3 Replies Latest reply on Aug 14, 2014 5:21 AM by areohbee
    Import a RAW file
    Bogdan Caraman Photo Level 1
      Hello,
      When I try to Import an .CR2 file Lightroom 5.6 is doing some "Calculating" and then "destroy" my picture with QuickDevelop settings. I try to find where to Disable that but with no success, can anyone know another solution?
      Thank you,
      Bogdan
        • 1. Re: Import a RAW file
          areohbee Level 6
          If by "destroy" you mean alters color and tone, then that's just how it works - you have to learn to set up pleasing defaults, and edit after import.
          (the first image you see is a camera-generated jpeg preview stored in the raw file, which is replaced after "calculation" by a different rendering of the raw data).
          If by "destroy" you mean "has obnoxious stripes and/or rectangles on it", then your raw file is corrupt.
          • 2. Re: Import a RAW file
            Thank you Rob for the reply; destroyed by tone and color. I do edits in Develop Room after Import but I did not know why the picture look different from the original.
            • 3. Re: Import a RAW file
              areohbee Level 6
              You're welcome Bogdan,
              Just to be clear:
              - Original is camera-generated jpeg preview (stored in the raw file).
              - Different picture is Lr-rendering of raw data.
              If you generally like the former better than the latter, then consider changing default settings, including camera calibration profile.
              ~R.
