3 Replies Latest reply on Aug 16, 2014 1:18 PM by divisj
    Is it possible to create an ePub that had editable fields?
    sabrina5by5
      Is it possible to create an ePub that had editable fields? I am hoping to be able to make my training manuals digital, and I can just use PDF's, but ePub seems like a more elegant presentation platform since a lot of participants use iPads and things.
        • 1. Re: Is it possible to create an ePub that had editable fields?
          Steve Werner Adobe Community Professional & MVP
          If by "editable fields," you mean "form fields," as far as I know, EPUB 3 has no concept of editable fields.
          EPUB3 is designed to create books which will likely be sold on a bookstore. Books are inherently not editable after they are sold.
          Stick with PDF for form fields.
          • 2. Re: Is it possible to create an ePub that had editable fields?
            divisj Level 1
            I was intrigued by the idea so I did a quick search and found an answer by Sumit Kumar over on LinkedIn regarding how to initiate the keyboard on an iOS device for an input field within an epub.
            function iPadTouchHandler(event) {
            var type = "",
            button = 0; /*left*/
            if (event.touches.length > 1)
            return;
            switch (event.type) {
            case "touchstart":
            // OLD: On iPad2 clicking on a text input field did not show the keyboard
            // if ($(event.changedTouches[0].target).is("select")) {
            // NEW: Now on iPad2 the touchstart-Event on input fields is ignored and everything works fine
            // change my by Roland Caspers, Scheer Management
            if ($(event.changedTouches[0].target).is("select") || $(event.changedTouches[0].target).is("input")) {
            return;
            iPadTouchStart(event); /*We need to trigger two events here to support one touch drag and drop*/
            event.preventDefault();
            return false;
            break;
            </script>
            Note:
            Used <input type="color" name='Name' />
            instead of <input type="text" name='Name' />
            I have not tried this myself yet, but may have to add a "This book belongs to:" option at the beginning of my book. Thanks for the inspiration!
            • 3. Re: Is it possible to create an ePub that had editable fields?
              divisj Level 1
              I also just stumbled upon another answer by Steve Werner where he points to a link that points to this compare tool. It allows you to see which input types and other epub features are supported on which devices.
