2 Replies Latest reply on Aug 20, 2014 12:50 PM by nellbern
    grep prices & pattern  applescript
    nellbern Level 1
      Hello, I'm not able to compile the script below. (Syntax eror Expected "" but found unknown token). It is not a complicated search but can't get it to work.  Would love an explanation if possible where my error resides. I also tried the FindChangebyList applescript but I'm having unknown token  error  too
      Need to perform 2 GREP finds.
      Example 1 :
      $1.99 5.99 $189.99 599.99. I know in Indesign the $ symbol is problematic so in the Find/change/Grep i'm using the unicode value. This GREP search works perfect but not in the script.  \x{0024}?[\d.]+\d{2}. I found that I needed to add an xtra \ to the digits  but still i'm not able to compiling it  \x{0024}?[\\d.]+\\d{2}
      Example 2:
      Find a pattern & replace with a tab
      Tab (might be there or not)
      Find literal 120
      followed by 2 uppercase letters
      followed 5 digits
      after the 5 digits (uppercase |or digits) might be there or not
      example codes: 120AB12345, 120BC78945CD788, 120BC15935ABCL
      tell application "Adobe InDesign CS4"
        set find text preferences to nothing
        set change text preferences to nothing
      --Set FindWhat
        set find what of find grep preferences to "\x{0024}?[\\d.]+\\d{2}"
        --Find $1.99, $11.99, $119.99, 1599.99 The $ symbol (unicode \x{0024}) might be there or not
      set change to of change grep preferences to "" --replace with nothing
        set find what of find grep preferences to "\t?120[\u]{2}[\d]{5}([\u|\d]+)?"
        set change to of change grep preferences to "\t" --replace with a tab
      --set the  options
        set include footnotes of find change grep options to false
        set include hidden layers of find change grep options to false
        set include locked layers for find of find change grep options to false
        set include locked stories for find of find change grep options to false
      change grep
        set find grep preferences to nothing
        set change grep preferences to nothing
      end tell
        • 1. Re: grep prices & pattern  applescript
          Kai Rübsamen Level 4
          first of all, I have no idea how to write an applescript . So this is my first one.
          Some thoughts:
          1. If you escape something, you must escape it in general, so not only digits, but also \x{0024} or \t  >> \\x and \\t
          2. If you have two queries, you must set 'change grep' twice
          3. Some cosmetics: \x{0024} can be written as \x24 and [\d]{5} should be written als \d{5}.
          With some changes, this lines work for me:
          tell application "Adobe InDesign CC 2014"
              set find what of find grep preferences to "\\x24?\\d+\\.\\d{2}"
              change grep
              set find what of find grep preferences to "\\t?120\\u{2}\\d{5}([\\u|\\d]+)?"
              set change to of change grep preferences to "\\t" --replace with a tab
              change grep
          end tell
          – Kai
          • 2. Re: grep prices & pattern  applescript
            nellbern Level 1
            Thanks Kai. I'm trying a different approach. I'm using POSIX classes for finding $ & the prices. When I'm using the Find & Change windowThe code is compiling but it's not finding anything. Do i need escape characters too. If that's the case where I should put the escape character \\
            --Set FindWhat
              set find what of find grep preferences to "~h?[[=$=]]?[[:digit:]][[:digit:]][[=.=]][[:digit:]][[:digit:]]"
              --Find $11.99, The $ symbol might be there or not
              set find what of find grep preferences to "\\t?120[\\u]{2}[\\d]{5}([\\u|\\d]+)?"
            --set the  options
            change grep
            end tell
