1. Re: See Also no displaying properly in WebHelp (RH11)
ctilly Aug 20, 2014 7:12 AM (in response to ctilly) -
2. Re: See Also no displaying properly in WebHelp (RH11)
Willam van Weelden Aug 26, 2014 12:40 AM (in response to ctilly)Changing the look and feel requires some effort on your part. You must change the styling in the function _WritePopupMenuLayer in the file ehlpdhtm.js (http://www.wvanweelden.eu/output_file/robohelp-9-and-earlier-webhelp/ehlpdhtmjs)
As for the scaling issue, this seems to be an issue with the embedded browser as it works fine in normal browsers. You can also change the scaling behaviour in the function _WritePopupMenuLayer.
Kind regards,
Willam
3. Re: See Also no displaying properly in WebHelp (RH11)
ctilly Aug 26, 2014 9:02 AM (in response to Willam van Weelden)Thanks William for the information. I opened the ehlpdhtm.js file in Dreamweaver. I compared two files, one which was used in my previous help (which I would like to make the See Also look like, this help was created in RH9) and the most recent file (which has the errors, see above images and now am using RH11). But the code in both files are exactly the same for WritePopupMenuLayer. I've included below an image of how I would like the See Also to look and the code from the ehlpdhtm.js file in my current help (RH11).
Also based on the code below, where would I make the change for the "hidden window" (scaling), in the STYLE section?
This is the code from my current help:
function _WritePopupMenuLayer()
if (!g_bIsPopupMenuInit)
if (gbBsNS4&&!gbBsNS6) {
//Do not try to write ininle styles for NS! NS can not handle it and will not stop downloading the html page...
document.write("<DIV CLASS='WebHelpPopupMenu' ID='PopupMenu'></DIV>");
} else{
document.write("<DIV ID='PopupMenu' STYLE='position:absolute; left:0px; top:0px; z-index:4; visibility:hidden;'></DIV>");
if (!(gbBsNS4&&!gbBsNS6)) {
document.write("<STYLE TYPE='text/css'>");
if (gbBsMac&&gbBsIE4) {
document.write(".PopupOver {font-family:'Arial'; color:white; background:navy; font-size:10pt; font-style:normal;font-weight:normal;text-decoration:none;}");
document.write(".PopupNotOver {font-family:'Arial'; color:black; background:#c0c0c0; font-size:10pt; font-style:normal;font-weight:normal;text-decoration:none;}");
} else {
document.write(".PopupOver {font-family:'Arial'; color:white; background:navy; font-size:8pt; font-style:normal;font-weight:normal;text-decoration:none;}");
document.write(".PopupNotOver {font-family:'Arial'; color:black; background:#c0c0c0; font-size:8pt; font-style:normal;font-weight:normal;text-decoration:none;}");
document.write("</STYLE>");
g_bIsPopupMenuInit = true;
Thanks again for your help,
Chris
4. Re: See Also no displaying properly in WebHelp (RH11)
Willam van Weelden Aug 26, 2014 12:06 PM (in response to ctilly)You need these lines:
} else {
Change the CSS styling added for the classes PopupOver and PopupNotOver to style it the way you want.
Don't forget to backup your changed file. When you generate the help again, ehlpdhtm.js will be overwritten.
Kind regards,
Willam
