22 Replies Latest reply on Jun 8, 2017 7:28 PM by brookd
    CF11 VFS error: The Global Memory Limit 1000 MB for In-Memory Virtual FileSystem exceeded .
    chewymole
      Greetings,
      I have a fresh install of CF11 standard on Windows 8 server 64x
      16GB of ram
      JVM settings:
      -server -Xmn1024m -Xss1024k -XX:PermSize=256m -XX:MaxPermSize=2048m -XX:+UseParallelGC -Xbatch -Dcoldfusion.home={application.home} -Duser.language=en -Dcoldfusion.rootDir={application.home} -Dcoldfusion.libPath={application.home}/lib -Dorg.apache.coyote.USE_CUSTOM_STATUS_MSG_IN_HEADER=true -Dcoldfusion.jsafe.defaultalgo=FIPS186Random
      Min Heap: 2048mb, Max Heap 6144mb
      VFS settings:
      Global memory limit for VFS: 1000mb
      Memory Limit per Application for VFS: 400mb
      Currently CF is using 1.7GB of ram
      I have a 6 applications on this server. 1 of which makes use of the VFS.
      The others are simple cfm applications that have NOTHING to do with the VFS system.
      I have a scheduled task that calls simple cfm pages to update tables in our database. When these tasks run, i get a global error email (ones i have setup if a cf error happens) and the gist of the error is
      Browser
      CFSCHEDULE
      DateTime
      {ts '2014-08-16 15:07:00'}
      Diagnostics
      The Global Memory Limit 1000 MB for In-Memory Virtual FileSystem exceeded . <br>Increase the VFS memory limit in ColdFusion Administrator. <br>The error occurred on line 17.
      GeneratedContent
      [empty string]
      HTTPReferer
      [empty string]
      Mailto
      [empty string]
      Message
      QueryString
      [empty string]
      RemoteAddress
      xxx.xxx.xxx.xxx
      I have a utility i can run to view all the files in the VFS. and there is currently a total of 8 cfm files there that make up 4064KB of space within the VFS.
      The 1 application that actually uses the VFS has several functions. One of which basically writes out CFM files and then includes the cfm as a content variable and returns the variable.
      Under CF9 we were also deleting the ram drive CFM files after including them. But under CF11 this fails with an error saying the modified date could not be found. I have since removed the delete file part and the system works but we get this out of memory error with the VFS.
      Can someone shed some light on this for me?
      It makes no since.
