1. Re: Can I change a name on an existing pdf document?
bob.treitman Aug 14, 2014 2:31 PM (in response to clincher)Is the file stored in workspaces.acrobat.com or on your computer?
In either case, you should be able to rename it as you would rename any file. Is that what you're asking?
Or are you asking if it's possible to edit a name that appears in the document itself (not the name OF the document)?
2. Re: Can I change a name on an existing pdf document?
clincher Aug 15, 2014 5:29 AM (in response to bob.treitman)Bob
thanks for your reply.
I received a pdf document from xxx company with their letterhead info and contact info. I want to remove all traces of xxx company and if possible replace it with ours. We want to conceal the source of the product from our client until we get a sales agreement.
I found a program called pdf filler that worked quite well. I paid for one month, $20, just to get this project done but am looking for other ways to do this in the future. Rewriting the info is not an option as there are extensive data tables and graphs.
Dave
Dave Savage
305 801 7026
skype:flysouth61
www.flysouthaviation.com
3. Re: Can I change a name on an existing pdf document?
bob.treitman Aug 15, 2014 8:13 AM (in response to clincher)You cannot edit PDFs in Workspaces. For that, you would need to purchase Adobe Acrobat.
The other option would be to use our Export PDF service, which would convert the PDF to Word format. You could then edit the document in Word.
