This content has been marked as final.
Show 3 replies
1. Re: "to-content" chunk not working
Jeff_Coatsworth Aug 21, 2014 6:06 AM (in response to SharadaTV)Not knowing much about Structured FM, I wonder if there’s any issue with the FM to RH integration here. If you try importing your FM content into a blank RH project, does it end up the way you want? If so, then the issue must be in the FM publishing settings (because the guts of it are all from RH); if not, then I wonder if it’s something to do with the FM content.
2. Re: "to-content" chunk not working
SharadaTV Aug 21, 2014 6:44 AM (in response to Jeff_Coatsworth)Jeff,
Thanks for your response.
We do not want to import the dita files into RH and want to go with the Publish option from FM. I will again look into FM content.
Regards
Sharada
3. Re: "to-content" chunk not working
Jeff_Coatsworth Aug 21, 2014 7:13 AM (in response to SharadaTV)It was just a testing suggestion, not a lifetime commitment ;>)
