1 Reply Latest reply on Aug 21, 2014 8:36 AM by heathrowe
    Error in OAM file
    ldpinc
      I have an EDGE file that I modified.  When I save it, and even when I save it with a different name, it produces a correct HTML file. When I publish it for use in Muse, with or without a different name it produces an OAM file that when placed in MUSE displays in exactly the same way as the original file before modification and/or before saving with a different name. The HTML file with either the original name or the new name displays and animates correctly.  Is this a problem the EDGE or MUSE?
      Thanks, Dan
        • 1. Re: Error in OAM file
          heathrowe Most Valuable Participant
          You shouldn't have to resort to Publishing different versions.
          In Edge Animate
          - make your change;
          - Save then File > Publish;
          Over in Muse
          - go to the Assets Panel, right click on the .oam asset element and choose 'Update Asset'. see capture below.
          - File Save then File > Preview in Browser to see the changes.
          In your case, it could be a simple case of adding the wrong version and or a snag with your Browser cache (clear browser cache to see if it corrects it).
          Darrell
