4 Replies Latest reply on Aug 22, 2014 8:26 AM by enrique zendejas
    Error "Status code:403" al usar cffileupload
    enrique zendejas
      I using a cffileupload to upload a file into server, but the component give me an error "Status code:403". Somebody have any idea?
        • 1. Re: Error "Status code:403" al usar cffileupload
          vishu#13 Pioneer
          Are you running cffileupload over https? If yes, then it is a bug in ColdFusion 10.
          Also, share the code?
          • 2. Re: Error "Status code:403" al usar cffileupload
            enrique zendejas Newcomer
            thanks for your comments.
            I not using HTTPS yet because I working in development enviropment, and I have coldfusion 9 and Apache in the server.
            I have two files, the first have next code:
            <cfoutput>
            <script type='text/javascript'>
              var cierra=function cerrarVentana(){
              window.close();
              var error_carga=function error(e){
              alert("Estado:"+e.STATUS+"\n  Mensaje: "+e.MESSAGE+"\n Archivo:"+e.FILENAME);
            </script>
            <cffileupload
                url="uf_xxx.cfm?ids=#url.ids#&fe=#url.fe#&#urlEncodedFormat(session.urltoken)#"
                progressbar="true"
                name="upload"
                addButtonLabel = "Agregar Archivo"
                clearButtonlabel = "Limpiar"
                hideUploadButton = "false"
                width=500
                height=200
                title = "Carga de archivos"
                extensionfilter="*.xls"
                BGCOLOR="##FFFFFF"
                MAXFILESELECT=1
                UPLOADBUTTONLABEL="Cargar archivo"
                onUploadComplete = cierra
                onError=error_carga
                maxuploadsize="20"
                stoponerror=true
            the second file is uf_xxx.cfm and have the next code:
            <cftry>
              <cffile action="uploadAll" destination="#expandpath('../../archivo')#" nameconflict="overwrite">
                <cfset stock = createObject("component","#Application.webroot#/component")>
              <cfset res=stock.recibe_stock("#expandpath('../../archivo/#cffile.serverFileName#.xls')#",url.id s, url.fe)>
                <cfcatch type="any">
                <cfset str.STATUS = 500>
              <cfset str.MESSAGE = "Error durante la carga del archivo">
                    <cfquery datasource="db" >
                        insert into logerror values(sysdate,'error', 'error')
                    </cfquery>
                </cfcatch>
            </cftry>
            When I try it, the file not up and the second file not execute and in the cffileupload component appers the message "Status code: 403".
            I think that is a configuration issue but I not find the solution yet.
            • 3. Re: Error "Status code:403" al usar cffileupload
              vishu#13 Pioneer
              Try this
                <cffile action="uploadAll" destination="#expandpath('../../archivo')#" nameconflict="overwrite" accept="application/vnd.ms-excel">
              • 4. Re: Error "Status code:403" al usar cffileupload
                thanks again.
                I tried your suggestion but i have the same error.
