1 Reply Latest reply on Apr 17, 2007 6:16 AM by Newsgroup_User
    Starting a Projector Over
    medonald1
      Hello All,
      OK, this is what I have. I am trying to get a projector to start over after 15 minutes. Both of these work, but after the first time they work as soon as I click on a tab it jumps back right away.
      It's like the projector thinks after I've done this once. I'm just going to keep doing it right away instead of waiting. Am I missing something?
      I will try again, just in case I am not giving enough info. The first time I run the projector it will wait the correct time and jump back to the index or page one. Now every time after that if I go to the page that is supposed to wait the 15 minutes, it will not wait, it just jumps back.
      on exitFrame
      if the timer > (1000*4) then go to "1" (the 4 would be what ever 15 min. would be, i'm guessing 900?)
      else
      go to the frame
      end if
      end
      I also tried this.
      on exitFrame
      if the timer > (30*1800) then go to "index"
      else
      go to the frame
      end if
      end
      Thank you very much.
        • 1. Re: Starting a Projector Over
          Level 7
          > something?
          You haven't set the timer back to zero.
          Andrew
