2 Replies Latest reply on Aug 18, 2014 11:06 AM by A.T. Romano
    動画の音声のみ表示されます
    ikedamai0818
      premium elements 12で、動画を取り込むと編集画面で音声のみしか表示されません。
        • 1. Re: 動画の音声のみ表示されます
          https://translate.google.com/
          At, only voice only appear in the edit screen and capture video.
          From the Premiere Elements Information FAQ http://forums.adobe.com/thread/1042180
          •You MUST use an account with Administrator Privileges to run Premiere Elements
          •(Doing Run as Administrator http://forums.adobe.com/thread/969395 [says Encore and also for "All" versions of Premiere] will sometimes fix "odd" errors)
          •What version of Premiere Elements? Include the minor version number (e.g., Premiere Elements 12 with the 12.0.1 update).
          •What operating system? This should include specific minor version numbers, like "Mac OSX v10.6.8"---not just "Mac"
          •Has this ever worked before?  If so, do you recall any changes you made to Premiere Elements, such as adding Plug-ins, brushes, etc.?  Did you make any changes to your system, such as updating hardware, printers or drivers; or installing/uninstalling any programs?
          •Have you installed any recent program or OS updates? (If not, you should. They fix a lot of problems.)
          •What kind(s) of image file(s)? When talking about camera raw files, include the model of camera.
          •If you are getting error message(s), what is the full text of the error message(s)?
          •What were you doing when the problem occurred?
          •What other software are you running?
          •Tell us about your computer hardware. How much RAM is installed?  How much free space is on your system (C:) drive?
          And some other questions...
          •What are you editing, and does your video have a red line over it BEFORE you do any work?
          •Which version of Quicktime do you have installed?
          Exactly what is INSIDE the video you are editing?
          Codec & Format information, with 2 links inside for you to read http://forums.adobe.com/thread/1270588
          Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing
          http://forums.adobe.com/thread/592070?tstart=30 for screen shot instructions
          Free programs to get file information for PC/Mac http://mediaarea.net/en/MediaInfo/Download
          • 2. Re: 動画の音声のみ表示されます
            A.T. Romano Level 7
            ikedamai0818
            Bing translate English to Japanese
            要素プリミア 12 実行されているどのようなコンピューターオペレーティング システム12.1 プロジェクトのヘルプ メニュー/アップデートを使用して更新していること確認します
            あなたビデオ記録するを使用しているカメラブランド/モデル/設定とはですか?
            プロジェクトどのインポートですか?
            a. 行う miniDV ビデオカメラ DV または HDVデータ キャプチャ firewireやっています
            アドビプレミア エレメント キャプチャ ウィンドウですか?
            または
            b. その他
            答え詳細なります
            ここで起動決定し、連絡します。質問必要性明確化お問い合わせください
            ありがとう。
            ATR
            追加.あなたビデオファイル拡張子とはですか?
            English version of above
            ikedamai0818
            What computer operating system is your Premiere Elements 12 running on? Make sure that you have updated to 12.1 using the project's Help Menu/Update.
            What is the brand/model/settings of the camera that you are using to record your video?
            How are you importing it into the project?
            a. Do you have a miniDV camcorder and are doing DV or HDV data capture firewire into
            Premiere Elements Capture Window?
            or
            b. other
            The answers will be in the details.
            Let us start here and then decide what next. Any questions or need clarification, please ask.
            Thank you.
            ATR
            Add On...What is the file extension for your video?
