0 Replies Latest reply on Aug 13, 2014 1:31 PM by coltonoscopy
    Chrome PDF Rendering Issue
      Hello all,
      I've been noticing some odd behavior in Chrome when trying to render a PDF I've exported from InDesign; attached is a screenshot of the symptom, and if you take the following link, you can also see it firsthand (though occasionally it will render fine; best to try and click the URL multiple times if the symptom isn't observable rather than refresh, as refreshing will make it work correctly every time).
      http://guide.cs50.net/guide-10.pdfScreen Shot 2014-08-11 at 8.30.31 AM.png
      Are there any particular export options I should turn on to make this issue go away, or something else I can do from within InDesign? Help is greatly appreciated!
