0 Replies Latest reply on Aug 15, 2014 7:45 PM by meladesigns
    Having problems with applying actions in the South Africa Tutorial, the map should come in stop, have a action of click to play and then the next rectangle object com on the stage and action to playback in reverse.
    meladesigns
      @paultrani
      html
      <!DOCTYPE html>
      <html>
      <head>
        <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
        <meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
        <title>SouthAfrica</title>
      <!--Adobe Edge Runtime-->
          <meta http-equiv="X-UA-Compatible" content="IE=Edge">
          <script type="text/javascript" charset="utf-8" src="index_edgePreload.js"></script>
          <style>
              .edgeLoad-EDGE-23447420 { visibility:hidden; }
          </style>
      <!--Adobe Edge Runtime End-->
      </head>
      <body style="margin:0;padding:0;">
        <div id="Stage" class="EDGE-23447420">
              <div id="Stage_Ellipse" class="edgeLoad-EDGE-23447420"></div>
              <div id="Stage_bkgd" class="edgeLoad-EDGE-23447420"></div>
              <div id="Stage_midground" class="edgeLoad-EDGE-23447420"></div>
              <div id="Stage_Impala" class="edgeLoad-EDGE-23447420"></div>
              <div id="Stage_Text" class="edgeLoad-EDGE-23447420">South Africa<br></div>
              <div id="Stage_foreground4" class="edgeLoad-EDGE-23447420"></div>
              <div id="Stage_Rectangle" class="edgeLoad-EDGE-23447420"></div>
              <div id="Stage_WorldMap" class="edgeLoad-EDGE-23447420"></div>
          </div>
      </body>
      </html>
      Javascript
      window.AdobeEdge=window.AdobeEdge||{};if(!AdobeEdge.yepnope){(function(a,b,c){function d(a){return"[object Function]"==o.call(a)}function e(a){return"string"==typeof a}function f(){}function g(a){return!a||"loaded"==a||"complete"==a||"uninitialized"==a}function h(){var a=p.shift();q=1,a?a.t?m(function(){("c"==a.t?B.injectCss:B.injectJs)(a.s,0,a.a,a.x,a.e,1) },0):(a(),h()):q=0}function i(a,c,d,e,f,i,j){function k(b){if(!o&&g(l.readyState)&&(u.r=o=1,!q&&h(),l.onload=l.onreadystatechange=null,b)){"img "!=a&&m(function(){t.removeChild(l)},50);for(var d in y[c])y[c].hasOwnProperty(d)&&y[c][d].onload()}}var j=j||B.errorTimeout,l=b.createElement(a),o=0,r=0,u={t:d,s:c,e:f,a:i,x:j};1===y[c]&&(r=1,y [c]=[]),"object"==a?l.data=c:(l.src=c,l.type=a),l.width=l.height="0",l.onerror=l.onload=l. onreadystatechange=function(){k.call(this,r)},p.splice(e,0,u),"img"!=a&&(r||2===y[c]?(t.in sertBefore(l,s?null:n),m(k,j)):y[c].push(l))}function j(a,b,c,d,f){return q=0,b=b||"j",e(a)?i("c"==b?v:u,a,b,this.i++,c,d,f):(p.splice(this.i++,0,a),1==p.length&&h ()),this}function k(){var a=B;return a.loader={load:j,i:0},a}var l=b.documentElement,m=a.setTimeout,n=b.getElementsByTagName("script")[0],o={}.toString,p= [],q=0,r="MozAppearance"in l.style,s=r&&!!b.createRange().compareNode,t=s?l:n.parentNode,l=a.opera&&"[object Opera]"==o.call(a.opera),l=!!b.attachEvent&&!l,u=r?"object":l?"script":"img",v=l?"script" :u,w=Array.isArray||function(a){return"[object Array]"==o.call(a)},x=[],y={},z={timeout:function(a,b){return b.length&&(a.timeout=b[0]),a}},A,B;B=function(a){function b(a){var a=a.split("!"),b=x.length,c=a.pop(),d=a.length,c={url:c,origUrl:c,prefixes:a},e,f,g;for(f =0;f<d;f++)g=a[f].split("="),(e=z[g.shift()])&&(c=e(c,g));for(f=0;f<b;f++)c=x[f](c);return c}function g(a,e,f,g,h){var i=b(a),j=i.autoCallback;i.url.split(".").pop().split("?").shift(),i.bypass||(e&&(e=d(e)?e :e[a]||e[g]||e[a.split("/").pop().split("?")[0]]),i.instead?i.instead(a,e,f,g,h):(y[i.url] ?i.noexec=!0:y[i.url]=1,f.load(i.url,i.forceCSS||!i.forceJS&&"css"==i.url.split(".").pop() .split("?").shift()?"c":c,i.noexec,i.attrs,i.timeout),(d(e)||d(j))&&f.load(function(){k(), e&&e(i.origUrl,h,g),j&&j(i.origUrl,h,g),y[i.url]=2})))}function h(a,b){function c(a,c){if(a){if(e(a))c||(j=function(){var a=[].slice.call(arguments);k.apply(this,a),l()}),g(a,j,b,0,h);else if(Object(a)===a)for(n in m=function(){var b=0,c;for(c in a)a.hasOwnProperty(c)&&b++;return b}(),a)a.hasOwnProperty(n)&&(!c&&!--m&&(d(j)?j=function(){var a=[].slice.call(arguments);k.apply(this,a),l()}:j[n]=function(a){return function(){var b=[].slice.call(arguments);a&&a.apply(this,b),l()}}(k[n])),g(a[n],j,b,n,h))}else!c&&l()}v ar h=!!a.test,i=a.load||a.both,j=a.callback||f,k=j,l=a.complete||f,m,n;c(h?a.yep:a.nope,!!i) ,i&&c(i)}var i,j,l=this.yepnope.loader;if(e(a))g(a,0,l,0);else if(w(a))for(i=0;i<a.length;i++)j=a[i],e(j)?g(j,0,l,0):w(j)?B(j):Object(j)===j&&h(j,l);els e Object(a)===a&&h(a,l)},B.addPrefix=function(a,b){z[a]=b},B.addFilter=function(a){x.push(a )},B.errorTimeout=1e4,null==b.readyState&&b.addEventListener&&(b.readyState="loading",b.ad dEventListener("DOMContentLoaded",A=function(){b.removeEventListener("DOMContentLoaded",A, 0),b.readyState="complete"},0)),a.yepnope=k(),a.yepnope.executeStack=h,a.yepnope.injectJs= function(a,c,d,e,i,j){var k=b.createElement("script"),l,o,e=e||B.errorTimeout;k.src=a;for(o in d)k.setAttribute(o,d[o]);c=j?h:c||f,k.onreadystatechange=k.onload=function(){!l&&g(k.read yState)&&(l=1,c(),k.onload=k.onreadystatechange=null)},m(function(){l||(l=1,c(1))},e),i?k. onload():n.parentNode.insertBefore(k,n)},a.yepnope.injectCss=function(a,c,d,e,g,i){var e=b.createElement("link"),j,c=i?h:c||f;e.href=a,e.rel="stylesheet",e.type="text/css";for( j in d)e.setAttribute(j,d[j]);g||(n.parentNode.insertBefore(e,n),m(c,0))}})(this,document);Ado beEdge.yepnope=window.yepnope;}
      (function(compId){var htFallbacks;var testEle=document.createElement("div");function isSupported(a){for(var d=testEle.style,b,g=0;g<a.length;g++)if(b=a[g],void 0!==d[b])return!0;return!1}function supportsRGBA(){testEle.cssText="background-color:rgba(150,255,150,.5)";return 0==(""+testEle.style.backgroundColor).indexOf("rgba")?!0:!1}
      var hasTransform=isSupported(["transformProperty","WebkitTransform","MozTransform","OTransfor m","msTransform"]),hasSVG=!!document.createElementNS&&!!document.createElementNS("http://www.w3.org/2000/svg","svg").createSVGRect,hasRGBA=supportsRGBA(),hasJSON=window.JSON&&window.JSON.parse&&wind ow.JSON.stringify,readyToPlay=!1;function safeColor(a){a=""+a;if(!hasRGBA&&0==a.indexOf("rgba")){var d=a.lastIndexOf(",");0<d&&(a="rgb("+a.substring(5,d)+")")}return a}
      AdobeEdge._preloaders=AdobeEdge._preloaders||[];AdobeEdge._preloaders.push(function(){file sToLoad&&(loadResources(filesToLoad),filesToLoad=void 0)});function doLoadResources(){for(var a=0;a<AdobeEdge._preloaders.length;a++)AdobeEdge._preloaders[a]()}AdobeEdge._readyplayers =AdobeEdge._readyplayers||[];AdobeEdge._readyplayers.push(function(){readyToPlay&&AdobeEdg e.okToLaunchComposition(compId)});function playWhenReady(){AdobeEdge._playWhenReady=!0;for(var a=0;a<AdobeEdge._readyplayers.length;a++)AdobeEdge._readyplayers[a]()}function edgeCallback(a,d,b){htFallbacks[a]&&(a=htFallbacks[a]);AdobeEdge.preload.got[a]=!0;a==Ado beEdge.preload.last&&(!AdobeEdge.bootstrapLoading||AdobeEdge._playWhenReady?AdobeEdge.okTo LaunchComposition(compId):readyToPlay=!0,AdobeEdge.preload.busy=!1,0<AdobeEdge.preload.q.l ength&&(a=AdobeEdge.preload.q.pop(),AdobeEdge.requestResources(a.files,a.callback)))}
      AdobeEdge.requestResources=AdobeEdge.requestResources||function(a,d){AdobeEdge.yepnope.err orTimeout=4E3;AdobeEdge.preload.busy=!0;AdobeEdge.preload.got=AdobeEdge.preload.got||{};va r b,g=a.length,f=[],c;for(b=0;b<g;b++){c=a[b];if("string"===typeof c)0===c.indexOf("//")&&0===window.location.href.indexOf("file://")&&(c="http:"+c),url=c,c ={load:url};else if(c.load&&0===c.load.indexOf("//")&&0===window.location.href.indexOf("file://")&&(c.load ="http:"+c.load),url=c.yep||c.load,c.callback){var h=c.callback;c.callback=function(a,b,c){h(a,b,c)&&d(a,b,c)}}c.callback||(c.callback=d);Ad obeEdge.preload.got[url]||(f.push(c),AdobeEdge.preload.last=url)}f.length&&AdobeEdge.yepno pe(f)};var filesToLoad,dlContent,preContent,doDelayLoad,signaledLoading,loadingEvt,requiresSVG,htLoo kup={},aLoader,aEffectors,plSTF,ctrPlS,minPlW,maxPlW,plHeight,plWidth;function loadResources(a,d){AdobeEdge.preload=AdobeEdge.preload||[];AdobeEdge.preload.q=AdobeEdge. preload.q||[];d||!isCapable()?filesToLoad=a:AdobeEdge.preload.busy?AdobeEdge.preload.q.pus h({files:a,callback:edgeCallback}):AdobeEdge.requestResources(a,edgeCallback)}function splitUnits(a){var d={};d.num=parseFloat(a);"string"==typeof a&&(d.units=a.match(/[a-zA-Z%]+$/));d.units&&"object"==typeof d.units&&(d.units=d.units[0]);return d}
      function defaultUnits(a){var d=a;"auto"!==a&&((a=splitUnits(a))&&a.units||(d+="px"));return d}function findNWC(a,d){if(-1!=String(a.className).indexOf(d))return a;for(var b=a.childNodes,g=0;g<b.length;g++){var f=findNWC(b[g],d);if(!1!=f)return f}return!1}function parent(a){return a.parentElement}function offset(a){a=a.getBoundingClientRect();return{left:a.left+window.pageXOffset,top:a.top+win dow.pageYOffset}}function width(a){return a.offsetWidth}function height(a){return a.offsetHeight}
      function isWrapped(a){return/center-wrapper/.test(parent(a).className)}function wrapForStageScaling(a){if(!isWrapped(a)){var d=document.createElement("div"),b=document.createElement("div");d.className="flow-wrapper ";b.className="center-wrapper";d.style.width="1px";d.appendChild(b);parent(a).insertBefore (d,a);b.appendChild(a)}}
      function bindPSS(a,d){if(!isWrapped(a)){var b=function(){var b=isWrapped(a),f=b?parent(parent(parent(a))):parent(a),c=width(f),h=height(f),k=width(a), n=height(a),m=window.innerHeight,e=1,l=a.style;(f="body"===f.nodeName.toLowerCase())&&(h=m );c=Math.round(c);h=Math.round(h);c/=k;h/=n;"both"===d?e=Math.min(c,h):"height"===d?e=h:"w idth"===d&&(e=c);void 0!==maxPlW&&(e=Math.min(e,parseInt(maxPlW,10)/k));void 0!==minPlW&&(e=Math.max(e,parseInt(minPlW,10)/k));h="scale("+e+")";l.transformOrigin="0 0";l.oTransformOrigin="0 0";l.msTransformOrigin="0 0";l.webkitTransformOrigin="0 0";l.mozTransformOrigin="0 0";l.oTransformOrigin="0 0";l.transform=h;l.oTransform=h;l.msTransform=h;l.webkitTransform=h;l.mozTransform=h;l.oT ransform=h;if(!f||b)parent(a).style.height=Math.round(n*e)+"px",parent(a).style.width=Math .round(k*e)+"px";b&&(b=parent(parent(a)),b.style.height=Math.round(n*e+offset(a).top-offse t(b).top))};wrapForStageScaling(a);window.addEventListener("resize",function(){b()});b()}}
      function centerThePreloadStage(a,d){isWrapped(a)&&(a=parent(a));var b=a.style;/^both$|^horizontal$/.test(d)&&(b.position="absolute",b.marginLeft="auto",b.mar ginRight="auto",b.left="0",b.right="0");/^both$|^vertical$/.test(d)&&(b.position="absolute ",b.marginTop="auto",b.marginBottom="auto",b.top="0",b.bottom="0")}
      function simpleContent(a,d,b){var g=document.getElementsByTagName("body")[0],f=b||findNWC(g,compId),c,h,k;f?"absolute"!=f.s tyle.position&&"relative"!=f.style.position&&(f.style.position="relative"):f=g;plHeight&&( f.style.height=plHeight);plWidth&&(f.style.width=plWidth);/^height$|^width$|^both$/.test(p lSTF)&&d&&!b&&bindPSS(f,plSTF);/^vertical$|^horizontal$|^both$/.test(ctrPlS)&&d&&!b&&cente rThePreloadStage(f,ctrPlS);for(var n=0;n<a.length;n++){b=a[n];"image"===b.type?(g=document.createElement("img"),g.src=b.fill [1]):g=document.createElement("div");g.id=b.id;k=g.style;if("text"==b.type){if(c=b.font)c[ 0]&&""!==c[0]&&(k.fontFamily=c[0]),"object"!=typeof c[1]&&(c[1]=[c[1]]),c[1][1]||(c[1][1]="px"),c[1][0]&&""!==c[1][0]&&(k.fontSize=c[1][0]+c[ 1][1]),c[2]&&""!==c[2]&&(k.color=safeColor(c[2])),c[3]&&""!==c[3]&&(k.fontWeight=c[3]),c[4 ]&&""!==c[4]&&(k.textDecoration=b.font[4]),c[5]&&""!==c[5]&&(k.fontStyle=b.font[5]);b.alig n&&"auto"!=b.align&&(k.textAlign=b.align);b.position&&(k.position=b.position);(!b.rect[2]| |0>=b.rect[2])&&(!b.rect[3]||0>=b.rect[3])&&(k.whiteSpace="nowrap");g.innerHTML=b.text}d&& (g.className=d);k.position="absolute";c=b.rect[0];h=b.rect[1];if(b.transform&&b.transform[ 0]){var m=b.transform[0][0],e=splitUnits(m);if(e&&e.units&&(m=e.num,"%"==e.units&&b.rect[2])){var e=b.rect[2],l=splitUnits(b.rect[2]);l&&l.units&&(e=l.num,"%"==l.units&&(e=e/100*f.offsetW idth));m=m/100*e;0<f.offsetWidth&&(m=m/f.offsetWidth*100)}if(e=splitUnits(c))c=e.num;c+=m; e.units||(e.units="px");c+=e.units;if(1<b.transform[0].length){m=b.transform[0][1];(e=spli tUnits(m))&&e.units&&(m=e.num,"%"==e.units&&b.rect[3]&&(e=b.rect[3],(l=splitUnits(b.rect[3 ]))&&l.units&&(e=l.num,"%"==l.units&&(e=e/100*f.offsetHeight)),m=m/100*e,0<f.offsetHeight& &(m=m/f.offsetHeight*100)));if(e=splitUnits(h))h=e.num;h+=m;e.units||(e.units="px");h+=e.u nits}}k.left=defaultUnits(c);k.top=defaultUnits(h);k.width=defaultUnits(b.rect[2]);k.heigh t=defaultUnits(b.rect[3]);b.linkURL&&(htLookup[g.id]=b,g.onclick=function(){var a=htLookup[this.id];a.linkTarget?window.open(a.linkURL,a.linkTarget):window.location.href =a.linkURL},k.cursor="pointer");f.appendChild(g);if(b.c)for(k=0;k<b.c.length;k++)simpleCon tent(b.c[k],d,g)}}var fnCycle=function(a){a?fnCycle&&setTimeout(fnCycle,20):a={event:"loading",progress:0};load ingEvt&&loadingEvt(a)},aBootcompsLoaded=[];window.AdobeEdge.bootstrapListeners||(window.Ad obeEdge.bootstrapListeners=[]);window.AdobeEdge.bootstrapCallback=function(a){window.Adobe Edge.bootstrapListeners.push(a);if(0<aBootcompsLoaded.length)for(var d=0;d<aBootcompsLoaded.length;d++)a(aBootcompsLoaded[d])};window.AdobeEdge.preloadComplet e||(window.AdobeEdge.preloadComplete={});window.AdobeEdge.preloadComplete[compId]=function (a){AdobeEdge.$_(".edgePreload"+a).css("display","none");fnCycle=null;loadingEvt&&loadingE vt({event:"done",progress:1,reason:"complete"});aBootcompsLoaded.push(a);for(var d=window.AdobeEdge.bootstrapListeners.length,b=0;b<d;b++)try{window.AdobeEdge.bootstrapLi steners[b](a)}catch(g){console.log("bootstrap error "+g)}};function isCapable(){return hasTransform?requiresSVG&&!hasSVG?!1:!0:!1}
      function onDocLoaded(a){window.AdobeEdge.loaded=!0;fnCycle({event:"begin"});isCapable()?(preConten t&&preContent.dom&&preContent.dom.length&&simpleContent(preContent.dom,"edgePreload"+compI d),filesToLoad&&!signaledLoading&&(loadResources(filesToLoad),filesToLoad=void 0)):dlContent&&dlContent.dom&&(loadingEvt&&loadingEvt({event:"done",progress:1,reason:"do wnlevel"}),simpleContent(dlContent.dom))};window.AdobeEdge=window.AdobeEdge||{};window.Ado beEdge.framework='jquery';if(document.addEventListener){window.addEventListener("load",onD ocLoaded,false);}else if(document.attachEvent){window.attachEvent("onload",onDocLoaded);}
      requiresSVG=true;doDelayLoad=false;htFallbacks={"edge_includes/jquery-2.0.3.min.js":"//aja x.googleapis.com/ajax/libs/jquery/2.0.3/jquery.min.js","edge_includes/edge.4.0.1.min.js":" //animate.adobe.com/runtime/4.0.1/edge.4.0.1.min.js"};aLoader=[{load:"//ajax.googleapis.co m/ajax/libs/jquery/2.0.3/jquery.min.js",callback:function(result,key){if(!window.jQuery){y epnope({load:"edge_includes/jquery-2.0.3.min.js",callback:edgeCallback});return false;}return true;}},{load:"//animate.adobe.com/runtime/4.0.1/edge.4.0.1.min.js",callback:function(res ult,key){if(!window.AdobeEdge){yepnope({load:"edge_includes/edge.4.0.1.min.js",callback:ed geCallback});return false;}return true;}},{load:"index_edge.js"},{load:"index_edgeActions.js"}];if(AdobeEdge.bootstrapLoadi ng){signaledLoading=true;AdobeEdge.loadResources=doLoadResources;AdobeEdge.playWhenReady=p layWhenReady;}
      loadResources(aLoader,doDelayLoad);var plSTF="none",ctrPlS="none",minPlW="0",maxPlW=undefined,plWidth="700px",plHeight="400px";p reContent={dom:[]};
      //simpleContent
      dlContent={dom:[]};
      //simpleContent
      })("EDGE-23447420");
