2 Replies Latest reply on Aug 20, 2014 5:44 AM by Sasan
    indesign quit unexpectedly with this  error " Transparency blend Space "
    Sasan
      i need some hand-helping please
      I just exported to pdf, and got this message, and would be happy to fix it if I had a clue what to do:
      The document's transparency blend space doesn't match the destination color space specified in the Export Adobe PDF settings. To avoid color appearance changes in the PDF, click cancel and change either the document's transparency blend space, or the destination color space.
      i’ve checked  the Edit.Transparency Blend Space which is already on CMYK i have no PDF's placed in the document.  also checked Adobe PDF Presets; "Output" tab; Change "Destination" to Document CMYK - U.S. Web Coated. which works for me.
      but no matter which preset i pick ;  as soon as indesign starts to make a PDF file  InDesign has unexpectedly quit.
      i though it might be fix with uninstall and reinstall .. done but the problem is still there i also try another file which i worked on before  and they had no problem but the result are the same for them as well . I'm getting the same message I started with.
      using cc version will be appreciate if any one could point me what is the problem and what to do ?
