1 Reply Latest reply on Aug 20, 2014 6:26 PM by A.T. Romano
    How can I adjust video from two cameras that are out of sync?
    Revdc
      Hi - I've just recorded someone speaking on two cameras with the intention of cutting clips in from the second camera while using the video and soundtrack from the main camera, however the two video files are out of sync by half a second or so by the end. How can I 'stretch' the shorter clip so they coincide properly? Thanks, David.
        • 1. Re: How can I adjust video from two cameras that are out of sync?
          A.T. Romano Level 7
          David
          What version of Premiere Elements are you using and on what computer operating system is it running?
          Typically, select the clip,
          as you hold down the Alt key of the computer main keyboard, tap the left or right arrow key once. Each tap = 1 frame nudge.
          as you hold down the Shift+Alt keys of the computer main keyboard, tap the left or right arrow key once. Each tap = 5 frames nudge.
          If you are working with audio editing, consider Edit Menu/Project Settings/General with Audio Display Format = Milliseconds.
          Please let us know if any of the above worked for you.
          Thank you.
          ATR
