2 Replies Latest reply on Aug 18, 2014 5:39 PM by Ankit Kanwara.
    Font Folio on InDesign
    benhoonana7
      I have had Adobe CS6 for 2 years now. I use indd. pretty rugularly, so I just downloaded Font Folio 11.1 to have a better array of fonts. Is it at all possible to load the fonts from Font Folio directly to indd? If so, what is the most correct and best way to do so? Thanks.
        • 1. Re: Font Folio on InDesign
          Sara.Forsberg Employee Moderator
          [moving discussion to InDesign forum]
          • 2. Re: Font Folio on InDesign
            Ankit Kanwara. Adobe Employee
            You can either install the font folio which would load the fonts in the system hence making it accessible to all applications including InDesign. Or In case you wish to just have it available to InDesign then there is a way, you can locate the "fonts" folder InDesign installation directory, i.e. on windows it should be under C:\Program Files (x86)\Adobe\Adobe InDesign CS6 or C:\Program Files \Adobe\Adobe InDesign CS6 depending weather your system is 64 bit or 32 bit. On Mac it should be under Applications/InDesign/Fonts
            Any font placed in the above directory will only be available to InDesign, Specifically to the version of InDesign that you copied the fonts over too.
            Hope this helps!!
            -Ankit Kanwara
