   IM: ----------  log end  ----------
2014-08-12 16:30:12 -0700   IM: ---------- log start ----------
2014-08-12 16:30:12 -0700   IM: All install checks pass
2014-08-12 16:30:12 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:30:14 -0700   IM: User has 3 processes that need to be closed.
2014-08-12 16:30:14 -0700   IM: Install failed with error code: 17.
2014-08-12 16:30:14 -0700   IM: ----------  log end  ----------
2014-08-12 16:31:03 -0700   IM: ---------- log start ----------
2014-08-12 16:31:03 -0700   IM: All install checks pass
2014-08-12 16:31:03 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:31:04 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:31:04 -0700   IM: Install failed with error code: 17.
2014-08-12 16:31:04 -0700   IM: ----------  log end  ----------
2014-08-12 16:31:38 -0700   IM: ---------- log start ----------
2014-08-12 16:31:38 -0700   IM: All install checks pass
2014-08-12 16:31:38 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:31:39 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:31:39 -0700   IM: Install failed with error code: 17.
2014-08-12 16:31:39 -0700   IM: ----------  log end  ----------
2014-08-12 16:31:47 -0700   IM: ---------- log start ----------
2014-08-12 16:31:47 -0700   IM: All install checks pass
2014-08-12 16:31:47 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:31:48 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:31:48 -0700   IM: Install failed with error code: 17.
2014-08-12 16:31:48 -0700   IM: ----------  log end  ----------
2014-08-12 16:31:50 -0700   IM: ---------- log start ----------
2014-08-12 16:31:50 -0700   IM: All install checks pass
2014-08-12 16:31:50 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:31:51 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:31:51 -0700   IM: Install failed with error code: 17.
2014-08-12 16:31:51 -0700   IM: ----------  log end  ----------
2014-08-12 16:32:17 -0700   IM: ---------- log start ----------
2014-08-12 16:32:17 -0700   IM: All install checks pass
2014-08-12 16:32:17 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:32:18 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:32:18 -0700   IM: Install failed with error code: 17.
2014-08-12 16:32:18 -0700   IM: ----------  log end  ----------
2014-08-12 16:33:13 -0700   IM: ---------- log start ----------
2014-08-12 16:33:13 -0700   IM: All install checks pass
2014-08-12 16:33:13 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:33:14 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:33:14 -0700   IM: Install failed with error code: 17.
2014-08-12 16:33:14 -0700   IM: ----------  log end  ----------
2014-08-12 16:33:24 -0700   IM: ---------- log start ----------
2014-08-12 16:33:24 -0700   IM: All install checks pass
2014-08-12 16:33:24 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:33:26 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:33:26 -0700   IM: Install failed with error code: 17.
2014-08-12 16:33:26 -0700   IM: ----------  log end  ----------
2014-08-12 16:33:59 -0700   IM: ---------- log start ----------
2014-08-12 16:33:59 -0700   IM: All install checks pass
2014-08-12 16:33:59 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:34:01 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:34:01 -0700   IM: Install failed with error code: 17.
2014-08-12 16:34:01 -0700   IM: ----------  log end  ----------
2014-08-12 16:34:02 -0700   IM: ---------- log start ----------
2014-08-12 16:34:02 -0700   IM: All install checks pass
2014-08-12 16:34:02 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:34:03 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:34:03 -0700   IM: Install failed with error code: 17.
2014-08-12 16:34:03 -0700   IM: ----------  log end  ----------
2014-08-12 16:34:20 -0700   IM: ---------- log start ----------
2014-08-12 16:34:20 -0700   IM: All install checks pass
2014-08-12 16:34:20 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:34:21 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:34:21 -0700   IM: Install failed with error code: 17.
2014-08-12 16:34:21 -0700   IM: ----------  log end  ----------
2014-08-12 16:35:50 -0700   IM: ---------- log start ----------
2014-08-12 16:35:50 -0700   IM: All install checks pass
2014-08-12 16:35:50 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:35:51 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:35:51 -0700   IM: Install failed with error code: 17.
2014-08-12 16:35:51 -0700   IM: ----------  log end  ----------
2014-08-12 16:35:57 -0700   IM: ---------- log start ----------
2014-08-12 16:35:57 -0700   IM: All install checks pass
2014-08-12 16:35:57 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:35:59 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:35:59 -0700   IM: Install failed with error code: 17.
2014-08-12 16:35:59 -0700   IM: ----------  log end  ----------
2014-08-12 16:36:00 -0700   IM: ---------- log start ----------
2014-08-12 16:36:00 -0700   IM: All install checks pass
2014-08-12 16:36:00 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:36:01 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:36:01 -0700   IM: Install failed with error code: 17.
2014-08-12 16:36:01 -0700   IM: ----------  log end  ----------
2014-08-12 16:36:02 -0700   IM: ---------- log start ----------
2014-08-12 16:36:02 -0700   IM: All install checks pass
2014-08-12 16:36:02 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:36:03 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:36:03 -0700   IM: Install failed with error code: 17.
2014-08-12 16:36:03 -0700   IM: ----------  log end  ----------
2014-08-12 16:36:04 -0700   IM: ---------- log start ----------
2014-08-12 16:36:04 -0700   IM: All install checks pass
2014-08-12 16:36:04 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:36:05 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:36:05 -0700   IM: Install failed with error code: 17.
2014-08-12 16:36:05 -0700   IM: ----------  log end  ----------
2014-08-12 16:36:06 -0700   IM: ---------- log start ----------
2014-08-12 16:36:06 -0700   IM: All install checks pass
2014-08-12 16:36:06 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:36:07 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:36:07 -0700   IM: Install failed with error code: 17.
2014-08-12 16:36:07 -0700   IM: ----------  log end  ----------
2014-08-12 16:36:08 -0700   IM: ---------- log start ----------
2014-08-12 16:36:08 -0700   IM: All install checks pass
2014-08-12 16:36:08 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:36:09 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:36:09 -0700   IM: Install failed with error code: 17.
2014-08-12 16:36:09 -0700   IM: ----------  log end  ----------
2014-08-12 16:36:10 -0700   IM: ---------- log start ----------
2014-08-12 16:36:10 -0700   IM: All install checks pass
2014-08-12 16:36:10 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:36:11 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:36:11 -0700   IM: Install failed with error code: 17.
2014-08-12 16:36:11 -0700   IM: ----------  log end  ----------
2014-08-12 16:36:12 -0700   IM: ---------- log start ----------
2014-08-12 16:36:12 -0700   IM: All install checks pass
2014-08-12 16:36:12 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:36:13 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:36:13 -0700   IM: Install failed with error code: 17.
2014-08-12 16:36:13 -0700   IM: ----------  log end  ----------
2014-08-12 16:37:00 -0700   IM: ---------- log start ----------
2014-08-12 16:37:00 -0700   IM: 1407
2014-08-12 16:37:03 -0700   IM: ---------- log start ----------
2014-08-12 16:37:03 -0700   IM: 1407
2014-08-12 16:37:11 -0700   IM: ----------  log end  ----------
2014-08-12 16:38:51 -0700   IM: ---------- log start ----------
2014-08-12 16:38:51 -0700   IM: All install checks pass
2014-08-12 16:38:51 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:38:53 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:38:53 -0700   IM: Install failed with error code: 17.
2014-08-12 16:38:53 -0700   IM: ----------  log end  ----------
2014-08-12 16:39:02 -0700   IM: ---------- log start ----------
2014-08-12 16:39:02 -0700   IM: All install checks pass
2014-08-12 16:39:02 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:39:03 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:39:03 -0700   IM: Install failed with error code: 17.
2014-08-12 16:39:03 -0700   IM: ----------  log end  ----------
2014-08-12 16:39:06 -0700   IM: ---------- log start ----------
2014-08-12 16:39:06 -0700   IM: All install checks pass
2014-08-12 16:39:06 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:39:07 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:39:07 -0700   IM: Install failed with error code: 17.
2014-08-12 16:39:07 -0700   IM: ----------  log end  ----------
2014-08-12 16:39:07 -0700   IM: ---------- log start ----------
2014-08-12 16:39:07 -0700   IM: All install checks pass
2014-08-12 16:39:07 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:39:08 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:39:09 -0700   IM: Install failed with error code: 17.
2014-08-12 16:39:09 -0700   IM: ----------  log end  ----------
2014-08-12 16:39:09 -0700   IM: ---------- log start ----------
2014-08-12 16:39:09 -0700   IM: All install checks pass
2014-08-12 16:39:09 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:39:10 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:39:10 -0700   IM: Install failed with error code: 17.
2014-08-12 16:39:10 -0700   IM: ----------  log end  ----------
2014-08-12 16:39:11 -0700   IM: ---------- log start ----------
2014-08-12 16:39:11 -0700   IM: All install checks pass
2014-08-12 16:39:11 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:39:12 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:39:12 -0700   IM: Install failed with error code: 17.
2014-08-12 16:39:12 -0700   IM: ----------  log end  ----------
2014-08-12 16:39:13 -0700   IM: ---------- log start ----------
2014-08-12 16:39:13 -0700   IM: All install checks pass
2014-08-12 16:39:13 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:39:14 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:39:14 -0700   IM: Install failed with error code: 17.
2014-08-12 16:39:14 -0700   IM: ----------  log end  ----------
2014-08-12 16:39:15 -0700   IM: ---------- log start ----------
2014-08-12 16:39:15 -0700   IM: All install checks pass
2014-08-12 16:39:15 -0700   IM: Unexpected umask value for process: 0
2014-08-12 16:39:16 -0700   IM: User has 1 process that needs to be closed.
2014-08-12 16:39:16 -0700   IM: Install failed with error code: 17.
2014-08-12 16:39:16 -0700   IM: ----------  log end  ----------
2014-08-13 06:18:07 -0700   IM: ---------- log start ----------
2014-08-13 06:18:08 -0700   IM: 1407
2014-08-13 06:18:11 -0700   IM: ---------- log start ----------
2014-08-13 06:18:11 -0700   IM: 1407
2014-08-13 06:18:19 -0700   IM: ----------  log end  ----------
2014-08-13 06:20:33 -0700   IM: ---------- log start ----------
2014-08-13 06:20:33 -0700   IM: All install checks pass
2014-08-13 06:20:33 -0700   IM: Unexpected umask value for process: 0
2014-08-13 06:20:34 -0700   IM: User has 1 process that needs to be closed.
2014-08-13 06:20:34 -0700   IM: Install failed with error code: 17.
2014-08-13 06:20:34 -0700   IM: ----------  log end  ----------
2014-08-13 06:21:28 -0700   IM: ---------- log start ----------
2014-08-13 06:21:28 -0700   IM: All install checks pass
2014-08-13 06:21:28 -0700   IM: Unexpected umask value for process: 0
2014-08-13 06:21:29 -0700   IM: User has 1 process that needs to be closed.
2014-08-13 06:21:29 -0700   IM: Install failed with error code: 17.
2014-08-13 06:21:29 -0700   IM: ----------  log end  ----------
2014-08-13 06:21:51 -0700   IM: ---------- log start ----------
2014-08-13 06:21:51 -0700   IM: All install checks pass
2014-08-13 06:21:51 -0700   IM: Unexpected umask value for process: 0
2014-08-13 06:21:52 -0700   IM: User has 1 process that needs to be closed.
2014-08-13 06:21:53 -0700   IM: Install failed with error code: 17.
2014-08-13 06:21:53 -0700   IM: ----------  log end  ----------
2014-08-13 06:21:54 -0700   IM: ---------- log start ----------
2014-08-13 06:21:54 -0700   IM: All install checks pass
2014-08-13 06:21:54 -0700   IM: Unexpected umask value for process: 0
2014-08-13 06:21:55 -0700   IM: User has 1 process that needs to be closed.
2014-08-13 06:21:55 -0700   IM: Install failed with error code: 17.
2014-08-13 06:21:55 -0700   IM: ----------  log end  ----------
2014-08-13 06:21:56 -0700   IM: ---------- log start ----------
2014-08-13 06:21:56 -0700   IM: All install checks pass
2014-08-13 06:21:56 -0700   IM: Unexpected umask value for process: 0
2014-08-13 06:21:57 -0700   IM: User has 1 process that needs to be closed.
2014-08-13 06:21:57 -0700   IM: Install failed with error code: 17.
2014-08-13 06:21:57 -0700   IM: ----------  log end  ----------
2014-08-13 06:21:58 -0700   IM: ---------- log start ----------
2014-08-13 06:21:58 -0700   IM: All install checks pass
2014-08-13 06:21:58 -0700   IM: Unexpected umask value for process: 0
2014-08-13 06:22:00 -0700   IM: User has 1 process that needs to be closed.
2014-08-13 06:22:00 -0700   IM: Install failed with error code: 17.
2014-08-13 06:22:00 -0700   IM: ----------  log end  ----------
2014-08-13 06:24:03 -0700   IM: ---------- log start ----------
2014-08-13 06:24:03 -0700   IM: All install checks pass
2014-08-13 06:24:03 -0700   IM: Unexpected umask value for process: 0
2014-08-13 06:24:04 -0700   IM: User has 1 process that needs to be closed.
2014-08-13 06:24:04 -0700   IM: Install failed with error code: 17.
2014-08-13 06:24:04 -0700   IM: ----------  log end  ----------
2014-08-13 06:24:19 -0700   IM: ---------- log start ----------
2014-08-13 06:24:19 -0700   IM: All install checks pass
2014-08-13 06:24:19 -0700   IM: Unexpected umask value for process: 0
2014-08-13 06:24:20 -0700   IM: User has 1 process that needs to be closed.
2014-08-13 06:24:20 -0700   IM: Install failed with error code: 17.
2014-08-13 06:24:20 -0700   IM: ----------  log end  ----------
2014-08-13 06:24:22 -0700   IM: ---------- log start ----------
2014-08-13 06:24:22 -0700   IM: All install checks pass
2014-08-13 06:24:22 -0700   IM: Unexpected umask value for process: 0
2014-08-13 06:24:23 -0700   IM: User has 1 process that needs to be closed.
2014-08-13 06:24:23 -0700   IM: Install failed with error code: 17.
2014-08-13 06:24:23 -0700   IM: ----------  log end  ----------
Votes
Translate
Translate
Report
Report
Aug 14, 2014 Aug 14, 2014
Pardon the link that leads to a page that is not useful....hopefully the cut/paste of the log file will be helpful to someone who might have a solution to my problem.
Barry
Votes
Translate
Translate
Report
Report
Barry
Votes
Translate
Translate
Report
Report
