I am simply running an action that converts all Word 2010 docs within a directory into pdfs in another directory. The Word doc is closed.
This is performed within Adobe Pro X. The directory to look in has been set. The directory to save in has been set, and is different.
The error message pops up after I run the action. If I click the OK button, the 'save pdf file as' box pops up, with Adobe printer's default save directory
(not the same as the above two) selected.
If I click Save, accepting the meaningless file name (ADPD5A5.pdf in this case) the problem goes away. If I chose cancel, the problem also goes away.
I don't want to save this pdf as anything other than what is set up in the action. How do I stop this from happening?
I've unchecked 'prompt for Adobe pdf file name' within the Word Adobe preferences, but to no success.
I will ultimately be converting scores of docs into pdfs, and cannot have to interfere with each one.
This worked fine on my XP machine, but now in Windows 7 64 bit (new machine, new Adobe install) it is causing this problem.
