Dear Team,
We would like to use QueryForMultipleRowsAsXML service for one of the requirement. For the XML Information parameter of the this service, we would like to pass xml/column mappings dynamically. We found using the XmlDocumentInfoBean process variable (JDBC Data Type) we can pass column mappings dynamically. Could you please help us to configure the column mappings using this variable. Actually we need how to use this variable type.
Thanks in advance
Ravitheja
Solved! Go to Solution.
Ravi,
Attached herewith is a working sample. That should help you.
-Wasil
Views
Total Likes
Ravi,
-Wasil
Views
Total Likes
Dear Wasil,
The solution is working perfectly. Thank you so much for your help. Have a good day!!
Warm Regards,
Ravitheja
