5 Replies Latest reply on Aug 18, 2014 1:11 PM by heathrowe
    Scale simple rectangle with .css on hover
    Smarc
      Good evening dear members,
      I uploaded you a sample project to illustrate the problem. (Dropbox - Example.zip)
      Over all I only want to resize a rectangle with a hover effect. However, the problem arises that the size of the rectangle with scale = 1 changes?!
      I create a rectangle "button" and give the "button" as mouseout-action the following code:
      var object = sym $ ("button").
      rescale = 1;
      object.css ('transform', 'scale (' + rescale + ')');
      object.css ('o-transform', 'scale (' + rescale + ')');
      object.css ('- ms-transform', 'scale (' + rescale + ')');
      object.css ('- webkit-transform', 'scale (' + rescale + ')');
      object.css ('- moz-transform', 'scale (' + rescale + ')');
      object.css ('- o-transform', 'scale (' + rescale + ')');
      object.css ('z-index', '1');
      I don´t understand why
      the rectangle is changing!
      Maybe you can explain it to me :-)
      Best regards and many thanks
      Marc
        • 1. Re: Scale simple rectangle with .css on hover
          heathrowe Most Valuable Participant
          Try this (note the shorthand notation compared to your multiple .css calls)
          object.css({
                      'transform': 'scale(' + rescale + ')',
                      '-ms-transform': 'scale(' + rescale + ')',
                      '-moz-transform': 'scale(' + rescale + ')',
                      '-webkit-transform': 'scale(' + rescale + ')',
                      '-o-transform': 'scale(' + rescale + ')',
                      'z-index':'1'
          Darrell
          • 2. Re: Scale simple rectangle with .css on hover
            Smarc Level 1
            Hi Darrell,
            thanks for your reply!
            This makes the code easier to read and understand...  but my problem remains:
            Why does the rectangle gets smaller when the variable rescale = 1, shouldn´t it stay with same size?
            • 3. Re: Scale simple rectangle with .css on hover
              It shouldn't get smaller, in fact at a value of 1, it should not change at all because 1 equates to 100% of the original.
              Change the value to a higher number, like 2, for example. Which says 'transform to 200% of the original'.
              var object = sym.$("button");
              rescale= 2;
              object.css({
                          'z-index':'1'
              To get a better understanding of how the values work and there equivalents.
              - Select any element on your Stage;
              - Then toy with the Transform property (see capture);
              - as captured a transform at 167% equates to a value of 1.67
              hth
              Darrell
              • 4. Re: Scale simple rectangle with .css on hover
                Smarc Level 1
                Hello Darrell,
                thank you for your detailed reply! Your picture was just right for me...I have not paid attention to the set value
                Thank you for your kind help !
                Until my next issue
                Marc
                • 5. Re: Scale simple rectangle with .css on hover
                  You are welcome
                  Darrell
