3 Replies Latest reply on Aug 21, 2014 10:21 AM by Serifaz
    A couple questions about flascc
    Serifaz
      So I did some extensive searching over Google and these forums.
      I am trying to figure out a few things about flascc, and how it works.
      First.
      Where do I download flascc?
      Is it flash pro cc, or is it another program.
      Do I need to compile it. If so can the initial build be made with cmake.
      Second.
      Can flascc communicate between a c++ console application and a database.
      Are there any examples on the web on how to do so.
      If not can someone supply me with a simple hello world example or just a way to pick up
      data output by the console which it picks up from the database when called for.
      Third.
      If these things are not available.
      Is there a way to accomplish the same communication between flash>console>db>console>flash
      if so please give some examples or link to a place that does.
      please also take into consideration that I am still learning.
      and need details on how these things work.
      Thank you for your time and patience with reading my post, even if you can't help I appreciate that you took the time.
        • 1. Re: A couple questions about flascc
          Preran Adobe Employee
          Hi Serfaz,
          Answering the first part of your question. See https://creative.adobe.com/products/download/flash
          Preran
          • 2. Re: A couple questions about flascc
            -mikey1969- Level 1
            First.
            - Get it here:  https://creative.adobe.com/products/download/flash
            - All the same thing.
            - No need to compile.  You download and install Flash.  Then you use a combination of timeline animation and code to create whatever it is you want.  Then you "publish" (aka compile) the project into an SWF (for browsers) or as a program or app (for Windows, iOS, or Android)
            Second.
            - Flash can communicate with databases, but to talk to the c++ app, that's where you might want to start learning about ANEs (AIR Native Extensions)
            - Native extensions for Adobe AIR | Adobe Developer Connection
            - Uh... Sorry.  You're on your own for that one.  :-(
            Third.
            - Like I said, I think ANE's would be the way to go... But you've moved well outside my comfort zone on this topic.
            - I hope someone with more knowledge on that end of things is able to help you out more than I can.
            Good luck!
            • 3. Re: A couple questions about flascc
              Serifaz Level 1
              thanx soo much for the help... I  will look into ANEs Air
              you were very helpful .
