5 Replies Latest reply on Aug 20, 2014 1:30 PM by Larry G. Schneider
    I need help with relative links in an interactive PDF
    r4a9s Level 1
      I was recently asked to create an interactive PDF file that could be used as a user interface to access a number of client files.
      The files are broken down into about 30 folders and subfolders and there is a link from the PDF to each folder, each containing several PDF and/or image files. I created the document in InDesign CC and it works well on our network, but the issue now is moving the entire project to the client via a USB drive.  Moving the files this way will break all the links.
      The question is twofold: 1) How can I make the project work correctly as a self-contained unit on the USB drive; and 2) How can I make it so that when the client moves everything over to their network, it will continue to work properly?
