2 Replies Latest reply on Aug 18, 2014 2:07 AM by annettecarla
    Why won't my InDesign CC 2014 document save any changes?
    annettecarla
      LS,
      I work with an Apple laptop retina display with OS 10.9.4
      I have an InDesign CC 2014 document and I can't save changes. I tried exporting as .idml opening that and saving as .indd. Doesn't work: nothing gets saved. I've replaced the preferences, that didn't do any good either. I have reinstalled InDesign CC 2014: nothing. I restarted my computer: no luck. When I open the same document on another computer it does O.K. Other InDesign documents are O.K. as well. What is going on?
      Annette
        • 1. Re: Why won't my InDesign CC 2014 document save any changes?
          Cari Jansen Adobe Community Professional
          @Annette,
          It sounds like you might be having some permissions issue on your computer, or there might be permission restrictions associated with the file you are working on.
          • Select the .indd file that is having issues
          • In the Finder, choose File > Get Info
          • Click the triangle to the left of Sharing & permissions at the bottom of the Info panel to see the permissions for your file.
          • Make changes if needed, or ask the owner of the file to make changes.
          Always make sure that you have made a proper back-up before running system checks and fixes.
          • Restart your Mac
          • In the Finder, choose Go > Utilities
          • Double-click the Disk Utility.app file
          • Select your Hard Drive in the list on the left, and choose Verify Permissions
          • If errors pop-up, then choose Repair Permissions.
          Fingers crossed this will resolve the issue.
          Cari
          • 2. Re: Why won't my InDesign CC 2014 document save any changes?
            annettecarla Level 1
            Hi Cari,
            I'd already made a new User Account and for the time being that solved my problem. After receiving your suggestion I tried the Disk Utility.app (and repeated it several times) and it fixed the InDesign document (or rather the User Account on my Apple). Anyway: thank you for your help!
            Annette
