23 Replies Latest reply on Aug 15, 2014 7:22 PM by Noel Carboni
    Photoshop CS5 crash on Mavericks
    DinoStudio
      I'm using PhotoShop CS5 on a Mac running OS Mavericks.  I'm unable to use PhotoShop since upgrading to Mavericks.  When I try to open a file, PhotoShop crashes.
        • 1. Re: PhotoShop crashes!
          Noel Carboni Level 8
          You could try a clean and reinstall of the application...
          Use the CC Cleaner Tool to solve installation problems | CC, CS3-CS6
          -Noel
          • 2. Re: PhotoShop crashes!
            DinoStudio Level 1
            The LINK won't allow me to download the...AdobeCreativeCloudCleanerTool.zip
            Ciao,
            Dino
            Dino Massaroni Studio
            P.O. Box 104
            Tallmadge, OH   44278-0104  USA
            001-330-388-9024
            www.DinoMassaroni.com
            www.TuscanTrio.com
            • 3. Re: PhotoShop crashes!
              Sounds like a problem with your security software or settings.  It works just fine here.
              -Noel
              • 4. Re: PhotoShop crashes!
                Level 7
                What does the detailed crash report say?  Without that, we can't know why you are crashing.
                • 5. Re: PhotoShop crashes!
                  DinoStudio Level 1
                  Well, now that I have deleted the Photoshop software according to Noel Carboni's instruction (of which I could only get as far as the deletion because the link to AdobeCreativeCloudCleanerTool.zip can't be accessed), I can't GET an crash report.
                  Ciao,
                  Dino
                  [ personal details removed by admin ]
                  • 6. Re: PhotoShop crashes!
                    You can work out how to download the software, I have confidence in you.
                    -Noel
                    • 7. Re: PhotoShop crashes!
                      DinoStudio Level 1
                      Ok...so I re-installed Photoshop CS5 from the original disks.  Opened the program, opened a file, tried to print.......CRASH!
                      Attached is the crash report.
                      Ciao,
                      Dino
                      • 8. Re: PhotoShop crashes!
                        DinoStudio Level 1
                        Ciao,
                        Dino
                        • 9. Re: PhotoShop crashes!
                          EMail attachments don't make it back to the forum thread.  Please use the web interface.  And break it up into multiple posts if it won't all fit.  Chris Cox needs the whole thing to be able to see what's up.
                          -Noel
                          • 10. Re: PhotoShop crashes!
                            DinoStudio Level 1
                            Process:         Adobe Photoshop CS5 [1602]
                            Path:            /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
                            Identifier:      com.adobe.Photoshop
                            Version:         12.0 (12.0x20100407.r.1103] [12.0)
                            Code Type:       X86-64 (Native)
                            Parent Process:  launchd [147]
                            Responsible:     Adobe Photoshop CS5 [1602]
                            User ID:         502
                            Date/Time:       2014-08-15 17:33:22.949 -0400
                            OS Version:      Mac OS X 10.9.4 (13E28)
                            Report Version:  11
                            Anonymous UUID:  EB3DA46C-7443-D1BA-8D39-94404E07E790
                            Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                            Exception Type:  EXC_BAD_ACCESS (SIGBUS)
                            Exception Codes: KERN_PROTECTION_FAILURE at 0x000000010354c818
                            VM Regions Near 0x10354c818:
                                __TEXT                 000000010334f000-0000000103535000 [ 1944K] r-x/rwx SM=COW  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                            --> __DATA                 0000000103535000-0000000103582000 [  308K] rw-/rwx SM=COW  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                __DATA                 0000000103582000-000000010358a000 [   32K] rw-/rwx SM=PRV  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                            Application Specific Information:
                            Performing @selector(performAction:) from sender PSCocoaButton 0x60800036fa80
                            Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                            0   ???                           0x000000010354c818 OBJC_CLASS_$_NSMutableArray + 0
                            1   com.apple.print.framework.PrintCore 0x000000010be596f1 PMRelease + 43
                            2   com.adobe.Photoshop           0x0000000100c237cf AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 9727123
                            3   com.adobe.Photoshop           0x0000000100c23e7d AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 9728833
                            4   com.adobe.Photoshop           0x0000000100c23eb7 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 9728891
                            5   com.adobe.Photoshop           0x0000000100c23da5 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 9728617
                            6   com.adobe.Photoshop           0x0000000100aee053 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 8459543
                            7   com.adobe.Photoshop           0x0000000100768626 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4766442
                            8   com.adobe.Photoshop           0x00000001007695d2 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4770454
                            9   com.adobe.Photoshop           0x000000010007ba06 0x100000000 + 506374
                            10  com.adobe.Photoshop           0x000000010007b91e 0x100000000 + 506142
                            11  com.adobe.Photoshop           0x000000010007ba06 0x100000000 + 506374
                            12  com.adobe.Photoshop           0x000000010007b91e 0x100000000 + 506142
                            13  com.adobe.Photoshop           0x00000001000724bd 0x100000000 + 468157
                            14  com.adobe.Photoshop           0x000000010007ba06 0x100000000 + 506374
                            15  com.adobe.Photoshop           0x000000010007b91e 0x100000000 + 506142
                            16  com.adobe.Photoshop           0x00000001000724bd 0x100000000 + 468157
                            17  com.adobe.Photoshop           0x000000010007ba06 0x100000000 + 506374
                            18  com.adobe.Photoshop           0x000000010007b91e 0x100000000 + 506142
                            19  com.adobe.Photoshop           0x00000001000724bd 0x100000000 + 468157
                            20  com.adobe.Photoshop           0x000000010007ba06 0x100000000 + 506374
                            21  com.adobe.Photoshop           0x000000010007b91e 0x100000000 + 506142
                            22  com.adobe.Photoshop           0x00000001000724bd 0x100000000 + 468157
                            23  com.adobe.Photoshop           0x000000010007ba06 0x100000000 + 506374
                            24  com.adobe.Photoshop           0x000000010007b91e 0x100000000 + 506142
                            25  com.adobe.Photoshop           0x00000001000724bd 0x100000000 + 468157
                            26  com.adobe.Photoshop           0x000000010007ba06 0x100000000 + 506374
                            27  com.adobe.Photoshop           0x000000010007b91e 0x100000000 + 506142
                            28  com.adobe.Photoshop           0x00000001000724bd 0x100000000 + 468157
                            29  com.adobe.Photoshop           0x00000001012d42b8 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16742268
                            30  com.adobe.Photoshop           0x000000010007ba06 0x100000000 + 506374
                            31  com.adobe.Photoshop           0x00000001012ed33b AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16844799
                            32  com.apple.AppKit              0x000000010457d260 -[NSApplication sendAction:to:from:] + 327
                            33  com.adobe.Photoshop           0x00000001012edd8e AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16847442
                            34  com.apple.AppKit              0x000000010457d0de -[NSControl sendAction:to:] + 86
                            35  com.apple.AppKit              0x00000001045c9c4d -[NSCell _sendActionFrom:] + 128
                            36  com.apple.AppKit              0x00000001045e3655 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 2316
                            37  com.apple.AppKit              0x00000001045e2a27 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 487
                            38  com.apple.AppKit              0x00000001045e213d -[NSControl mouseDown:] + 706
                            39  com.apple.AppKit              0x0000000104563a58 -[NSWindow sendEvent:] + 11296
                            40  com.adobe.Photoshop           0x00000001012e3b22 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16805862
                            41  com.apple.AppKit              0x00000001045025d4 -[NSApplication sendEvent:] + 2021
                            42  com.adobe.Photoshop           0x00000001012ef760 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16854052
                            43  com.adobe.Photoshop           0x00000001012f025c AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16856864
                            44  com.adobe.Photoshop           0x00000001000792bc 0x100000000 + 496316
                            45  com.adobe.Photoshop           0x000000010006716f 0x100000000 + 422255
                            46  com.adobe.Photoshop           0x0000000100067232 0x100000000 + 422450
                            47  com.adobe.Photoshop           0x0000000100075242 0x100000000 + 479810
                            48  com.adobe.Photoshop           0x000000010078f8eb AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4926895
                            49  com.adobe.Photoshop           0x0000000100790f24 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4932584
                            50  com.adobe.Photoshop           0x0000000100af065b AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 8469279
                            51  com.adobe.Photoshop           0x0000000100af0be9 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 8470701
                            52  com.adobe.Photoshop           0x0000000100af1295 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 8472409
                            53  com.adobe.Photoshop           0x000000010007bbdc 0x100000000 + 506844
                            54  com.adobe.Photoshop           0x00000001000d6a7e 0x100000000 + 879230
                            55  com.adobe.Photoshop           0x00000001000d6a9e 0x100000000 + 879262
                            56  com.adobe.Photoshop           0x0000000100066eb1 0x100000000 + 421553
                            57  com.adobe.Photoshop           0x0000000100071d74 0x100000000 + 466292
                            58  com.adobe.Photoshop           0x000000010006716f 0x100000000 + 422255
                            59  com.adobe.Photoshop           0x0000000100067232 0x100000000 + 422450
                            60  com.adobe.Photoshop           0x00000001012ee27b AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16848703
                            61  com.apple.Foundation          0x000000010370a0f4 __NSFireTimer + 96
                            62  com.apple.CoreFoundation      0x00000001034043e4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
                            63  com.apple.CoreFoundation      0x0000000103403f1f __CFRunLoopDoTimer + 1151
                            64  com.apple.CoreFoundation      0x00000001034755aa __CFRunLoopDoTimers + 298
                            65  com.apple.CoreFoundation      0x00000001033bf6a5 __CFRunLoopRun + 1525
                            66  com.apple.CoreFoundation      0x00000001033bee75 CFRunLoopRunSpecific + 309
                            67  com.apple.HIToolbox           0x000000010aa5da0d RunCurrentEventLoopInMode + 226
                            68  com.apple.HIToolbox           0x000000010aa5d685 ReceiveNextEventCommon + 173
                            69  com.apple.HIToolbox           0x000000010aa5d5bc _BlockUntilNextEventMatchingListInModeWithFilter + 65
                            70  com.apple.AppKit              0x000000010435f24e _DPSNextEvent + 1434
                            71  com.apple.AppKit              0x000000010435e89b -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122
                            72  com.apple.AppKit              0x000000010435299c -[NSApplication run] + 553
                            73  com.adobe.Photoshop           0x00000001012ee19c AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16848480
                            74  com.adobe.Photoshop           0x00000001012ef3c7 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 16853131
                            75  com.adobe.Photoshop           0x0000000100068e82 0x100000000 + 429698
                            76  com.adobe.Photoshop           0x0000000100238308 0x100000000 + 2327304
                            77  com.adobe.Photoshop           0x00000001002383a7 0x100000000 + 2327463
                            78  com.adobe.Photoshop           0x0000000100002ea4 0x100000000 + 11940
                            Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                            0   libsystem_kernel.dylib        0x000000010a6dc662 kevent64 + 10
                            1   libdispatch.dylib             0x000000010a533421 _dispatch_mgr_invoke + 239
                            2   libdispatch.dylib             0x000000010a533136 _dispatch_mgr_thread + 52
                            Thread 2:
                            0   libsystem_kernel.dylib        0x000000010a6dbe6a __workq_kernreturn + 10
                            1   libsystem_pthread.dylib       0x000000010a7d5f08 _pthread_wqthread + 330
                            2   libsystem_pthread.dylib       0x000000010a7d8fb9 start_wqthread + 13
                            Thread 3:
                            0   libsystem_kernel.dylib        0x000000010a6db716 __psynch_cvwait + 10
                            1   libsystem_pthread.dylib       0x000000010a7d6c3b _pthread_cond_wait + 727
                            2   com.adobe.amt.services        0x0000000111ed6c53 AMTConditionLock::LockWhenCondition(int) + 37
                            3   com.adobe.amt.services        0x0000000111ecfcce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
                            4   com.adobe.amt.services        0x0000000111ed6cbe AMTThread::Worker(void*) + 28
                            5   libsystem_pthread.dylib       0x000000010a7d4899 _pthread_body + 138
                            6   libsystem_pthread.dylib       0x000000010a7d472a _pthread_start + 137
                            7   libsystem_pthread.dylib       0x000000010a7d8fc9 thread_start + 13
                            Thread 4:
                            0   libsystem_kernel.dylib        0x000000010a6d7a6e semaphore_timedwait_trap + 10
                            1   com.apple.CoreServices.CarbonCore 0x000000010963c47b MPWaitOnSemaphore + 77
                            2   MultiProcessor Support        0x00000001153b1bd3 ThreadFunction(void*) + 69
                            3   com.apple.CoreServices.CarbonCore 0x000000010963c6c3 PrivateMPEntryPoint + 58
                            4   libsystem_pthread.dylib       0x000000010a7d4899 _pthread_body + 138
                            5   libsystem_pthread.dylib       0x000000010a7d472a _pthread_start + 137
                            6   libsystem_pthread.dylib       0x000000010a7d8fc9 thread_start + 13
                            Thread 5:
                            2   com.apple.CoreServices.CarbonCore 0x000000010966b800 TSWaitOnCondition + 108
                            3   com.apple.CoreServices.CarbonCore 0x000000010966b9ff TSWaitOnConditionTimedRelative + 172
                            4   com.apple.CoreServices.CarbonCore 0x000000010963c145 MPWaitOnQueue + 192
                            5   AdobeACE                      0x0000000107be423d 0x107baa000 + 238141
                            6   AdobeACE                      0x0000000107be3bea 0x107baa000 + 236522
                            7   com.apple.CoreServices.CarbonCore 0x000000010963c6c3 PrivateMPEntryPoint + 58
                            8   libsystem_pthread.dylib       0x000000010a7d4899 _pthread_body + 138
                            9   libsystem_pthread.dylib       0x000000010a7d472a _pthread_start + 137
                            10  libsystem_pthread.dylib       0x000000010a7d8fc9 thread_start + 13
                            Thread 6:
                            0   libsystem_kernel.dylib        0x000000010a6dba3a __semwait_signal + 10
                            1   libsystem_c.dylib             0x000000010a638dc0 nanosleep + 200
                            2   com.adobe.PSAutomate          0x00000001178620fb ScObjects::Thread::sleep(unsigned int) + 59
                            3   com.adobe.PSAutomate          0x0000000117844033 ScObjects::BridgeTalkThread::run() + 163
                            4   com.adobe.PSAutomate          0x00000001178621f6 ScObjects::Thread::go(void*) + 166
                            Thread 7:
                            Thread 8:
                            0   libsystem_kernel.dylib        0x000000010a6d7a1a mach_msg_trap + 10
                            1   libsystem_kernel.dylib        0x000000010a6d6d18 mach_msg + 64
                            2   com.apple.CoreFoundation      0x00000001033bff15 __CFRunLoopServiceMachPort + 181
                            3   com.apple.CoreFoundation      0x00000001033bf539 __CFRunLoopRun + 1161
                            4   com.apple.CoreFoundation      0x00000001033bee75 CFRunLoopRunSpecific + 309
                            5   com.apple.AppKit              0x00000001044ff05e _NSEventThread + 144
                            6   libsystem_pthread.dylib       0x000000010a7d4899 _pthread_body + 138
                            7   libsystem_pthread.dylib       0x000000010a7d472a _pthread_start + 137
                            8   libsystem_pthread.dylib       0x000000010a7d8fc9 thread_start + 13
                            Thread 9:
                            2   com.adobe.adobeswfl           0x000000011927f04d APXGetHostAPI + 2430509
                            3   com.adobe.adobeswfl           0x0000000119040a39 APXGetHostAPI + 77849
                            4   com.adobe.adobeswfl           0x000000011927f161 APXGetHostAPI + 2430785
                            5   com.adobe.adobeswfl           0x000000011927f2ba APXGetHostAPI + 2431130
                            6   com.adobe.adobeswfl           0x000000011927f3b0 APXGetHostAPI + 2431376
                            7   libsystem_pthread.dylib       0x000000010a7d4899 _pthread_body + 138
                            8   libsystem_pthread.dylib       0x000000010a7d472a _pthread_start + 137
                            9   libsystem_pthread.dylib       0x000000010a7d8fc9 thread_start + 13
                            Thread 10:
                            Thread 11:
                            1   libsystem_pthread.dylib       0x000000010a7d6c77 _pthread_cond_wait + 787
                            2   com.adobe.adobeswfl           0x000000011927f019 APXGetHostAPI + 2430457
                            3   com.adobe.adobeswfl           0x00000001194148e5 APXGetHostAPI + 4091589
                            Thread 12:
                            3   com.adobe.adobeswfl           0x000000011929b95c APXGetHostAPI + 2547516
                            Thread 13:
                            0   libsystem_kernel.dylib        0x000000010a6d7a56 semaphore_wait_trap + 10
                            1   com.adobe.CameraRaw           0x0000000126e866fc EntryFM + 1855036
                            2   com.adobe.CameraRaw           0x0000000126e8a200 EntryFM + 1870144
                            3   libsystem_pthread.dylib       0x000000010a7d4899 _pthread_body + 138
                            4   libsystem_pthread.dylib       0x000000010a7d472a _pthread_start + 137
                            5   libsystem_pthread.dylib       0x000000010a7d8fc9 thread_start + 13
                            Thread 14:
                            5   com.adobe.CameraRaw           0x0000000126c5df9d 0x126ab9000 + 1724317
                            6   com.adobe.CameraRaw           0x0000000126c5d93b 0x126ab9000 + 1722683
                            Thread 15:
                            2   com.adobe.CameraRaw           0x0000000126af48c5 0x126ab9000 + 243909
                            3   com.adobe.CameraRaw           0x0000000126d772e7 EntryFM + 743975
                            4   com.adobe.CameraRaw           0x0000000126b8ee8b 0x126ab9000 + 876171
                            Thread 16:
                            2   com.adobe.CameraRaw           0x0000000126e8c990 EntryFM + 1880272
                            Thread 17:
                            2   com.adobe.CameraRaw           0x0000000126e8c945 EntryFM + 1880197
                            Thread 18:
                            3   com.adobe.CameraRaw           0x0000000126df12c8 EntryFM + 1243656
                            Thread 19:: com.apple.CoreAnimation.render-server
                            2   com.apple.QuartzCore          0x000000010565f377 CA::Render::Server::server_thread(void*) + 195
                            3   com.apple.QuartzCore          0x000000010565f2ad thread_fun + 25
                            Thread 20:
                            Thread 21:
                            Thread 22:
                            0   libsystem_kernel.dylib        0x000000010a6db91a __recvfrom + 10
                            1   ServiceManager-Launcher.dylib 0x00000001120f3982 Invoke + 54020
                            2   ServiceManager-Launcher.dylib 0x00000001120f2adf Invoke + 50273
                            3   ServiceManager-Launcher.dylib 0x00000001120f1b26 Invoke + 46248
                            4   ServiceManager-Launcher.dylib 0x00000001120f1b81 Invoke + 46339
                            5   ServiceManager-Launcher.dylib 0x00000001120f1c02 Invoke + 46468
                            6   ServiceManager-Launcher.dylib 0x00000001120ec30d Invoke + 23695
                            7   ServiceManager-Launcher.dylib 0x00000001120ec4a6 Invoke + 24104
                            8   ServiceManager-Launcher.dylib 0x00000001120ecf2f Invoke + 26801
                            9   ServiceManager-Launcher.dylib 0x00000001120ed01d Invoke + 27039
                            10  ServiceManager-Launcher.dylib 0x00000001120f031f Invoke + 40097
                            11  ServiceManager-Launcher.dylib 0x00000001120f05c5 Invoke + 40775
                            12  ServiceManager-Launcher.dylib 0x00000001120f0b84 Invoke + 42246
                            13  ServiceManager-Launcher.dylib 0x00000001120f0d71 Invoke + 42739
                            14  ServiceManager-Launcher.dylib 0x00000001120e2daf Login + 1773
                            15  ServiceManager-Launcher.dylib 0x00000001120e4295 Login + 7123
                            16  ServiceManager-Launcher.dylib 0x00000001120f12a8 Invoke + 44074
                            17  ServiceManager-Launcher.dylib 0x00000001120f36c1 Invoke + 53315
                            18  libsystem_pthread.dylib       0x000000010a7d4899 _pthread_body + 138
                            19  libsystem_pthread.dylib       0x000000010a7d472a _pthread_start + 137
                            20  libsystem_pthread.dylib       0x000000010a7d8fc9 thread_start + 13
                            Thread 23:: com.apple.appkit-heartbeat
                            2   libsystem_c.dylib             0x000000010a638cb2 usleep + 54
                            3   com.apple.AppKit              0x00000001045c317d -[NSUIHeartBeat _heartBeatThread:] + 2132
                            4   com.apple.Foundation          0x000000010370c76b __NSThread__main__ + 1318
                            Thread 0 crashed with X86 Thread State (64-bit):
                              rax: 0x000000010354c778  rbx: 0x0000600000c4ff30  rcx: 0x0000000000000001  rdx: 0x0000000000000001
                              rdi: 0x0000600000c4ff30  rsi: 0x000060800061e398  rbp: 0x00007fff5fbfb860  rsp: 0x00007fff5fbfb858
                               r8: 0x0000000000000001   r9: 0x0000000000000001  r10: 0x000000010beade60  r11: 0x000000010be596c6
                              r12: 0x0000608002059b00  r13: 0x000060800061e390  r14: 0x0000000000000001  r15: 0x00007fff5fbfb980
                              rip: 0x000000010354c818  rfl: 0x0000000000010206  cr2: 0x000000010354c818
                            Logical CPU:     1
                            Error Code:      0x00000015
                            Trap Number:     14
                            • 11. Re: PhotoShop crashes!
                              DinoStudio Level 1
                              (CONTINUED FROM ABOVE)
                              Binary Images:
                                     0x100000000 -        0x1026b5fff +com.adobe.Photoshop (12.0 - 12.0x20100407.r.1103] [12.0) <B69D89E5-01DD-C220-48B1-E129D0574536> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/MacOS/Adobe Photoshop CS5
                                     0x103295000 -        0x10330dfef +com.adobe.adobe_caps (adobe_caps 3.0.116.0 - 3.0.116.0) <4A355686-1451-B19A-0C55-DFE49FD2539E> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/a/adobe_caps
                                     0x103323000 -        0x103323fff  com.apple.Carbon (154 - 157) <EFC1A1C0-CB07-395A-B038-CFA2E71D3E69> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                     0x103326000 -        0x10332cfff  org.twain.dsm (1.9.5 - 1.9.5) <E614CAAE-7B01-348B-90E4-DB3FD3D066A6> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
                                     0x103334000 -        0x103344ff8 +com.adobe.ahclientframework (1.5.0.30 - 1.5.0.30) <5D6FFC4E-7B81-3E8C-F0D4-66A3FA94A837> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/ahclient.framework/Versions/a/ahclient
                                     0x10334f000 -        0x103534fff  com.apple.CoreFoundation (6.9 - 855.17) <729BD6DA-1F63-3E72-A148-26F21EBF52BB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                     0x1036a6000 -        0x1039a4fff  com.apple.Foundation (6.9 - 1056.13) <2EE9AB07-3EA0-37D3-B407-4A520F2CB497> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                     0x103be1000 -        0x103e3bff9  com.apple.security (7.0 - 55471.14.8) <EA03E140-2509-3A07-8440-2DC97C0D478B> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                     0x103f84000 -        0x103ff0fff  com.apple.framework.IOKit (2.0.1 - 907.100.13) <057FDBA3-56D6-3903-8C0B-849214BF1985> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                     0x104025000 -        0x104029fff  com.apple.agl (3.2.3 - AGL-3.2.3) <9851E4CC-DA6B-3AF4-9B06-61BAC289572D> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                     0x104030000 -        0x10403efff  com.apple.opengl (9.6.1 - 9.6.1) <B22FA400-5824-36AF-9945-5FEC31995A0E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                     0x104046000 -        0x10424cfef +com.adobe.linguistic.LinguisticManager (5.0.0 - 11696) <499B4E7A-08BB-80FC-C220-D57D45CA424F> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adobelinguistic.framework/Versions/3/AdobeLinguistic
                                     0x1042df000 -        0x104326ff7  libcups.2.dylib (372.4) <36EA4350-43B4-3A5C-9904-10685BFDA7D4> /usr/lib/libcups.2.dylib
                                     0x10433b000 -        0x104eb1ff7  com.apple.AppKit (6.9 - 1265.21) <9DC13B27-841D-3839-93B2-3EDE66157BDE> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                     0x105638000 -        0x1057d4ff3  com.apple.QuartzCore (1.8 - 332.3) <D6285800-F386-3E6B-84F2-A62F9029D95F> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                     0x1058ab000 -        0x105a59fef +com.adobe.owl (AdobeOwl version 3.0.91 - 3.0.91) <C36CA603-EFFB-2EED-6CEE-0B532CE052D2> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/a/AdobeOwl
                                     0x105afb000 -        0x105f2bfef +AdobeMPS (1) <FA334142-5343-8808-7760-4318EB62AD51> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/a/AdobeMPS
                                     0x106085000 -        0x1063b0ff7 +AdobeAGM (1) <52E17D56-6E7A-A635-82ED-5DE1F3E5045D> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/a/AdobeAGM
                                     0x10647d000 -        0x1067a5fe7 +AdobeCoolType (1) <9E03F47A-06A3-F1F4-AC4C-76F12FACC294> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/a/AdobeCoolType
                                     0x10683d000 -        0x10685eff7 +AdobeBIBUtils (1) <F7150688-2C15-0F0C-AF24-93ED82FC321A> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/a/AdobeBIBUtils
                                     0x10686b000 -        0x106896ff6 +AdobeAXE8SharedExpat (0) <7E809606-BF97-DB3A-E465-156446E56D00> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/a/AdobeAXE8SharedExpa t
                                     0x1068a8000 -        0x1069ecfef +WRServices (0) <76354373-F0BD-0BAF-6FC0-B96DBB371755> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/wrservices.framework/Versions/a/WRServices
                                     0x106a33000 -        0x106a98fff +aif_core (0) <12FA670E-05A8-1FCB-A7A2-AAE68728EA30> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/aif_core.framework/Versions/a/aif_core
                                     0x106ab4000 -        0x106acafff +data_flow (0) <9C5D39A6-D2A2-9B6A-8B64-D1B59396C112> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/data_flow.framework/Versions/a/data_flow
                                     0x106ae2000 -        0x106b78fff +image_flow (0) <B72AA922-0D68-D57E-96B1-2E009B0AD4AE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/image_flow.framework/Versions/a/image_flow
                                     0x106bef000 -        0x106c0dfff +image_runtime (0) <32786637-C9BF-4CB6-2DF9-5D99220E00BE> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/image_runtime.framework/Versions/a/image_runtime
                                     0x106c2a000 -        0x106e59fff +aif_ogl (0) <615E7DF6-09B1-857A-74AC-E224A636BEE1> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/a/aif_ogl
                                     0x106f38000 -        0x106fcbfff +AdobeOwlCanvas (1) <EC667F6D-0BB6-03EA-41E8-624425B2BF4B> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeOwlCanvas.framework/Versions/a/AdobeOwlCanvas
                                     0x106feb000 -        0x107334fef +com.adobe.dvaui.framework (dvaui version 5.0.0 - 5.0.0.0) <023E0760-0223-AB5D-758C-2C5A052F6AF4> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvaui.framework/Versions/a/dvaui
                                     0x1074c4000 -        0x107646fe7 +com.adobe.dvacore.framework (dvacore version 5.0.0 - 5.0.0.0) <42077295-9026-D519-C057-35E07029D97B> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvacore.framework/Versions/a/dvacore
                                     0x1076e8000 -        0x107a60fff +com.adobe.dvaadameve.framework (dvaadameve version 5.0.0 - 5.0.0.0) <0E95A0DF-038A-CFF2-EC7B-BDB905CDF5C5> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/dvaadameve.framework/Versions/a/dvaadameve
                                     0x107baa000 -        0x107cbefff +AdobeACE (1) <E359887D-1E7F-5E62-CB8D-37CE4DBFB4D8> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/a/AdobeACE
                                     0x107ce3000 -        0x107cfffff +AdobeBIB (1) <7A792F27-42CC-2DCA-D5DF-88A2CE6C2626> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/a/AdobeBIB
                                     0x107d09000 -        0x107d73ff7 +com.adobe.amtlib (amtlib 3.0.0.64 - 3.0.0.64) <6B2F73C2-10AB-08B3-4AB0-A31C83D1E5E0> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/amtlib.framework/Versions/a/amtlib
                                     0x107da6000 -        0x107e79ffb +AdobeJP2K (0) <465D1693-BE79-590E-E1AA-BAA8061B4746> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adobejp2k.framework/Versions/a/AdobeJP2K
                                     0x107e99000 -        0x107e9dff8 +com.adobe.ape.shim (adbeape version 3.1.65.7508 - 3.1.65.7508) <0C380604-C686-C2E4-0535-C1FAB230187E> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adbeape.framework/Versions/a/adbeape
                                     0x107ea1000 -        0x107f18fff +FileInfo (0) <6D5235B9-0EB6-17CA-6457-A2507A87EA8F> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/FileInfo.framework/Versions/a/FileInfo
                                     0x107f39000 -        0x107f97ffd +AdobeXMP (0) <561026BB-C6EA-29CE-4790-CABCB81E8884> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/a/AdobeXMP
                                     0x107fa5000 -        0x108440fff +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/Cg.framework/Cg
                                     0x1089c6000 -        0x108a1cfeb +com.adobe.headlights.LogSessionFramework (2.0.1.011) <03B80698-2C3B-A232-F15F-8F08F8963A19> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/LogSession.framework/Versions/a/LogSession
                                     0x108a61000 -        0x108bcfff7  libBLAS.dylib (1094.5) <DE93A590-5FA5-32A2-A16C-5D7D7361769F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                     0x108bf8000 -        0x108d4cff3  com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) <69B273E8-5A8E-3FC7-B807-C16B657662FE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                     0x108de2000 -        0x108e07ffe +AdobePDFSettings (1) <56E7F033-6032-2EC2-250E-43F1EBD123B1> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/adobepdfsettings.framework/Versions/a/AdobePDFSettings
                                     0x108e41000 -        0x108e46ffd +com.adobe.AdobeCrashReporter (3.0 - 3.0.20100302) <DFFB9A08-8369-D65F-161F-7C61D562E307> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/a/AdobeCrashReporter
                                     0x108e4b000 -        0x108fe6fff +com.adobe.PlugPlug (2.0.0.746 - 2.0.0.746) <CB23C5AA-0E4B-182B-CB88-57DD32893F92> /Applications/Adobe Photoshop CS5/Adobe Photoshop CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/a/PlugPlug
                                     0x10908e000 -        0x1090dcff9  libstdc++.6.dylib (60) <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
                                     0x109143000 -        0x109144ff7  libSystem.B.dylib (1197.1.1) <E6BCC031-4342-318C-A1AD-A8E9AEAE716F> /usr/lib/libSystem.B.dylib
                                     0x10914b000 -        0x10914bfff  com.apple.CoreServices (59 - 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                     0x10914f000 -        0x1092fcf27  libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib
                                     0x10931d000 -        0x10931dfff  com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                     0x109320000 -        0x1094bbff8  com.apple.CFNetwork (673.3 - 673.3) <4375B7CB-34B6-3A26-99AC-2D2404AD9C9B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                                     0x1095c2000 -        0x1098acfff  com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <3A2E92FD-DEE2-3D45-9619-11500801A61C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                     0x109929000 -        0x1099b9ff7  com.apple.Metadata (10.7.0 - 800.28) <CB43AF4C-F5DE-3161-B7D7-540DF9718EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                     0x109a20000 -        0x109a97fff  com.apple.CoreServices.OSServices (600.4 - 600.4) <B9436B61-0885-3EF6-B981-EB77C325F745> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                     0x109b3a000 -        0x109ba7fff  com.apple.SearchKit (1.4.0 - 1.4.0) <B9B8D510-A27E-36B0-93E9-17146D9E9045> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                     0x109beb000 -        0x109c46ffb  com.apple.AE (665.5 - 665.5) <BBA230F9-144C-3CAB-A77A-0621719244CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                     0x109c75000 -        0x109d3ffff  com.apple.LaunchServices (572.28 - 572.28) <FDED4724-4CB6-3DE5-B785-AE6D4C261CF6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                     0x109db4000 -        0x109dddfff  com.apple.DictionaryServices (1.2 - 208) <A539A058-BA57-35EE-AA08-D0B0E835127D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                     0x109e00000 -        0x109e42ff7  libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib
                                     0x109e5a000 -        0x109e6afff  libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
                                     0x109e73000 -        0x109ed6ffb  com.apple.SystemConfiguration (1.13.1 - 1.13.1) <2C8E1A73-5AD6-3A7D-8ED8-D6755555A993> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                     0x109f11000 -        0x109ffbfff  libsqlite3.dylib (158) <00269BF9-43BE-39E0-9C85-24585B9923C8> /usr/lib/libsqlite3.dylib
                                     0x10a012000 -        0x10a023ff7  libz.1.dylib (53) <42E0C8C6-CA38-3CA4-8619-D24ED5DD492E> /usr/lib/libz.1.dylib
                                     0x10a029000 -        0x10a110ff7  libxml2.2.dylib (26) <A1DADD11-89E5-3DE4-8802-07186225967F> /usr/lib/libxml2.2.dylib
                                     0x10a146000 -        0x10a2feffb  libicucore.A.dylib (511.34) <616A65D6-3F20-3EAB-8CA8-273AD890261C> /usr/lib/libicucore.A.dylib
                                     0x10a3a4000 -        0x10a3f6fff  libc++.1.dylib (120) <4F68DFC5-2077-39A8-A449-CAC5FDEE7BDE> /usr/lib/libc++.1.dylib
                                     0x10a452000 -        0x10a453ff7  libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib
                                     0x10a458000 -        0x10a481ff7  libc++abi.dylib (49.1) <21A807D3-6732-3455-B77F-743E9F916DF0> /usr/lib/libc++abi.dylib
                                     0x10a48f000 -        0x10a493ff7  libcache.dylib (62) <BDC1E65B-72A1-3DA3-A57C-B23159CAAD0B> /usr/lib/system/libcache.dylib
                                     0x10a498000 -        0x10a4a2fff  libcommonCrypto.dylib (60049) <8C4F0CA0-389C-3EDC-B155-E62DD2187E1D> /usr/lib/system/libcommonCrypto.dylib
                                     0x10a4b0000 -        0x10a4b7fff  libcompiler_rt.dylib (35) <4CD916B2-1B17-362A-B403-EF24A1DAC141> /usr/lib/system/libcompiler_rt.dylib
                                     0x10a4c3000 -        0x10a4caffb  libcopyfile.dylib (103.92.1) <CF29DFF6-0589-3590-834C-82E2316612E8> /usr/lib/system/libcopyfile.dylib
                                     0x10a4d1000 -        0x10a51ffff  libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib
                                     0x10a530000 -        0x10a54afff  libdispatch.dylib (339.92.1) <C4E4A18D-3C3B-3C9C-8709-A4270D998DE7> /usr/lib/system/libdispatch.dylib
                                     0x10a564000 -        0x10a567ff7  libdyld.dylib (239.4) <A1273A02-4928-3BAC-A846-6C069DC1A0A6> /usr/lib/system/libdyld.dylib
                                     0x10a56e000 -        0x10a56eff7  libkeymgr.dylib (28) <3AA8D85D-CF00-3BD3-A5A0-E28E1A32A6D8> /usr/lib/system/libkeymgr.dylib
                                     0x10a573000 -        0x10a57aff8  liblaunch.dylib (842.92.1) <A40A0C7B-3216-39B4-8AE0-B5D3BAF1DA8A> /usr/lib/system/liblaunch.dylib
                                     0x10a582000 -        0x10a587fff  libmacho.dylib (845) <1D2910DF-C036-3A82-A3FD-44FF73B5FF9B> /usr/lib/system/libmacho.dylib
                                     0x10a58d000 -        0x10a58fff7  libquarantine.dylib (71) <7A1A2BCB-C03D-3A25-BFA4-3E569B2D2C38> /usr/lib/system/libquarantine.dylib
                                     0x10a595000 -        0x10a596ffb  libremovefile.dylib (33) <3543F917-928E-3DB2-A2F4-7AB73B4970EF> /usr/lib/system/libremovefile.dylib
                                     0x10a59c000 -        0x10a5adff7  libsystem_asl.dylib (217.1.4) <655FB343-52CF-3E2F-B14D-BEBF5AAEF94D> /usr/lib/system/libsystem_asl.dylib
                                     0x10a5b7000 -        0x10a5b8ff7  libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib
                                     0x10a5bd000 -        0x10a646ff7  libsystem_c.dylib (997.90.3) <6FD3A400-4BB2-3B95-B90C-BE6E9D0D78FA> /usr/lib/system/libsystem_c.dylib
                                     0x10a672000 -        0x10a674ff3  libsystem_configuration.dylib (596.15) <4998CB6A-9D54-390A-9F57-5D1AC53C135C> /usr/lib/system/libsystem_configuration.dylib
                                     0x10a67a000 -        0x10a682fff  libsystem_dnssd.dylib (522.92.1) <17B03FFD-92C5-3282-9981-EBB28B456207> /usr/lib/system/libsystem_dnssd.dylib
                                     0x10a689000 -        0x10a6b0ffb  libsystem_info.dylib (449.1.3) <7D41A156-D285-3849-A2C3-C04ADE797D98> /usr/lib/system/libsystem_info.dylib
                                     0x10a6c6000 -        0x10a6e2ff7  libsystem_kernel.dylib (2422.110.17) <873931CE-D1AF-3596-AADB-D2E63C9AB29F> /usr/lib/system/libsystem_kernel.dylib
                                     0x10a706000 -        0x10a735fd2  libsystem_m.dylib (3047.16) <B7F0E2E4-2777-33FC-A787-D6430B630D54> /usr/lib/system/libsystem_m.dylib
                                     0x10a740000 -        0x10a75bff7  libsystem_malloc.dylib (23.10.1) <A695B4E4-38E9-332E-A772-29D31E3F1385> /usr/lib/system/libsystem_malloc.dylib
                                     0x10a765000 -        0x10a78cff7  libsystem_network.dylib (241.3) <8B1E1F1D-A5CC-3BAE-8B1E-ABC84337A364> /usr/lib/system/libsystem_network.dylib
                                     0x10a7a8000 -        0x10a7b1ff3  libsystem_notify.dylib (121) <52571EC3-6894-37E4-946E-064B021ED44E> /usr/lib/system/libsystem_notify.dylib
                                     0x10a7ba000 -        0x10a7c0ff7  libsystem_platform.dylib (24.90.1) <3C3D3DA8-32B9-3243-98EC-D89B9A1670B3> /usr/lib/system/libsystem_platform.dylib
                                     0x10a7d3000 -        0x10a7daff7  libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib
                                     0x10a7e6000 -        0x10a7e7fff  libsystem_sandbox.dylib (278.11.1) <0D0B13EA-6B7A-3AC8-BE60-B548543BEB77> /usr/lib/system/libsystem_sandbox.dylib
                                     0x10a7ec000 -        0x10a7f0ff7  libsystem_stats.dylib (93.90.3) <337946FC-B2E1-3DFA-A8B5-30DA8D584D75> /usr/lib/system/libsystem_stats.dylib
                                     0x10a7f7000 -        0x10a7f8fff  libunc.dylib (28) <62682455-1862-36FE-8A04-7A6B91256438> /usr/lib/system/libunc.dylib
                                     0x10a7fe000 -        0x10a803ff7  libunwind.dylib (35.3) <78DCC358-2FC1-302E-B395-0155B47CB547> /usr/lib/system/libunwind.dylib
                                     0x10a80a000 -        0x10a82efff  libxpc.dylib (300.90.2) <AB40CD57-F454-3FD4-B415-63B3C0D5C624> /usr/lib/system/libxpc.dylib
                                     0x10a84b000 -        0x10a858ff7  libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib
                                     0x10a860000 -        0x10a864fff  libpam.2.dylib (20) <B93CE8F5-DAA8-30A1-B1F6-F890509513CB> /usr/lib/libpam.2.dylib
                                     0x10a869000 -        0x10a869ffd  libOpenScriptingUtil.dylib (157) <19F0E769-0989-3062-9AFB-8976E90E9759> /usr/lib/libOpenScriptingUtil.dylib
                                     0x10a86d000 -        0x10a87aff0  libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib
                                     0x10a880000 -        0x10a885fff  com.apple.DiskArbitration (2.6 - 2.6) <A4165553-770E-3D27-B217-01FC1F852B87> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                     0x10a88f000 -        0x10a896fff  com.apple.NetFS (6.0 - 4.0) <8E26C099-CE9D-3819-91A2-64EA929C6137> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                     0x10a89e000 -        0x10a8a9fff  libkxld.dylib (2422.110.17) <B6140BAB-0EAF-3E4F-B055-314068056BB4> /usr/lib/system/libkxld.dylib
                                     0x10a8ae000 -        0x10a8b9ff7  com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                     0x10a8c5000 -        0x10a8c6fff  liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib
                                     0x10a8ca000 -        0x10a8e5ff7  libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib
                                     0x10a8ef000 -        0x10a953fff  com.apple.datadetectorscore (5.0 - 354.5) <0AE9749A-6BFC-3032-B802-210DF59AEDB0> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                     0x10a992000 -        0x10a995fff  com.apple.TCC (1.0 - 1) <32A075D9-47FD-3E71-95BC-BFB0D583F41C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                                     0x10a99c000 -        0x10a9b3ff7  com.apple.CFOpenDirectory (10.9 - 173.90.1) <EBC0A1F2-9054-3D39-99AE-A3F655E55D6A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                     0x10a9d1000 -        0x10a9dbff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <2D27B498-BB9C-3D88-B05A-76908A8A26F3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                                     0x10a9e6000 -        0x10aa0effb  libxslt.1.dylib (13) <C9794936-633C-3F0C-9E71-30190B9B41C1> /usr/lib/libxslt.1.dylib
                                     0x10aa1b000 -        0x10aa1ffff  com.apple.CommonPanels (1.2.6 - 96) <6B434AFD-50F8-37C7-9A56-162C17E375B3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                     0x10aa26000 -        0x10aa29fff  com.apple.help (1.3.3 - 46) <AE763646-D07A-3F9A-ACD4-F5CBD734EE36> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                     0x10aa2f000 -        0x10acd9ff5  com.apple.HIToolbox (2.1.1 - 698) <26FF0E2C-1CD7-311F-ACF0-84F3D5273AD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                     0x10ae31000 -        0x10ae43fff  com.apple.ImageCapture (9.0 - 9.0) <BE0B65DA-3031-359B-8BBA-B9803D4ADBF4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                     0x10ae5e000 -        0x10aeeaff7  com.apple.ink.framework (10.9 - 207) <8A50B893-AD03-3826-8555-A54FEAF08F47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                     0x10af1d000 -        0x10af35ff7  com.apple.openscripting (1.4 - 157) <B3B037D7-1019-31E6-9D17-08E699AF3701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                     0x10af47000 -        0x10af48ff7  com.apple.print.framework.Print (9.0 - 260) <EE00FAE1-DA03-3EC2-8571-562518C46994> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                     0x10af4d000 -        0x10af4fff7  com.apple.securityhi (9.0 - 55005) <446BE1A5-F65F-3ACB-8F33-A8EBFE0D0BD4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                     0x10af55000 -        0x10af5dff7  com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <98BBB3E4-6239-3EF1-90B2-84EA0D3B8D61> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                     0x10af67000 -        0x10b029ff5  com.apple.CoreText (367.20 - 367.20) <B80D086D-93A9-3C35-860E-9C3FDD027F3B> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                                     0x10b097000 -        0x10b9b732b  com.apple.CoreGraphics (1.600.0 - 599.25.10.1) <EC14B831-96BB-3A50-A451-E36BDC8F59FB> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                                     0x10bae4000 -        0x10bbeaff7  com.apple.ImageIO.framework (3.3.0 - 1043) <C4ADE5B1-A540-34E1-A043-118185489C9D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                     0x10bc52000 -        0x10bcc1ff1  com.apple.ApplicationServices.ATS (360 - 363.3) <546E89D9-2AE7-3111-B2B8-2366650D22F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                     0x10bced000 -        0x10bd76fff  com.apple.ColorSync (4.9.0 - 4.9.0) <B756B908-9AD1-3F5D-83F9-7A0B068387D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                     0x10bdbd000 -        0x10be02ff6  com.apple.HIServices (1.23 - 468) <E06287C4-1534-3D46-B099-3DF8B8EE4EB5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                     0x10be35000 -        0x10be44ff8  com.apple.LangAnalysis (1.7.0 - 1.7.0) <8FE131B6-1180-3892-98F5-C9C9B79072D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                              • 12. Re: PhotoShop crashes!
                                DinoStudio Level 1
                                HOW DOES ANYONE POST REPORTS?!!!!  WON'T EVEN TAKE IT BROKEN UP INTO SMALLER SECTIONS!
                                • 13. Re: PhotoShop crashes!
                                  Level 7
                                  You haven't installed any of the Photoshop CS5 updates -- you need to go do that now.  I'm pretty sure we fixed/worked around this in a dot release several years ago.
                                  • 14. Re: PhotoShop crashes!
                                    DinoStudio Level 1
                                    Where do I get these updates?
                                    • 15. Re: PhotoShop crashes!
                                      DinoStudio Level 1
                                      And how do I know how far back to go?
                                      • 16. Re: PhotoShop crashes!
                                        Level 7
                                        You get the latest update for CS5 (12.0.4).
                                        And Help -> Updates is a good place to start.
                                        • 17. Re: PhotoShop crashes!
                                          DinoStudio Level 1
                                          Message said there was an error downloading updates, try again.  So I did...3 times.  NEXT.
                                          • 19. Re: PhotoShop crashes!
                                            DinoStudio Level 1
                                            Yeah...done that almost a dozen times.  Here's the error message I get every time.
                                            HOW DID I KNOW YOUR SYSTEM WOULDN'T LET ME INSERT AN IMAGE OF THE ERROR MESSAGE?!!!  Even though it's only 70KB and 420x260 ppi  well within the limitations.  Here, let me take another 3 minutes to type it . . .
                                            "AdobePatchInstaller" can't be opened because it is from an unidentified developer.  Your security preferences allow installation of only apps from the Mac App Store and identified developers.
                                            • 20. Re: PhotoShop crashes!
                                              Level 7
                                              That's not an error, just information from Apple (since the CS5 installer came before Apple required signed apps/installers).
                                              Just change your system settings to allow it, and then run the installer.
                                              • 21. Re: PhotoShop crashes!
                                                DinoStudio Level 1
                                                Update Progress window
                                                Please close the following applications to continue:
                                                * Photoshop (Adobe Photoshop CS5)
                                                NOTE:  It wasn't running in the first place!  So there's no way to close the application.  So then I open up the Photoshop application so I can close it when I'm asked to...but it still doesn't continue to update...it also closes itself down!
                                                • 22. Re: PhotoShop crashes!
                                                  DinoStudio Level 1
                                                  Ok.  So far so good.  I was able to update.  Thanks for your help.
                                                  • 23. Re: PhotoShop crashes!
                                                    DinoStudio wrote:
                                                    HOW DID I KNOW YOUR SYSTEM ..
                                                    Just for reference, it's not *my* system.  I'm not with Adobe, I'm just trying to be helpful.
                                                    -Noel
