1 Reply Latest reply on Aug 18, 2014 3:37 PM by gkaiseril
    Custom format multiple fields
    xavierharrell Level 1
      I'm looking to format multiple total fields to two decimal spots. Is there a way to do this without having to put each custom format script on each field?
        • 1. Re: Custom format multiple fields
          I would create a script to do the work:
          // array of field names to process
          var aFieldNames = new Array("Text1", "Text2", "Text3");
          // loop through the field names;
          for(var i = 0; i < aFieldNames.length; i++) {
          var f = this.getField(aFieldNames[i]); // get the field;
          f.setAction("Format", 'AFNumber_Format(2,0,0,0,"",true)'); // set the format;
          } // end for field names loop;
          Adobe has provided some documentation about the AFNumber_Format function.
          You could also set the keystroke and validation routines for numbers at the same time.
