This content has been marked as final.
Show 4 replies
1. Re: PDPageSetPDEContent change PDF content
lrosenth Aug 22, 2014 6:25 AM (in response to vin22)If you change the content in certain ways, then things will move...(because you told them to)
2. Re: PDPageSetPDEContent change PDF content
vin22 Aug 22, 2014 11:58 AM (in response to lrosenth)But I didn't tell "them" to' move.
I clone the PDF and call the setcontent method without modifying the content.
The result is the PDF with graphic and text moved in a different position. elements position change even il I don't set New coords
3. Re: PDPageSetPDEContent change PDF content
lrosenth Aug 22, 2014 12:01 PM (in response to vin22)If you want someone to look at your code, you are welcome to file a formal tech support request with our developer support.
4. Re: PDPageSetPDEContent change PDF content
Test Screen Name Aug 22, 2014 1:06 PM (in response to lrosenth)Of course if it only happens with certain PDFs it _might_ be a bug in PDFEdit. But these are pretty much fixed these days, I assume you are up to date, with Acrobat 11?
