7 Replies Latest reply on Aug 22, 2014 5:09 AM by VeluVK
    alternate row shading in tables
    VeluVK Level 1
      I am working in financial tables. the tables having alternate row colours.
      I have applied cell styles to all table body rows. In additionally  i need alternate row colors in all tables, in table style alternate row option not working. but once i remove the cell styles in body rows it will working.
      Can any one please give me a solution regarding this issue?
        • 1. Re: alternate row shading in tables
          Chinnadk Level 4
          Try this,
          var doc = app.activeDocument,
              _tables = doc.stories.everyItem().tables.everyItem().getElements();
          for(var i =0;i<_tables.length;i++)
                  var _rows = _tables[i].rows;
                  for(var j=1;j<_rows.length;j+=2)
                          _rows[j].fillColor = doc.colors.item("red");
          Regards,
          Chinna
          • 2. Re: Re: alternate row shading in tables
            Trevorׅ Adobe Community Professional
            I think this is what you want
            var doc = app.documents.add(),
                tf = doc.pages[0].textFrames.add({
                    geometricBounds: ["12.7mm", "12.7mm", "100mm", "197.3mm"],
                    contents: "Head 1\tHead 2\tHead 3\r1a\t1b\t1c\r2a\t2b\t2c\r3a\t3b\t3c\r4a\t4b\t4c\r5a\t5b\t5c"
                myTable = tf.texts[0].convertToTable();
            myTable.rows[0].rowType = RowTypes.headerRow;
            myTable.alternatingFills = AlternatingFillsTypes.alternatingRows;
            myTable.startRowFillColor = doc.colors.itemByName("Magenta");
            myTable.startRowFillTint = 60;
            myTable.endRowFillColor = doc.colors.itemByName("Cyan");
            myTable.endRowFillTint = 50;
            Trevor
            • 3. Re: Re: alternate row shading in tables
              P.s. for all the tables etc. use doc = app.activeDocument and myTable(s) = doc.stories.... as per China's example
              I was just showing how to do the alternating bit in the snippet above
              • 4. Re: alternate row shading in tables
                Kai Rübsamen Level 4
                Guys, your scripts produces local overrides.
                @VeluVK: I would think, that your cellstyle has a fill applied. In this case the alternating rows from the table style are overwritten by the cellstyle. In a normal world there is no need for a script in this case.
                If your cellstyles have no fill, please provide an example file.
                – Kai
                • 5. Re: alternate row shading in tables
                  VeluVK Level 1
                  Hi Kai,
                  Many thanks for your reply.
                  Cell style fills having "None".  but it is not working. when I use the Ignore it will working fine.
                  Thanks & Regards,
                  Velu
                  • 6. Re: alternate row shading in tables
                    VeluVK Level 1
                    I am working in financial tables. i need script for the below requirement. any one suggest.
                    For all tables from second column onwards ""Tbody_rightalign" paragraph style. and all parenthesis values should be "Tbody_bracket" style, but these changes to be omitted in first rows because column head having separate style.
                    • 7. Re: alternate row shading in tables
                      VeluVK Level 1
                      Grey should be Tbody_rightalign style.
                      Pink color should be Tbody_bracket style.
                      Any one help me pls. i am having 150+ tables.
                      Velu
