2 Replies Latest reply on Aug 30, 2014 6:23 AM by Royi A
    How to Work in 32 Bit in Premier Pro Plug In
    Royi A Level 1
      As I understand it, Adobe Premier Pro doesn't support "Smart Render" mode as in After Effects.
      Yet I don't understand how does it support 32 Bit Per Channel input.
      I look at the SDK sample called SDK Noise, at the following code:
      PrPixelFormat destinationPixelFormat = PrPixelFormat_BGRA_4444_8u;
                      if (pixelFormatSuite) {
                              (*pixelFormatSuite->GetPixelFormat)(output, &destinationPixelFormat);
                              if (destinationPixelFormat == PrPixelFormat_BGRA_4444_8u){
                                      ERR(suites.Iterate8Suite1()->iterate(   in_dataP,
        0,                                                              // progress base
        linesL,                                                 // progress final
        &params[NOISE_INPUT]->u.ld,             // src
        NULL,                                                   // area - null for all pixels
        (void*)&niP,                                    // refcon - your custom data pointer
        FilterImageBGRA_8u,                             // pixel function pointer
        output));
                              } else if (destinationPixelFormat == PrPixelFormat_VUYA_4444_8u){
        0,                                                              // progress base
        FilterImageVUYA_8u,                             // pixel function pointer
        output));
                              } else if (destinationPixelFormat == PrPixelFormat_BGRA_4444_32f) {
                                      // Premiere doesn't support IterateFloatSuite1, so we've rolled our own
                                      IterateFloat(   in_dataP,
        0,                                                              // progress base
        FilterImageBGRA_32f,                    // pixel function pointer
        output);
                              } else if (destinationPixelFormat == PrPixelFormat_VUYA_4444_32f) {
        0,                                                              // progress base
        FilterImageVUYA_32f,                    // pixel function pointer
        output);
                              } else {
                                      //      Return error, because we don't know how to handle the specified pixel type
                                      return PF_Err_UNRECOGNIZED_PARAM_TYPE;
                              err = AEFX_ReleaseSuite (
                                      in_dataP,
                                      out_data,
                                      kPFPixelFormatSuite,
                                      kPFPixelFormatSuiteVersion1,
                                      NULL);
      I removed some code related to errors.
      Yet even if I set the Render and the Sequence (Preview) to 32 Bit (Max Bit Depth) it still always selects 8 Bit Format.
      I don't understand how the pipeline should work in order to enable support for 32 Bit processing.
      Any assistance?
      How exactly does it work?
