This content has been marked as final.
Show 6 replies
1. Re: Get file metadata with Reader API
Bernd Alheit Aug 20, 2014 4:24 AM (in response to PlombSoldier2)Which API?
2. Re: Get file metadata with Reader API
PlombSoldier2 Aug 20, 2014 5:21 AM (in response to Bernd Alheit)The plugin API (C/C++), it is possible to use the PDDocGetXAPMetadata in Reader? If not, what alternatives?
3. Re: Get file metadata with Reader API
Bernd Alheit Aug 20, 2014 5:40 AM (in response to PlombSoldier2)Yes, a plugin can access the data.
4. Re: Get file metadata with Reader API
PlombSoldier2 Aug 21, 2014 2:21 PM (in response to Bernd Alheit)My project was generated by the wizard, but when try to use the PDDocGetXAPMetadata function the project does not compile with this error: "'PDDocGetXAPMetadataSELPROTO' : undeclared identifier".
Any ideas?
5. Re: Get file metadata with Reader API
Test Screen Name Aug 22, 2014 12:59 AM (in response to PlombSoldier2)You probably need to add the right header file. The documentation should tell you which one. If not, just search the header files for the problem identifier.
6. Re: Get file metadata with Reader API
Bernd Alheit Aug 22, 2014 1:46 AM (in response to PlombSoldier2)This function is not available in Adobe Reader. With the functions of the low level COS Layer you can access the data.
