3 Replies Latest reply on Aug 22, 2014 12:39 PM by JimHess
    Camera raw does not read D7100 nef files [was:Ernied]
    Ernied
      Camera raw does not read d7100 nef files. did update...still no success.
        • 1. Re: Ernied
          You need at least Camera Raw 7.4 for that camera. What version of Photoshop are you running? And what version of Camera Raw do you have installed?
          • 2. Re: Ernied
            Ernied Level 1
            For JimHess I have PS 5.5 Camera Raw version 6.7.1.  Have downloaded the DNG Converter which does make the images work.
            • 3. Re: Camera raw does not read D7100 nef files [was:Ernied]
              I suspect that the DNG converter will work for you if you use it properly. It isn't your fault, but Adobe has created a kind of a silly interface in the DNG converter. Notice that it is asking you for the folder. When you are browsing for a location within the DNG converter, choose the folder, but don't open the folder. If you do then the DNG converter will tell you there are no images to convert. If you choose the folder then the DNG converter will convert all the files within that folder.
