2 Replies Latest reply on Aug 17, 2014 2:58 AM by mezofi
    PageItems position false I think
    mezofi
      I created a javascript file, this file read in an EPS file after it resize and add a new position all items. From 10 EPS file 7 ok, but 3 false.
      This EPS, I do not get correct position: http://mezofi.hu/proba_017.eps
      My js code:
      [code]
      // JavaScript Document
      //Set up vairaibles
      var destFolder, destDoc, sourceDoc, sourceFolder, newLayer, newName, out, kicsinyites;
      var out = false; // Kell-e menteni a képet
      var kicsinyites = true; // Kell-e a kicsinyíteni
      var teszt = true; // Teszteléshez kiíratunk minden félét
      // Select the source folder.
      sourceFolder = Folder.selectDialog('Hol vannak a Illustrator fájlok amiket át kell méretezni?', '~');
      if(out){
      // Get the destination to save the files
      destFolder = Folder.selectDialog('Válassz egy könyvtárat a mentett PNG fájlok részére.', '~' );
      // If a valid folder is selected
      if (sourceFolder != null) {
          files = new Array();
          // Get all files matching the pattern
          files = sourceFolder.getFiles();
          if (files.length > 0) {
             for (k = 0; k < files.length; k++) {
                  sourceDoc = app.open(files[k]); // returns the document object
                  //alert(sourceDoc.name);
                  //Mi a kép eredeti neve - File name
                  fileUrl = files[k];
                  fileUrl = fileUrl.toString();
                  fileUrlTomb = fileUrl.split("/");
                  tagDb = fileUrlTomb.length;
                  fileName = fileUrlTomb[(tagDb-1)];
                  fileNameArray = fileName.split(".");
                  newName = fileNameArray[0];
              // Select All layers in Active Document
              var myLayers = sourceDoc.layers;
               //Go through all layers of source document and copy artwork
               for (i = 0; i < myLayers.length; i++) {
               myLayers[i].hasSelectedArtwork = true;
              // középre igazítja a grafikát, körben 1 pixel margót hagy -position center + 1px space
              AdjustArtboardSize(0, true);
              function AdjustArtboardSize(abMargin, useLongSideMargin) {
                var aDoc = activeDocument;
               // var cb =  new Array(aDoc.cropBox);
               // alert(aDoc.cropBox);
                var vb = new Array(aDoc.visibleBounds);
                vb = aDoc.visibleBounds;
                var width = (vb[2] - vb[0]);  // left-right
                var height = -(vb[3] - vb[1]);  // bottom-top
                if (useLongSideMargin == true)
                    var margin = Math.max(width, height) * (abMargin / 100) +1;
                    vb[0] -= margin;    // left
                    vb[1] += margin;   // top
                    vb[2] += margin;   // right
                    vb[3] -= margin;   // bottom
                else
                    vb[0] -= (width * (1 + abMargin / 100) - width);  // left
                    vb[1] += (height * (1 + abMargin / 100) - height); // top
                    vb[2] += (width * (1 + abMargin / 100) - width);  // right
                    vb[3] -= (height * (1 + abMargin / 100) - height); // bottom
                  //alert(vb[0]+"\n"+vb[1]+"\n"+vb[2]+"\n"+vb[3]);
                aDoc.artboards[0].artboardRect = vb;
                  var docWidth = aDoc.width;
                  var docHeight = aDoc.height;
                  var myPathItem = aDoc.pathItems.add();
                  alert(myPathItem[0]+"\n"+myPathItem[1]);
                 if(kicsinyites){
                  engWidthMM = 97.89583333; // 370 pixel
                  engHeightMM = 97.89583333; // 370 pixel
                  engWidthPix = 370;
                  engHeightPix = 370;
                  percent = 100; //Alapból 100, tehát nem kell kicsínyíteni
                      //Kicsínyítés ha kell
                      if(docWidth > engWidthPix || docHeight > engHeightPix){
                      //Szélesebb, ezért csökkenteni kell az engedélyezettre
                           if (docWidth > docHeight) {
                           percent =  ( engWidthPix / docWidth ) * 100;
                          } else {
                           percent = ( engHeightPix /  docHeight ) * 100;
                      }else if( docWidth < engWidthPix ){
                      // Kisebb, meg kell nagyítani
                          } else {
                      if(teszt){
                      alert("Percent number: "+percent);
                  var docRef = app.activeDocument;
                   var layerRef = docRef.layers[0];
                   var pageItemCount = layerRef.pageItems.length;
                   //Minden elemre végig kell futtatni a kicsinyítést
                   var resize_count = 0;
                   with(sourceDoc) {
                      var count = pageItems.length;
                       if(pageItemCount > 1){
                          for (var i = 0; i < pageItemCount; i++) {
                          oldX = layerRef.pageItems[i].position[0];
                          oldY = layerRef.pageItems[i].position[1];
                          oszto = percent/100;
                          newX = oldX*oszto;
                          newY = oldY*oszto;
                          layerRef.pageItems[i].resize( percent , percent );
                          layerRef.pageItems[i].position = new Array(newX,newY);
                          resize_count++;
                       }else{
                        layerRef.pageItems[0].resize( percent , percent );
                  if(teszt){
                  alert("Resize count: "+resize_count);
                   /* 380*380 pixel image */
                   var vbc = aDoc.visibleBounds;
                  // more pageItem
                   var fix = 380;
                    szelesseg = Math.abs(vbc[2] - vbc[0]);
                    magassag =  (vbc[3] - vbc[1]);
                    //With
                    if( szelesseg < fix){
                    kulonbozet = (fix-szelesseg)/2;
                    vbc[0] -= kulonbozet;
                    vbc[2] +=  kulonbozet;
                    //Height
                    if( Math.abs(magassag) < fix){
                    kulonbozet = (fix - Math.abs(magassag) )/2;
                     if(magassag > 0){
                     vbc[1] -= kulonbozet;
                     vbc[3] += kulonbozet;
                     }else{
                       //Negatív  tesztelve
                      vbc[1] += kulonbozet;
                      vbc[3] -= kulonbozet;
                   }else{
                    vbc[0] = 107;    // left 105
                    vbc[1] = 610;   // top  614
                    vbc[2] = 487;   // right 485
                    vbc[3] = 230;   // bottom 225
               aDoc.artboards[0].artboardRect = vbc;
                 } // if(kicsinyites){ end
          else {
              alert('Nincs fájl a könyvtárban');
      [/code]
