2 Replies Latest reply on Apr 25, 2007 12:14 PM by InfoSciCo
    Dynamically adding item to List box
    InfoSciCo
      Hi.
      I have a List box that is bound to an Array, and now I need to add some values to the List box.
      I can add a new item to the List box by hard-coding a value, such as:
      arrayData.addItem({'label':'test2', 'data':'99'});
      This works just fine. But the problem is that I don't know what the values will be,
      so I need a way ot dynamically adding a value via variables.
      I tried:
      var strLabel:String = "Some Text";
      var strData:String = "99";
      var newItem:Object = "{'label':'" + strLabel + "', 'data':'" + strData + "'}";
      And then adding it to the Array:
      arrayData.addItem(newItem);
      But what shows up in the List box is:
      {'label':'Some Label', 'data':'99'}
      I tried every variation I could think of. What's the correct syntax to do this?
