This content has been marked as final.
Show 2 replies
1. Re: Unable to create (first) Workbench application ("Failed to create application, please check if application name contains invalid string).
Aditaya Maini Aug 18, 2014 2:47 AM (in response to nimurphy)Hi
I hope the service is in running state. Check the "DesigntimeService" too.
if it does not help, then also please check by configuring the service run as "Specify run as " as System on "repository provider service" and try again.
Also search for the services in stopped state. default services should all be in running state.
2. Re: Unable to create (first) Workbench application ("Failed to create application, please check if application name contains invalid string).
nimurphy Aug 27, 2014 7:34 AM (in response to Aditaya Maini)Thanks Aditaya. I didn't know about the DesignTimeService. There were no issues and I had already checked the other settings.
Looking at the logs it turned out that the JVM ran out of memory. Increasing the memory resolved the issue.
