1 Reply Latest reply on Aug 18, 2014 5:16 PM by Captiv8r
    Robohelp 11 dhtml javascript errors (HHComponentActivator” is undefined
    DonnaBlumberg Level 1
      Would greatly appreciate some help with this issue, I haven't been able to find anything online about it.
      I'm using  RoboHelp 11.02 (just upgraded from 11.01) on a 64 bit Windows 7 PC. When I try to Insert DHTML Effects, such as when a file has loaded, fade it in, I get the error "line 4233 char 2 Unable to get property ‘alpha’ of undefined or null reference code 0 File .../ehlpdhtm.js"
      Here's that part of the code.
      4231 CAgencyAlpha.prototype.PrepareEffect = function()
      4232    {// to set the visual filter function
      4233    // the visual filter ONLY work when set by "Width and Height" or
      4234    // absolute position for DIV, SPAN and normal tag ( such as p )
      4235    // but, "absolute" cause the following elements overlap, so:
      4236    CCSSP.PrepareFilter( this.ele );
      4237    CCSSP.ShowObject(this.ele, !this.bIsIn );
      4238 }
      and when I try to View a Browser Sequence (in another project) that I've added (to a Microsoft Help file), I see the message “line 354, char 4 error “HHComponentActivator” is undefined code 0"
      But line 354 is //End to support previous generic parameters.
      I searched for HHComponentActivator and found a few lines later,
      357 function BsHHActivateComponents()
      358 {
      359  if( HH_ActiveX && (HH_ChmFilename != "") && ((self == top) || (self == top.frames[0])))
      360  {
      361  var objBody = getElementsByTag(document,"BODY")[0];
      362  if( typeof(objBody) == "object" )
      363  {
      364  insertAdjacentHTML(objBody, "beforeEnd", '<OBJECT ID="HHComponentActivator" CLASSID="CLSID:399CB6C4-7312-11D2-B4D9-00105A0422DF" width=0 height=0></OBJECT>');
      365  if (HHComponentActivator.object)
      366  HHComponentActivator.Activate(HH_ChmFilename, HH_WindowName, HH_GlossaryFont, HH_Glossary, HH_Avenue);
      367  }
      368  }
      369}
      Any help is appreciated, I'd really like to get this resolved!
