7 Replies Latest reply on Aug 19, 2014 10:36 AM by kglad
    drag and drop with user feedback
    tmjames_128
      I created a drag and drop game where users drop sections on a map and instantly receive feedback if they are correct or incorrect.  I've got the correct feedback working correctly but I can figure out the incorrect part as it is below nothing happens.  Any help is greatly appreciated
      stop();
      _global.counter=1;
      _global.totalquestions=10;
      Slogan1="Question 1";
      Slogan2="Question 2";
      Slogan3="Question 3";
      Slogan4="Question 4";
      Slogan5="Question 5";
      Slogan6="Question 6";
      Slogan7="Question 7";
      Slogan8="Question 8";
      Slogan9="Question 9";
      Answer1="Box_A";
      Answer2="Box_B";
      Answer3="Box_C";
      Answer4="Box_D";
      Answer5="Box_E";
      Answer6="Box_F";
      Answer7="Box_G";
      Answer8="Box_H";
      Answer9="Box_I";
      function init(){
      _root.slogan.text=Slogan1;
      _global.answer=Answer1;
      _global.counter++;
      function checkAnswer(guess){
      if (guess==_global.answer){
      _root.slogan.text=eval("Slogan"+_global.counter);
      _global.answer=eval("Answer"+_global.counter);
      _global.counter++;
      //_root.result.text="You Are Correct";
      feedback("correct");
      eval("_root." + guess)._alpha=70;
      eval("_root." + guess).active=0;
      if (_global.counter > _global.totalquestions){
      _root.complete.text="Quiz Complete";
      _root.slogan.text="Quiz Complete";
      }else{
      //_root.result.text="You Are Wrong";
      feedback("incorrect");
      init();
      function feedback (response){
        _root.correct._visible=0;
        _root.incorrect._visible=0;
        clearInterval (_global.feedTime);
         if (response=="correct")
         {_root.correct._visible=1;
           }else{
         _root.incorrect._visible=1;
         _global.feedTime=setInterval (clearFeed, 1000, response);
      function clearFeed(response){
        eval("_root."+response)._visible=0;
        • 1. Re: drag and drop with user feedback
          use the trace function to debug.
          stop();
          _global.counter=1;
          Answer1="Box_A";
          Answer2="Box_B";
          Answer3="Box_C";
          Answer4="Box_D";
          Answer5="Box_E";
          Answer6="Box_F";
          Answer7="Box_G";
          Answer8="Box_H";
          Answer9="Box_I";
          function init(){
          _global.counter++;
          trace(guess+" "+_global.answer);
          _global.counter++;
          }else{
          trace("incorrect");
          init();
               }else{
          trace("incorrect and code is working")
          • 2. Re: drag and drop with user feedback
            tmjames_128 Level 1
            When I do that this is displayed - Box_A Box_A.  So the correct part is working but something is wrong with the incorrect that I cant seem to figure out.
            stop();
            _global.counter=1;
            Answer1="Box_A";
            Answer2="Box_B";
            Answer3="Box_C";
            Answer4="Box_D";
            Answer5="Box_E";
            Answer6="Box_F";
            Answer7="Box_G";
            Answer8="Box_H";
            Answer9="Box_I";
            function init(){
            _global.counter++;
            _global.counter++;
            }else{
            trace("incorrect");
            init();
                 }else{
            • 3. Re: drag and drop with user feedback
              well, what do you see when you drop an incorrect object?
              • 5. Re: drag and drop with user feedback
                then you're not calling checkAnswer() when you drop an incorrect object.
                what code executes when an object is dropped?
                • 6. Re: drag and drop with user feedback
                  tmjames_128 Level 1
                  This is the code on every object that is dropped, there are 9 of them.
                  onClipEvent (load) {
                    this.active = 1;
                    origX = this._x;
                    origY = this._y;
                  onClipEvent (mouseDown) {
                    if (this.hitTest(_root._xmouse, _root._ymouse))
                    if (this.active == 1)
                    this.startDrag();
                  onClipEvent (mouseUp){
                       // see if the dropZone conatins the center of this mc
                    if (_parent.dropZone_A.hitTest(this._x, this._y, true))
                    _root.checkAnswer(this._name);
                    origX = 285.95;
                    origY = 230.00;
                    this._x = origX;
                    this._y = origY;
                    this.stopDrag();
                  • 7. Re: drag and drop with user feedback
                    that's not good coding.
                    but the problem is probably,
