4 Replies Latest reply on Aug 21, 2014 7:29 PM by Crystal Tsui
    Operation problem
    Crystal Tsui Level 1
      Dear All,
      I can not open Indesign CC 2014 and Windows 8 system always stopped the operation, Please help me to solve this problem? Thanks!
        • 1. Re: Operation problem
          Can you translate that error message for us?
          • 2. Re: Operation problem
            Thanks, Peter.
            The translation of the error message as below:
            "Adobe InDesign CC 2014 has stopped working
            Since the problem occurred, causing the program to stop the normal operation.
            Windows will close the program, if there are any solutions will notify you."
            Unfortunately, I didn't receive any solutions from Windows.
            • 3. Re: Operation problem
              Might be a number of different things, and Windows isn't very helpful at telling us what they are.
              ID is sensitive to badly made or damaged fonts. It might also be a font manger auto-activation plugin if you use a font manager.or it could be something else entirely.
              Things you can try:
              Trash the prefs. See Replace Your Preferences
              Reboot and log in on a different user account.
              Make sure the default printer is local (not network) and turned on. You can use a virtual printer, like MS Fax, if necessary. After one successful launch you should be able to change back.
              Remove any non-adobe plugins (old versions are not forward compatible).
              That little message under the dialog in the splash screen might give a clue, too.
              • 4. Re: Operation problem
                Thanks Peter.  I will try it.
