• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to apply the styling of the existing navigation buttons to newly added ones?
New Here ,
Aug 17, 2014 Aug 17, 2014
Hello,
I am using a predefined skin in robohelp and need to add new navigation buttons. However, when I generate help, the styling for the selected button is not applied to the new buttons.
I supposed that the styling should be applied as well to the new buttons(?), can you help me where can I update this?
You can see the issue from this video: Robohelp - zbayta's library
Info:
I am using Robohelp 10 and generating a Web Help
TIA!
Views
222
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
HI there
Most of the skin options for buttons are for using buttons made from images. So to get the "styling", you must use an image editing utility to create images of the button using the text you want.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Hello,
From the WebHelp skin editor, we have an option to select the color of the selected button -- the buttons are not actually an image. I supposed that if I selected another color, it will be applied to all the buttons?
backgroud color - zbayta's library
Votes
Translate
Translate
Report
Report
LEGEND ,
Aug 18, 2014 Aug 18, 2014
LATEST
Okay, I think I understand now.
Here's the deal. Even if you had images that you had created, there is no way that a new button that you add will simply remain on the "selected" bit after you click it.
The "selected" state will only ever apply to the TOC, Index, Glossary or Search buttons. This is because those elements cause a semi-permanent change to the WebHelp frameset by presenting the TOC, Index, Glossary, or Search in the navigation frame. Anything else is "temporary" and generally speaking, simply causes a topic to load into the topic frame.
If you want to see this change, you can vote for it by completing a wish form using the link below:
http://www.adobe.com/go/wish
Cheers... Rick
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
